05-14-2019, 06:00 PM | #1 |
Re: Grandpa's 72 restoration
Thanks for the insight and pointers. Yes doors shells are original to truck and were fit prior to final welding of the cab sheet metal. The window frame could have gotten tweaked a little while I was working with it, moving it around, etc. I think I can finesse it enough for proper gap. The new skins and bottoms measure exactly the same as original measurements before I cut them up. Door skins went on great, fit like a glove. Kinda weird.
Like MDPotter mentioned, I think the door bottom profile / angle is off a little bit. I think I can work the metal up enough to clearance the rocker, its only like 1/8" or 1/4" of contact. Otherwise I'll just cut the door bottoms off again and scoot them up. Probably trim up bottom skin 1/4" too. Easy enough to do, just time. And I'd rather work the door again than the rocker. |
05-28-2019, 10:55 AM | #2 |
Got my doors pretty close this weekend. Open and close great now, gaps are ok and have enough adjustment to get them nearly perfect. I had to cut 3/16" off the bottom door skins to clear rockers and get a good gap. I don't have the rolled over skin on the bottom now but tack welded the skin and inner door bottom together, I don't see a huge issue with this, may try seam sealer over the welds. Will probably weld 1/8" rod to front of both door skins to close the large fender/door gap.
Bent the passenger window hoop backwards, grinded the sharp corner off the hoop where it meets the wing window, hammered the door bottoms for clearance in a few spots where it was contacting the rocker. Had to bore out the hinge bolt holes where they mount to cab for more adjustment. Also straightened the rear lower driver door skin to match the cab corner contour. The fenders mount up well but appear tilted forward. Lifting up the front of the fender gives me the good gaps to the door, will shim up the core support a little to help this. Lower rear fender bolt holes do not line up with cab mount support but I can make that work. All in all, most of the tough fitting is done...I think... |
05-28-2019, 10:58 AM | #3 |
ugh sorry about the turned pics...
here is the passenger side, still too tight around window frame but it opens and closes without contact top or bottom. |
