#426 |
Re: Used Parts Build
More nice work. Just weld a ring on there for a bungee.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#427 |
Box is done and mounted
![]() ![]() The rear is starting to come together ![]() I need to figure out how to mount my limit straps still. Bought some hard line for my fuel lines so I can try to keep making progress.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#428 |
I'm just glad to be here!
Battery box looks good. If the battery ever falls out, it won't be for the box being under built!
How about mounting your limit straps in the shock bolts between the shock on the frame?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#429 | |
I used your thread to set up my fuel sending unit btw. Thank you for that. I was thinking the same thing about the limiting straps. I need to reassemble everything and mock them up to see what would work best.
#430 |
I need to work on my vertical up. I made a tab to bolt my ground strap to. I am trying to make everything on this thing easy to service and I though this would be a good idea.
![]() Made a bunch of tabs to run my fuel lines and battery cable. I need to make some more for the other side to run my airline and brake line. ![]()
#431 |
![]() ![]() Join Date: Aug 2013
cool...nice work
#432 | |
Link: https://www.mcmaster.com/#sex-bolts/=1bucq9j
#433 |
#434 |
What are the limit straps for?
#435 |
To keep the rear end from dropping too low when I jack the truck up.
There is nothing to keep my rear end from dropping down enough to damage the bags or bind up the watts link.
#436 |
Got the other cross member bar welded on the other side. Moved to the front for a bit to get a break from working on the back.
Shortened my lower control arms 1.5''. Still need to finish welding out the other side and add a truss on the bottom side. ![]() ![]() ![]()
#437 |
looks good!
#438 |
Your an ambitious dude...lol
Joe |
#439 |
Thank you sir.
Ive seen the body work and paint you have been doing. That's way more work than I am doing!
#440 |
Shortened my upper control arms. Tacked them together just to check the fit. I went 1.5'' with the lowers and 1.25''(ish) with the uppers. Might grind a hair more off because I am near 0 degrees camber with one shim and want a bit more room for error. I clear the hood hinges now. Still a bit tight with the turning. I get why the raised cross members tuck so much now. I might still go with a CPP modular spindle for that extra 3/4''. Ill figure it out later.
![]() Checking for any binding or issues. Seems like I should be okay to lay out. ![]()
#441 |
Looking good dude. Nice work.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#442 |
Some terrible pictures for you...Upper control arms are done. Reassembled the front suspension. Shortened the tie rods.
![]() Tapped the water pump for a steam port line. ![]() Thinking it is about time to pull the cab and finish the frame work...
#443 |
Glad to see progress.
#444 |
Nice work......anxious to see it finished...
#445 |
Thanks guys. Here is an update.
![]() Going to try to finish out all the chassis work over the next few weeks. Pulling the cab was a pain! I wish I had the space for a lift.
#446 |
Started grinding off the por15 I did a few years ago. Going to shoot it with epoxy instead. Cleaned up my boxing a bit to make it look nicer. Welded on the tops of my body mounts. Need to pull my engine and trans next.
#447 |
Got some work done this weekend:
Didn't like my previous steering stabilizer so I made a new one ![]() ![]() Welded on my turbo drain ![]() Reboxed my Z with a bit more style and all tig welded. ![]() ![]()
#448 |
Very nice.
#449 |
Well done.....
#450 |
Made some new motor mount towers (again..)
![]() ![]() Weld shot for fun ![]() Finally able to lay out without the oil pan touching ![]() Started the trans mount ![]() Started laying out tubes to figure out how I want to build the inner frame stiffener ![]()
