Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-02-2018, 10:52 PM   #126
Captainfab
60-66 Nut
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
PM sent
Originally Posted by Uptown83 View Post
I'm interested in this. I want to run a hydroboost setup. Wilwood booster for the clutch. It's a tr6060 transmission. Black booster. Please pm me. Thanks
Old 09-03-2018, 09:54 PM   #127
SteveA69
SteveA69's Avatar
I’m interested I have a 69 with stock booster, want to change from auto to manual thanks
SteveA69 is offline   Reply With Quote
Old 09-03-2018, 11:38 PM   #128
Captainfab
60-66 Nut
I'll send you a PM.
Old 10-25-2018, 07:12 PM   #129
SteveA69
SteveA69's Avatar
Great product, thank you! Easy to install and works perfect!
Old 10-25-2018, 11:48 PM   #130
Captainfab
60-66 Nut
Thanks for the compliment and the purchase
Old 11-15-2018, 12:57 AM   #131
67_ShortFleet
67_ShortFleet's Avatar
Originally Posted by Hinz28 View Post
Just sharing. Love these kits!! Bought my second kit from capatinFab. I have 2 trucks both 4 speed manuals. Used his kit on both my trucks. Just installed one on my 1972 Chevrolet K10 today. Here some some pictures of the kit on my 1970 C10
One last picture of what I'm doing on my K10
Love the look of that master cylinder. Is that the one that comes in the kit?
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 11-15-2018, 01:00 AM   #132
Captainfab
60-66 Nut
If you're talking about the clutch master, yes it is. Unless your particular slave cylinder or hydraulic release bearing requires a different master cylinder.
Old 12-17-2018, 11:12 AM   #133
cebra
What is the price of just a base plate setup without the clutch master and booster relocation? With the booster relocation, do the brake lines need to be rebent or replaced? I have a 71 and I read the holes do not line up so I am trying to get something as bolt-in as possible to save time on my swap. Thanks.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 12-18-2018, 12:44 AM   #134
Captainfab
60-66 Nut
If you delete the booster mounts and the clutch master the cost would be $147.50 plus $13.65 for shipping.
In moving the master cylinder much closer to the firewall, I would imagine that the brake lines will need to be bent or replaced. That is correct, the '71-'72 boosters are not compatible with any of my booster brackets without modifying the booster bracket. This is why they are not on the list of compatible boosters.
Old 01-18-2019, 12:26 AM   #135
Captainfab
60-66 Nut
The Wilwood clutch masters went up in price again, so I had to raise my price on this conversion.
Old 01-18-2019, 09:54 AM   #136
clay68c10
clay68c10's Avatar
Lucked out and found a hydroboost (77 G30), and it bolts right up to your bracket.
Score!!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-18-2019, 11:38 AM   #137
gringoloco
A guy with a truck
gringoloco's Avatar
Got mine installed, took a little more trimming of the firewall bracing than anticipated, but went together and works butter smooth...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-18-2019, 01:43 PM   #138
67_ShortFleet
I'm surprised you had to trim. Did you order the right year? I guess that bracing is different 67-72 some years.
Matt
HAPPILY DIVORCED!
Old 02-18-2019, 06:55 PM   #139
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, he warned me I might have to due the moving of the fuse box somewhere during the model years.
-Chris
Old 02-19-2019, 01:32 AM   #140
Captainfab
60-66 Nut
The '69-'72 cab is slightly different than the '67-'68 cab which requires moving the clutch master. Consequently there is some inside brace trimming required on the '69-'72 cab
Old 03-21-2019, 11:01 PM   #141
gringoloco
A guy with a truck
gringoloco's Avatar
Hey captain, the action of the linkage forces the piston to go in at a bit of an upward angle. I’ve been reading on these Wilwood girling style masters and they seem to not like being off center. Any thoughts? Anyone else had issues? I’m concerned with sealing and longevity of the part due to the misalignment.
Thanks -Chris
-Chris
Old 03-22-2019, 12:31 AM   #142
Captainfab
60-66 Nut
I am aware of the slight angle issue of the clutch master pushrod. In a perfect world, it should be perfectly straight, but this isn't always possible, especially with a retrofit situation and to be cost effective. Of the couple hundred of these conversions that I have made and sold, I have had only one report of a clutch master failure.
Old 03-22-2019, 10:07 AM   #143
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the quick reply. We’ll run with it and see what happens
-Chris
Old 05-21-2019, 07:41 AM   #144
70inbville
Can this kit be retrofitted to a Squarebody or do you make one for a Squarebody?
70inbville is offline   Reply With Quote
Old 05-22-2019, 12:57 AM   #145
Captainfab
60-66 Nut
I have no idea if it could be made to retrofit into a square body. No I do not make a hydraulic clutch conversion fro the squarebodies. I see really no need to when all you need are the factory components from a '84-'91 squarebody, which came from the factory with hydraulic clutches.
Old 05-22-2019, 07:57 AM   #146
70inbville
Thanks for the info will follow that up
Old 06-05-2019, 10:29 AM   #147
71'tahoe
71'tahoe's Avatar
Captain,
I'm a dealer for Wilwood so I don't need the master. I also have started my hydro boost swap and mine is bolted directly to the firewall so can I still order the brackets kit and associated pieces for just the hydro conversion in bare steel?
Thanks,
GT
71'tahoe is offline   Reply With Quote
Old 06-05-2019, 11:32 PM   #148
Captainfab
60-66 Nut
Are you wanting just the linkage, or do you also want the booster bracket without the booster mounts?
Originally Posted by 71'tahoe View Post
Captain,
Thanks,
GT
Old 06-06-2019, 09:06 AM   #149
71'tahoe
71'tahoe's Avatar
I will need the booster bracket with out the booster mounts and the linkage. Like the kit you put together for jlsanborn back in post #11 and #17. I'd want the bracket in bare steel.
Old 06-06-2019, 11:09 PM   #150
Captainfab
60-66 Nut
I will send you a PM with pricing and ordering info.
