03-04-2012, 11:47 AM | #151 |
Re: New 1957 Project
cool,, what size did you go with?
03-04-2012, 12:13 PM | #152 |
I went with 255/85 16 tires. I originally went with zero offset rims but, found out the hard way that they won't clear the tie rod ends.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
05-15-2012, 09:39 AM | #153 |
It is now sold
05-15-2012, 10:49 AM | #154 |
Thanks for your service, hope to see you back soon with a new project.
It's sad that you had to sell it without getting to enjoy it for very long but I hope you got a lot for it. It should be a high dollar truck IMO. How did you sell it? EBay, HAMB, this forum, CL? just curious. |
05-15-2012, 03:07 PM | #155 |
Thanks. I enjoy doing what I do.
I sold it for $24.5 and I could have gotten a bit more but, didn't want to get greedy. I had it listed in multiple sites but, old-ride was the one that I got the most hits off of. I already have my next project a 63 Biscayne.
09-05-2013, 08:59 AM | #156 |
Re: Steering pictures
03-10-2018, 02:05 AM | #157 |
how do I fix my driver door hinge as the top hole for pin is worn and big. 99 chevy silverado replaced pins but top hole is worn bigger. i was told that the hinge needs replaced but no one wants to do it. Help ple
ase Last edited by Rebecca55; 03-10-2018 at 02:07 AM. Reason: add more |
03-10-2018, 07:06 PM | #158 |
I had the same problem with mine. I welded the hole and drilled to correct size. replaced the pins and bushings. just gotta bear in mind where the correct hole center should be.
otherwise replace with a new hinge, not usually gonna break the bank. |
