Old 02-23-2015, 02:05 AM   #76
P10-001
P10-001's Avatar
Re: 1968 GMC P-10 Ice Cream Truck
It's a bit rough outside, but I like it
1968 GMC P-10
P10-001 is offline   Reply With Quote
Old 03-04-2015, 09:34 PM   #77
P10-001
P10-001's Avatar
Talking Re: 1968 GMC P-10 Ice Cream Truck
I got the engine fired up and almost have it ready for its first test drive. I am just waiting on the adaptor for the alternator.
1968 GMC P-10
Old 04-27-2015, 07:51 PM   #78
P10-001
P10-001's Avatar
I've been busy getting the truck in primer and then doing a vinyl wrap on it. I found out that the transmission had a bad repair that messed up the pump and bushing. I am getting close to making my first ice cream sale... The company name is "Aye! Scream"
1968 GMC P-10
Old 04-27-2015, 07:52 PM   #79
P10-001
P10-001's Avatar
Also put in a new window from E-bay. It's 35"x44"
1968 GMC P-10
Old 04-27-2015, 07:57 PM   #80
P10-001
P10-001's Avatar
3 gallons of aircraft remover paint stripper. I am so glad to be done with that part!
1968 GMC P-10
Old 12-18-2015, 05:05 PM   #81
Corte's Speed Shop
Any updates on this? Wondering if you had any issues fitting the SBC (i.e. did you have to modify the cab floor or pedals?)? Do you have any pics from the side showing the stance with it aired out? Also, did you end up using any sort of booster for the brakes? TIA for the info. I picked up a '66 step van and am planning on bagging it and tossing a 5.3/TH350 combo in it.
Corte's Speed Shop is offline   Reply With Quote
Old 12-18-2015, 05:26 PM   #82
P10-001
P10-001's Avatar
I did finish it. It worked out pretty well. I had to cut about 2-2 1/2" out of the firewall and floor. It's a bit cramped and the only issue is filling the power steering fluid.
I also had to cut out the floor brace that is under the engine cover. I put the engine and trans in as one piece thru the passenger door. I am almost wishing I put in a non-computer trans and a carb, but I do like this engine/trans so far.
1968 GMC P-10
Old 12-18-2015, 05:28 PM   #83
P10-001
P10-001's Avatar
As it sits now. It now has 7 switches
1968 GMC P-10
Old 12-18-2015, 05:32 PM   #84
P10-001
P10-001's Avatar
Out with the old
1968 GMC P-10
Old 12-18-2015, 05:34 PM   #85
P10-001
P10-001's Avatar
You can see how tight of a squeeze this really is. I tried to leve as much room for my feet as I could.
1968 GMC P-10
Old 12-18-2015, 11:18 PM   #86
Corte's Speed Shop
Looks like it turned out great! Were you able to use a factory type power steering box? If not, what did you end up using? And how did you fit the brake booster? Any pics would be greatly appreciated. Here's mine as it currently sits. Hoping to get started on it next month.
Old 12-18-2015, 11:43 PM   #87
P10-001
P10-001's Avatar
I was able to change the steering gearbox to one from a 1968 c10 that was power. The brake booster is from eBay. It just fits
1968 GMC P-10
Old 12-18-2015, 11:45 PM   #88
P10-001
P10-001's Avatar
You can kind of see the brake booster and master cylinder
1968 GMC P-10
Old 04-09-2016, 07:50 AM   #89
P10-001
P10-001's Avatar
Changed out the wheels. I can set the front crossmember on the ground now!
1968 GMC P-10
Old 05-13-2016, 02:46 PM   #90
P10-001
P10-001's Avatar
Started our ice cream season yesterday. We get a lot of looks!
1968 GMC P-10
Old 06-02-2016, 02:30 AM   #91
P10-001
P10-001's Avatar
Selling some ice cream
1968 GMC P-10
Old 06-02-2016, 06:14 AM   #92
GR8-68
GR8-68's Avatar
That is sweet !! ( no pun intended ) love the color scheme also
GR8-68 is offline   Reply With Quote
Old 06-03-2016, 11:12 AM   #93
tommys72
tommys72's Avatar
Nice work! Now go make some profit
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 06-03-2016, 12:24 PM   #94
P10-001
P10-001's Avatar
1968 GMC P-10
Old 12-05-2017, 12:01 PM   #95
Corte's Speed Shop
Any updates on this little hot rod?
Old 12-26-2017, 08:25 PM   #96
Aberdare
Aberdare's Avatar
Also curious if there are any updates on this project.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 07-18-2018, 02:30 PM   #97
preciador6
nice I have owned 3 1972 P10s and now I have a 1968 GMC P10
preciador6 is offline   Reply With Quote
