Old 05-17-2018, 11:48 AM   #1
SKR
Looking for a rear mount tank
Hey I'm looking for a rear tank, preferably EFI ready, and definitely as bolt-in as possible. I see No Limit makes one, and CPP does too. Does anyone have any experience with either one of those? Is there anyone else I should look at? Thanks.
2007 GMC 2500 CCSB LBZ
1991 GMC 1500 RCSB 350
1981 GMC Street Coupe RCSB 454
SKR is offline   Reply With Quote
Old 05-17-2018, 12:41 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Looking for a rear mount tank (NOT BOYD WELDING)
A lot of us use an OEM Blazer or Suburban tank. Although this may not be as fancy as the other options you are looking at, but it gets the job done.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-17-2018, 01:25 PM   #3
RADustin
I've had great success with tanks inc.
http://www.tanksinc.com/index.cfm/pa...cat/cat133.htm
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 05-17-2018, 01:34 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
GSI Machine Fab just started making these for c10’s.
Keith
Convert to disc brakes.
Old 05-17-2018, 07:04 PM   #5
SKR
I was under the impression that the Blazer tank took a little engineering to get it to work, but talking to my mechanic today he said he didn't think it would be an issue. So that might be the way I go. It won't be as pretty but the rest of the truck sucks so there's no need for the tank to be a work of art.
Thanks, I'll have a better look at that tonight.
I didn't know that, thanks. All their crossmembers and frames and stuff look really nice, so their tanks should be too.
Old 05-17-2018, 07:20 PM   #6
44th Miss Inf
I’ve got a bad blazer frame I’ll remove the tank crossmembers and mounting hardware from if anyone is interested.
44th Miss Inf is offline   Reply With Quote
Old 05-17-2018, 07:21 PM   #7
Goats86
The drawback to the Blazer tank is no baffles. When mine shows less that 1/4 tank (about 8 gallons) and I corner and throttle hard, it can loose fuel for a second.
Goats86 is offline   Reply With Quote
Old 05-17-2018, 08:14 PM   #8
44th Miss Inf
The one out of the 89 Blazer I have with the bad frame was baffled. I’m guessing 87 - up would be as they are FI, but could be wrong.
Old 05-17-2018, 09:52 PM   #9
LOW 7FO
LOW 7FO's Avatar
I bought the No Limit tank with an internal pump to simplify my EFI install. It looks to be high quality. Requires you to remove the spare tire holder and rear cross member. The one thing I don't like about it is that the mounting flange is flat for the full length of the tank and the rear frame has a small kick up which makes it look goofy for mounting it. I plan to make some sort of elbow bracket to fill this area up. Won't be visible once bed is back on anyways I'm just being picky. Hopefully I didn't overlook something with it haha. See attached pics.
lowfastnloud
LOW 7FO is offline   Reply With Quote
Old 05-17-2018, 10:50 PM   #10
SKR
I would have thought an 87+ tank would be baffled too, but I've never seen one to know for sure. Either way, Holley's Hydramat would probably be a quick and easy fix for that.
Looks nice. I see what you mean about the flange. That would probably bug me too.
Old 05-18-2018, 10:32 AM   #11
Bloodhound
I got a poly 31 gallon Blazer tank from here http://www.ineedparts.com/heavy-duty...y-gm-en-2.html
It is baffled.
Bloodhound is offline   Reply With Quote
Old 05-18-2018, 11:58 AM   #12
zach_carver
zach_carver's Avatar
Why not Boyds? Ive used a few of them and always had great luck with them.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 05-18-2018, 12:19 PM   #13
SKR
Because I got mad and jumped the gun regarding an issue I had, but that has been resolved and I will now be using a Boyd tank.
Old 05-19-2018, 03:24 PM   #14
86c10shorty
Boyd fuel tanks are pretty sweet, you can always go to EFI for when your ready to go that routeName:  gas tank.jpg
86c10shorty is offline   Reply With Quote
