Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-04-2018, 12:38 PM   #1
richards72chevy
richards72chevy's Avatar
Grease gun accessories.
The rear ujoint on my 02 Silverado is a pain to grease.Does anyone here have any thing they use to get in there and grease it.
richards72chevy is offline   Reply With Quote
Old 07-04-2018, 02:00 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Grease gun accessories.
https://shop.advanceautoparts.com/p/...source=bing&ut
I have used this on different applications.
It helps if you have three hands or someone to help operate the gun while you try to depress the ball and spring.
84 Chevy K-20
Old 09-23-2018, 07:47 AM   #3
richards72chevy
I got one and it actually worked on greasing the ujoint on my Silverado.
Old 11-21-2018, 02:48 AM   #4
mikelom
I used a grease needle also. It's a bit PITA to use but it works.
mikelom is offline   Reply With Quote
Old 11-21-2018, 02:50 PM   #5
sweetk30
sweetk30's Avatar
different uses but they also make a slide on 90* head for tight spots .
but the needle type adapter shown above is the ticket to u-joint greasing jobs .
and when changing u-joints try and plan ahead on zerk fitting position . i set them up so there facing the drive shaft tube NOT the axle u-joint yoke . and also clock them to match so you dont need to roll the shaft to hit the next one .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
