Old 04-16-2019, 08:21 PM   #26
1967KaiserM715
1967KaiserM715's Avatar
Re: 1986 Chevy K30 CUCV/M1008 rebuild
Amazing how slow things go, and how nothing gets done, because you misplace that one tool, that you normally get several of... clutch alignment tool. I just did one last year, no clue where I put that tool...found the box though.
Anyways, flywheel installed and torqued to 110ft-lbs.
1967KaiserM715 is offline   Reply With Quote
Old 04-20-2019, 07:16 PM   #27
1967KaiserM715
Pressure plate on, new throw-out bearing, transmission and engine installed.
Some clearance issues with the headers. Not sure how I will proceed just yet.
Some accessories installed, I used a fan clutch from a 6.2 diesel, I'll see how it works out.only the later 292(1982+)had these clutches. I'm using a turnbuckle to adjust alternator tension, I will need a stud on the water pump to finish install.
Old 04-22-2019, 05:42 PM   #28
obijuan
Sweeeeet. Got excited to see a k30. Then a 292. Then alpine green. Then an nv4500!!
Subscribed af.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 04-25-2019, 08:43 PM   #29
1967KaiserM715
Got some work done on exhaust, prying and heating wasn't working, so cutting torch and grinder came out, all tube seperated, #1 and #2 tubes sat fine when set in place, #3 there is many issues...first was the tube was physically 3 inches longer then #1and #2...so some bending and cutting-all tubes same length, and no contact issues now.
I also had to grind some of the exhaust flange to clear the Offenhauser intake... but now it's almost ready for a carburetor. Distributor is in, need some bolts for the valve cover, and PCV/breathers. I have a new fuel pump ready for install...might be able to make some noise soon.
Old 06-09-2019, 07:55 PM   #30
1967KaiserM715
Been a while, had to tweak the exhaust a little bit, the flange was in a poor spot and could not get a reducer in place. Now I'm ready to finish the exhaust system, and get the intake back in place.
I also started going through the axles, rear had all new brakes previously installed- I did replace one wheel seal. And all the studs on the drivers side-the originals were either worn or had rusted, didn't feel safe using them either way.
Been very busy with work, and doing some house searching.
Old 06-29-2019, 09:43 PM   #31
1967KaiserM715
I decided to do a rear mount gas tank. I am using a 31 gallon blazer tank. By moving the rear crossmember all the way back, the tank will clear the right rear shock mount. Ground clearance isn't compromised much with a hitch. But I plan on a skid plate at some point.
I also scored a CUCV brush guard for cheap.
Old 06-30-2019, 01:15 PM   #32
MTCK
MTCK's Avatar
Looks good! Assume you’re ditching the saddle tanks? My 292 wouldn’t make it very far with 31 gallons but I bet yours is quite a bit better with the 4500.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-30-2019, 06:27 PM   #33
1967KaiserM715
Thanks!
Yeah, because I put in 64" rear springs from a later style 1 ton truck, I would only have been able to do a 16 gallon side tank, and because I didn't have any 16 gallon tanks, and I would want 2 of them it was cheaper to figure out a rear tank. I paid $167 for the 31 gallon, sender and straps-including shipping.
I would have done a 40 gallon tank, but the right rear inboard shock would have interfered with the larger tank. If I remember, the 40 gallon was 4 inches longer and 1 inch deeper.
Old 06-30-2019, 09:13 PM   #34
farmall
farmall's Avatar
I have never heard split exhaust routed to the right and left on a Chevy 6 before. What are your plans on routing?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 09-08-2019, 01:14 PM   #35
1967KaiserM715
Sorry, just saw this, been way to busy with work, and then managed to get an infection in my knee, which made me a complete cripple for the last 2 weeks (I could not put any weight on my knee).
Anyways, I plan on dumping the exhaust right in front of the drivers rear tires. Keeps it short and I don't need to find the angles to get over and around the fuel tank. Nice and simple for now.
I managed to get the rear half of the frame painted, and finalized the fuel tank install, now I am ready to route fuel and brake lines.
Old 09-08-2019, 01:20 PM   #36
1967KaiserM715
I also had an adapter machined to fit the offenhauser intake and converts directly to a Jolley 2 barrel, this makes it much easier then using 2 or 3 adapters to get from the offenhauser to 2 barrel. I need to modify the power steering bracket I made, it's a tight fit, and I'm hitting someplace that isn't allowing the bracket to sit correct.
Old 03-01-2020, 01:05 PM   #37
1967KaiserM715
Been a while since an update. Engine is pretty close to being finished, had to custom fabricate a power steering pump bracket, tensioners installed for alternator and PS pump. Also picked up a 8ft stepside bed, will need to widen either fenders or bed itself, and add inner fender tubes to help clear the inner rear dual tires.
Old 03-22-2020, 08:39 PM   #38
1967KaiserM715
Getting some work done, making the step bed 4 inches wider, scored a set of brand new fenders with the marker lamps(73-78 style). Two of the pictures show before and after fender coverage of the rear dually tires.
Can't figure why the pictures uploaded sideways or upside down.
Last edited by 1967KaiserM715; 03-22-2020 at 08:42 PM. Reason: Tried fixing pictures.
Old 03-23-2020, 12:53 PM   #39
1967KaiserM715
Trying to show rear fender coverage better, and some of the parts I widened installed. Running several ideas on how to do the tailgate, wouldn't mind getting rid of chains, so I could widen the gate 2", and build some post/pockets... or just widen gate the 4 inches, not sure yet.
Old 03-25-2020, 04:19 AM   #40
MTCK
MTCK's Avatar
Great progress. I think it would look cool to have the narrow box and bigger fenders but probably a lot more work too.
-Marcus
Project Plow Truck
Old 04-02-2020, 10:12 PM   #41
duallydude63
i have a 63 on a 73/87 frame i jst widen the fender by 4 inches !!!
duallydude63 is offline   Reply With Quote
Old 05-03-2020, 09:29 PM   #42
1967KaiserM715
That was my original plan, but didn't like the look of the wider 73-87 style fenders. So I went the more difficult route.
Not much to report, been busy, house hunting, prepping the 8ft bed for paint for my other square, fixing up the Honda 250 3 wheeler. Also found a nice set of rock sliders for my other truck-I plan to use as steps, but excellent start. Plus weather has been all over the place.
But I scored a nice set of clifford shorty headers, these fit 10 times better, no massaging of pipes to fit, no grinding, just plopped right on, no mess, no fuss. I've been hoping to drag the truck into the garage so I can start ordering brake parts, just want to make sure I dont need bearings or kingpins as well.
Pictured is rock sliders, 2 angles of the Clifford headers, and the screw up I did on the 8ft bed that I'm fixing...got distracted and put an extra coat on, so the paint ran, finally getting around to fixing and respraying.
Old 05-05-2020, 12:14 AM   #43
farmall
farmall's Avatar
I would love to hear what those pipes sound like exiting each side.
