Old 05-29-2018, 08:27 PM   #1
jeffs56
56 cab on camaro clip
Hey guys I finally got one of my cabs on the camaro clip frame I’ve been going back and forth with. Not sure what frame to use. What do you guys think of how it looks. Sits really really high for some reason
jeffs56 is offline   Reply With Quote
Old 05-29-2018, 10:18 PM   #2
59chev
59chev's Avatar
Re: 56 cab on camaro clip
There is two popular ways to install the clip. Was the clip blended into the frame or was the stock frame stacked on top of the clip? The blended clip sits a little higher and some guys run 2" drop spindles to bring it back down. Also the weight of the engine, bumper, hood, ect usually brings it down an inch or two.
Take a look at my thread to see ride height with a stacked camaro clip frame.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 05-29-2018, 10:48 PM   #3
jeffs56
Mine is stacked also
Old 05-29-2018, 11:25 PM   #4
59chev
59chev's Avatar
I have some 1" all thread going through the shock holes to hold the spring compressed. It should sit the same as mine once the weight of the bumper, engine, ect are in place.
Old 05-30-2018, 12:03 AM   #5
mr48chev
mr48chev's Avatar
That is not TOO HIGH with no engine or trans in the truck. You have to have the weigh on the springs or do as 59 Chevy said and use all thread or some sort of static height spacer rather than the springs to see the final height without everything being on the truck.
Slide under the front with a tape measure and measure from the bottom of the crossmember to the shop floor. A Camaro at stock height sits real close to 6 inches to six inches from the bottom of the crossmember to the shop floor. That should show you how much you can expect it to drop with the stock springs.
My ongoing truck projects:
Old 05-30-2018, 12:39 AM   #6
jeffs56
These are the measurements I have now. I will have to get the other ones
Old 05-30-2018, 11:17 AM   #7
mr48chev
mr48chev's Avatar
Measure at the middle of the crossmember. Those photos don't say much except the install of the subframe may be rather suspect from seeing that that they wacked it off with a torch and didn't bother to clean up the cuts the rest of it may have the same hack job.
Old 05-30-2018, 12:27 PM   #8
MARTINSR
MARTINSR's Avatar
I have little experience with this, but did one and I looked at the Camaro's weight and the truck were super close. I measured the distance between the rubber bumper on the lower control arm on a stock Camaro and put "all thread" in place of the shock and tightened it up bring sub frame down until that distance was the same from the rubber bumper to the control arm. Then set the frame on jack stands at the height I wanted it and simply welded the sub frame to the frame at that height.
Also, checked the upper control arm shafts angle using an angle finder and put that exactly the same so it would align properly.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-30-2018, 07:34 PM   #9
jeffs56
Just seems way off to me. I’ll get the measurements when I get back over there. I just can’t see a motor lowering the truck that much. Cuz those are 20 inch wheels. So when I put the 15’s on it’s going to have to come down even more
Old 05-30-2018, 08:02 PM   #10
MARTINSR
MARTINSR's Avatar
I think the outside diameter on the 15's may be as much or more than those 22's with rubber bands on them!
As I remember it was VERY little distance between the rubber bumper on the control arm and the frame. I am thinking it was something like one inch.
Brian
1948 Chevy pickup
Old 05-31-2018, 05:17 PM   #11
idbeast
Mine is done even at frame height, 18" wheels and tires, 27" tall same as stock.
idbeast is offline   Reply With Quote
Old 06-01-2018, 01:27 AM   #12
jeffs56
I took the measurement today. From the crossmember to the ground is about 11-12 inches. And I was just messing around with the front fenders and it’s off by a few inches
Old 06-01-2018, 02:47 PM   #13
_Ogre
_Ogre's Avatar
add the: motor, trans, interior, doors, hood, glass, radio to get it down
those rubber band tires wouldn't last a week here in michigan
shop air compressor timer
Old 06-01-2018, 02:57 PM   #14
_Ogre
_Ogre's Avatar
my truk had the suspension fully extended for a long time
with the truk at the top pic point i could jump on the front frame with no spring compression
bottom pic shows ready to drive, came down 3 inches more after the bumper, side glass and interior
Old 06-02-2018, 02:06 AM   #15
jeffs56
Those wheels are just rollers that came with the frame. They are junk. The fenders aren’t even close to lining up. Needs a lot of adjustments and fabricating some stuff. I’m staying with my dropped axle. If I don’t like that I’ll put in a aftermarket mustang 2
Old 06-02-2018, 10:47 AM   #16
MARTINSR
MARTINSR's Avatar
Good thinking!
Brian
1948 Chevy pickup
Old 06-03-2018, 02:59 PM   #17
Purcell69
This was mine sitting on a stacked Camaro clip. The tires are 235/60R15s and when the truck was sitting in the grass, they were aired up, not flat or in holes. This is the best example of what I had at the time.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 06-04-2018, 12:09 AM   #18
59chev
59chev's Avatar
Here's mine mocked up. Stacked camaro clip with all thread in the shock holes. Frame is sitting on the rear end right now ( I plan on a step notch and a 4-link ) but this is my intended ride height.
Old 06-04-2018, 01:47 AM   #19
jeffs56
Those both look good. Mine is far from that. Way too high on my suspension for my liking
Old 06-04-2018, 10:46 AM   #20
lowrodderchev
lowrodderchev's Avatar
Yeah cause you don't got the weight of the motor trans radiator fluids etc etc. Like we all said get a threaded bolt tighten it to hold the springs down. Or pull the springs and use the long ass bolt to hold front end up
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-04-2018, 11:21 AM   #21
jeffs56
I will see what I can come up with. Thank you
