02-25-2018, 08:27 PM | #51 | |
Posted via Mobile Device Last edited by LowCST; 02-25-2018 at 08:53 PM. |
02-26-2018, 09:07 AM | #52 | |
Posted via Mobile Device |
02-26-2018, 10:20 AM | #53 | |
Re: 22" Gm Transport wheels
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-26-2018, 11:21 AM | #54 | |
1.) get all 4 wheel centers bored to clear the hubs 2.) run 1.25-1.5” spacers on the rears (either find ones that fit our hubs or get them bored as well) if I’m reading your instructions right I shouldn’t have to use spacers on the fronts. 3.) make sure the studs now are long enough to clear the new setup. I’m gonna look at what the other guys mentioned above and check out the Toyota style spacers that may fit. I’m going to run a hubcentric spacer if at all possible for safety and stability reasons so if I find a solution that fits I’ll def let you know. Thanks again for the help man much appreciated Posted via Mobile Device |
02-26-2018, 12:04 PM | #55 | |
1) Correct. Only exception here is if you plan to do a disk swap in the process of getting these wheels mounted. The rotors have a smaller hub and fit inside the transit center without boring them. If you are running all drums, then they all need to be bored. 2)Correct. No spacers on front needed. The rears are technically called adapters. There are no spacers that wide. Adapters bolt to your existing studs and then have their own studs that the wheel bolts to. 3)See 2). You won't need to replace the studs if you run adapters. The only thing you didn't mention is getting the lugnuts I referenced above. I HIGHLY recommend getting those for the fronts. for the rears, you won't need them if you get adapters because those usually have the larger studs in them (and I think they come with lugnuts).
02-26-2018, 12:34 PM | #56 | |
02-26-2018, 12:41 PM | #57 |
Moderator
You can also wash them with this soap. Not sure if "Wagon Train" makes soap, but this stuff gets em clean:
02-26-2018, 08:14 PM | #58 |
I may order some mob wheels for my 61 impala.
02-26-2018, 09:44 PM | #59 |
The center hub on the stock steel wheels specs out right at 3.5" and my bore on the transits is 3.7". There's definitely some room to tighten that up but I think you're going to have to be really sure you can get the bore centered. I can see on my wheels that the bore is ever so slightly off center, so it's a good thing the bore isn't centering the wheel on the hub because it would probably vibrate.
02-26-2018, 10:38 PM | #60 |
The lug nuts will need to line it up.
02-28-2018, 12:29 AM | #61 |
I have a 1998 Chevy that is a light duty 3/4 ton. I plan on using the engine, transmission and rear Axle in my 64. Will the transport wheels need to be bored for a 1998 6 lug rear end? I am also wondering what how close the width is on the 1998 rear end is vs the 1964.
Of coarse I can measure it but I am not to that point yet. Thanks |
03-07-2018, 12:05 AM | #62 |
I also have a 2003 Escalade will that rear end be too wide for my truck has anybody tried it yet? 1965 C10 Fleetside
03-07-2018, 01:01 AM | #63 |
60-66 Nut
I'm pretty sure it will be 3-4" wider than your original differential.
04-06-2018, 03:06 PM | #64 |
I have them on my truck. Work awesome. I will post pics soon
I’m the starter of this thread |
05-05-2018, 11:01 PM | #65 |
Hi Everyone.
I got my 22" transports from kijiji from a guy in red deer I used the hubcap clips from the guy on instagram. they were easy to put on I used just regular "dog dish" hubcaps, baby moons, got them from a place in Edmonton on Calgary trail, just south of 63 Ave, hubcap king or something like that. the 22s have been great. I have a CPP 5-6 drop. no rubbing except hard bumps in the rear. I think the tires touch the inner wheel well. other than that its all great. |
05-05-2018, 11:06 PM | #66 | |
05-05-2018, 11:07 PM | #67 |
05-06-2018, 05:09 PM | #68 |
1/2" spacer won't work without extending the lugs. There wouldn't be enough material and it would be really dangerous driving like that. Stock studs only have 3/4" material on the outside of the drum.
I've been selling them for about 4 years now. |
05-06-2018, 09:28 PM | #69 |
I have 1/4 inch on mine.
05-06-2018, 09:28 PM | #70 |
Oh yeah i have longer studs.
05-06-2018, 10:52 PM | #71 |
Right on. Unfortunately 1/4" isn't enough to clear the bed on a fleetside. I'm not sure about a stepside.
07-16-2018, 06:03 AM | #72 |
Quick question, I just picked up a set of transports. They came with 10.5" hubcaps and what I believe are old style very clips.is there a pattern available or pdf download so I can make sure I get them exact? I don't want to wobble.
08-21-2018, 10:03 PM | #73 | |
08-21-2018, 10:51 PM | #74 | |
Thanks, |
01-23-2023, 06:26 PM | #75 |
New Member
Hey are you still sell the studs?
