Name that Miscellaneous Blazer Part
So I'm not selling anything here, but I am trying to identify some parts I have lying around. When I bought my Blazer, it came with a random box of hardware and other parts that were removed or replaced. So I'm calling all you Blazer experts to point out what I have here!
1. Top Bracket? 2. 3. Seat Belt Bolts? 4. 5. 6. 7. 8. 9. 10. 11. 12. Rear Seat Hold Down? 13. 14. Rear Seat Bolts (Back)?
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
Re: Name that Miscellaneous Blazer Part
4 is the window vent
5 is a steering column bracket 6 I believe is a side mirror gasket |
![]() Join Date: May 2011
1. Correct top bracket
2. Starter bracket 3. Correct seat belt bolts 4. Flapper for fresh air on an A/C blazer goes under the cowl on the passenger side. 5. Mounts to dash under steering column 6. Mirror gasket 7. Lug wrench and jack handle mounting hardware goes behind drivers seat. 8. Goes with 7 9. Door shim gets screwed to the door and makes contact with the bronze one on the body. 10. Hatch stop goes with number 1 11. Mirror bracket goes inside the door for the mirror to screw to. 12. Rear seat hold down 13. Tube for start wires I think but not sure if correct for first gen. blazers. 14. Seat belt bolts or possible rear seat Did I win anything LOL |
Holy smokes, Rip! Very impressive! The knowledge and helpfulness on this board is second to none. Thanks for the time!
Question. I thought both sides of the door got brass wedge plates? My blazer came with a truck door on the driver's side and possibly some other cannibalized parts, so I'm not 100% sure what's original.
#5 | |
Huh, well that explains why I only have one of the stainless plates. I'm sure the other is on the original door along with the reinforcement plate! I wish the previous owners held onto more of this stuff when the fixed it up over the years. I also wish I looked through this box and asked more questions before I bought 4 of the brass wedge plates! Looks like I'll have a few for sale. Thanks aga in Rippen.
Yep, one of the first things that sells when parting one. Seems like everyone removes the doors and doesn't strip them before throwing them out.
![]() Join Date: Apr 2006
Stainless plate? Is it under the mirror? Anyone have a picture?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#9 | |
At least I'd have a good mounting surface for my drop down power steps!
If I ever do a frame off that might be what I do. I would like to have some power steps as well eventually.
Round 2! You guys are so good, you inspired me to dig through the parts bin again to look for some other parts that I might have been overlooking. Fair warning, it appears random fasteners, clips, shims, and general garage junk may have made it in this box at the previous owners house.
15. 16. 17. 18. 19. 20. 21. 22.
I know what everything but 18 also 19 isn't oem
18 is a funny piece of sheet metal with a stud/screw in it.
Glad to know 19 is just an add on. I'm excited to find a few hidden gems in here. I'll box up all the loose fasteners and hang on to them. Already found all the jack handle clips and fasteners. Thanks!
If a had to guess I would say a fastener to the tailgate trim is it a CST?
#15 |
I don't think so, but it was totally debadged and had no original interior when I got it. The front roll cage is also preventing me from opening the glove box to see the spid! Damn PO's!
#16 |
15. Dash bezel trim for the wiper and headlight switch.
16. Radio cups 17. Radio knobs 18. Took a guess 19. Strap anchors not OEM 20. Drivers seat track catch 21. Looks like optic light that plugs into the back of the dash and illuminates the gear selector on the steering column. 22. Headlight switch |
#17 |
![]() Join Date: Oct 2015
18 looks like the stud out of a dash pad.
#18 |
![]() Join Date: Mar 2006
I think # 18 is the hardware that holds heater core assembly to the firewall.
