Old 07-12-2018, 06:15 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
c20 front drums removal
Hello everyone quick question
i need to get access to the wheel studs on front of my truck
i pulled the dust cover -spindle nut-the notched washer-2 flat head screws
now im stuck how in the heck does the drum come off? i cant get the bearings our couse i cant get a good grip on them.
the drum budges a tiny bit but thats it
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 07-12-2018, 08:44 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: c20 front drums removal
There is probably a small ridge at the inside edge of the drum where the brake shoes don't rub it and wear the drum. You will have to back off the adjusters.
~Steven
Simi Valley, CA
Old 07-12-2018, 09:50 PM   #3
nrb's70gmc
nrb's70gmc's Avatar
Might be a dumb question but which way should I spin the adjusting knob?
Up or down to back off?
Old 07-12-2018, 10:06 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
I can't remember off-hand but you turn them one way and it will either solve your problem or make the drum hard to turn, in which case you go the other way. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 07-13-2018, 12:05 PM   #5
nrb's70gmc
nrb's70gmc's Avatar
ware the heck is the adjustment slot on front drums? dont see anything on backing plate
Old 07-13-2018, 01:37 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
It may have never been knocked out. Look for an indentation about an inch long and 1/4" wide. Might be a little bigger each way. Should be in the backing plate, though some drums have the knockout as well.
~Steven
Simi Valley, CA
Old 07-13-2018, 02:22 PM   #7
nrb's70gmc
nrb's70gmc's Avatar
I got it. There are 4 untapped holes on drum face wedged a flat head in them and walked it off
Now is the spindle supposed to slide off? Tried pulling it but there is some resistance.
Old 07-13-2018, 04:01 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Once you back the adjusters off, the drum should come off. If you meant that the hub should come off, yes it should, since you have the spindle nut removed. The bearings may be a bit tight on the spindle, so make take some persuading.
~Steven
Simi Valley, CA
