08-14-2018, 11:53 PM | #1 |
New Tool Gantry Crane
First use of new crane.
Works good so far. Very easy to lift stuff. Should work great, for removing cab, bed, and moving frame. Grandson doing lifting Thanks, Les Last edited by aotte1; 08-15-2018 at 01:25 AM. |
08-15-2018, 07:39 AM | #2 |
Re: New Tool Gantry Crane
I’d love one! But where to put it??!?!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-15-2018, 11:46 PM | #3 |
SAVING ONE TRUCK AT A TIME
I have the same one from Harbor Freight. I did't like the fact that you could barely fit a truck within the uprights. I went to my local steel vendor and walked there yard for a remnants and found a much thicker 11' beam and some heavy plates to weld to it. Works much better know and has 10' clear and I think I spent about $75.00. Good luck with the new toy. CHIZZLER.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
08-16-2018, 11:06 PM | #4 |
Chizzler,
Sounds like a nice upgrade, will look into finding a longer top I-beam too. Les |
