Old 04-01-2019, 02:48 PM   #1
bigmoe
bigmoe's Avatar
Odd bracket behind cowl extension?
They were on my parts truck (65 C10) but not my original 65 GMC.
bigmoe is offline   Reply With Quote
Old 04-01-2019, 04:49 PM   #2
jbgroby
jbgroby's Avatar
Re: Odd bracket behind cowl extension?
ITs a needed braket to stop airflow. your should NOT be bent upwards, they lay flat.
jbgroby is offline   Reply With Quote
Old 04-01-2019, 05:44 PM   #3
bigmoe
bigmoe's Avatar
Oh I see. The cowl extensions were already removed when I got the parts truck. Probably supposed to have some rubber attached to it?
Old 04-02-2019, 08:58 AM   #4
jbgroby
jbgroby's Avatar
You can use a 1/8" think piece of stiff rubber and glue it to the underside and fit it in place to stop the water and dust from getting under the hood.
Old 04-02-2019, 07:44 PM   #5
damnyankee36
damnyankee36's Avatar
My 66 originally didn't have rubber on them. No staple holes either. I wonder if it was later model year change...
damnyankee36 is offline   Reply With Quote
Old 04-07-2019, 08:50 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
that is called the Debree Tray Uts keep big Tash like paper or tree branches from going down into the Fender crevice. It kinda works but I see a lot of people remove them
stsalvage is offline   Reply With Quote
