#51 | |
Re: Installing Deluxe trim on cab
for making a backer for the tape to stick to i'd think body filler would work well the shape of the trim would lock in the filler, even if it cracked every 1 inch we use the grey tape (joedoh refers as vhb) for body kits and window louvers use of the 3m adhesion promoter would guarantee a permanent bond
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#52 |
![]() Join Date: May 2007
here is newfishers how to, I followed it except I only used spacers and tape about every foot.
http://67-72chevytrucks.com/vboard/s...2&postcount=23
#53 | |
![]() ![]() Join Date: Nov 2008
I really love the deluxe trim but i just couldnt wrap my head around drilling holes in my newly restored and painted cab. I'm going to have to reconsider now. If any of you does this PLEASE take detailed photos of it and especially if you run into any hangups doing it. Thanks to Newfisher and of course to JoeDoh for remembering it and posting the link here.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#54 |
The last time I was at the auto paint store I saw a display of various clips and they had some wire clips that had the rubber seal on them. If I was still thinking of using wire clips I would go back there and see if I could find something that would work. I've decided that I'm not going to drill holes to mount the trim so I'll leave it off until I figure out some way to hold it on. I'm going down to see my son next week and get his advice about it.
#55 |
that's a good idea for straight trim, which our cab trim is not
#56 |
After reading this thread I had to open the trim kit that was bought in the 80's to see if the clips would hold the trim tight to the truck. After temporarily installing trim to drivers door, clips were found to be correct size and held tight to body. They appear to have a fabric or foam adhered to the clip. I have 48 holes in total on cab, and 46 clips were supplied with kit.
#57 |
I know most of you have seen this in the assembly manual, but if you haven't
Good info for sure. |
#58 |
Well the clips fit good, but I was given two top rights and two bottom lefts for the back of the cab. After all of these years protecting that dang cardboard box
![]() ![]() ![]() JT from SC |
#59 |
you could 1. use a heat gun on the lexan spacer, lexan is really nice to work with heat, it turns into a noodle. this would let you run a continuous strip of tape if that were the desire. 2. you could do it the way I did it and attach the tape only in small sections. curves be damned, it would work that way. like I said, it was easier done than said, I was done with the bed in minutes once I had some spacers cut.
#60 |
I'm thinking the modern badge tape would work fine for our purposes. Even though the tape will be narrow behind this trim, the number of linear inches would be plenty I would think.
#61 |
I Think I would have Added - Thin Teflon Circles with a
Cross Cut Center with Main Vertical Cut going out the Bottom of Circle to Act as the Slip On . . .035 Material - should do it Up Fine . Would Act as a Cushion to the Steel - Quieter - and Plug the Hole .. Just a Thought . . |
#62 |
Any truck builders out there got any 55-59 deluxe cab s/s trim pieces or kit they would like to get rid of.
Thanks JT from SC |
#63 | |
Thanks to all who contributed to this thread. I'm dreading buying the wrong clips and this is helping. |
#64 |
Just today I took all the clips off my stainless. Took some pictures too. I've counted the rusty images on the back of the trim and I count 42 spots plus 2 spots for the figure 8 clips plus 2 more spots for the bolt clips that hold the trim on the door(s) for a total of 48 spots.
For what it's worth, here are some pictures.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
#65 |
I bought a taped together bundle of stainless. enough to do 3 trucks for $35 at a swap meet.
all the clips were in a plastic bag. sadly, none of the stainless is perfect, but I used a small rubber hammer and some tongue depressors taped together to massage some of them back to almost normal If you didnt look at the other side of the truck, you would think they were perfect.
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
#66 |
Reviving this thread.
I tried the aftermarket ones and they are a far cry from the original. Does anybody have any good originals?
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
#67 | |
Buy a bag of clips from Bills Trucks up here in Canada. He also sells the trim and it comes with clips, but they blow, and the clips they sell in a baggy are perfect. PM me for more info. I’m lucky to live five mins from that shop ![]() |
#68 |
I bought the ones from Bill's too, and they worked perfectly.
#69 | |
24-304-CR clip kit for cab trim–fits OE trim only (NO water seal on clip) 50 piece kit 55-59 $22.95 page 65, http://www.billstruckshop.com/Catalo...0%20Master.pdf |
