06-20-2019, 03:52 PM | #1 |
Looking for 67 - 70 drag link
I am in need of a 67 drag link. Does anyone have one they would be willing to part with?
Update: 67 - 70 1/2 ton drag link is what I need. Thank you! Last edited by mike88a; 06-20-2019 at 06:18 PM. Reason: update |
06-20-2019, 05:09 PM | #2 |
Re: Looking for 67 drag link
For power steering or manual? Thanks
06-20-2019, 05:30 PM | #3 |
I have one off a 70 manual steering c30. According to my catalog at Napa the pitman and idler are the same as a 67 c10 and the tie rod ends have the same taper and size. I’d do $30 plus shipping.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
06-20-2019, 05:36 PM | #4 |
06-20-2019, 05:38 PM | #5 |
My limited understanding from the research I have done it that the 67 through 70 and 1/2 ton only.
06-20-2019, 05:59 PM | #6 |
When you said you had an 80s front end. What all is late model and what’s 67 still?
06-20-2019, 06:53 PM | #7 | |
Hope that makes better sense. |
06-21-2019, 12:02 AM | #8 |
Well I have a drag link then if you want it. The only thing if I were you that I would want to verify is what tie rod ends you have. Being they are spindles for a late model the tie rod end should be different, unless a conversion sleeve was used or something. If you have aftermarket conversion spindles with late model rotors and calipers then that would make sense why you still need the 67-70 drag link. Just trying to help you so you don’t purchase something you can’t use.
06-21-2019, 12:36 AM | #9 | |
THANK YOU! |
06-21-2019, 11:52 AM | #10 |
Using the size and weight in my history from the last one I sold. $55 to your door. Still need to take it off.
06-21-2019, 01:36 PM | #11 | |
Thanks again for helping! |
06-21-2019, 06:54 PM | #12 |
Notta problem at all. Main thing is the site and info helping with the truck
06-21-2019, 09:10 PM | #13 |
Do you already have all the other steering parts??/ Check the on the center link and the spindles, to make sure everything you have fits...these deals can be work, I'm not entirely I am following what all you have for parts. Not trying to be a Beavis, just helpful. My 67 is getting different steering stuff, different from even, yours!!! LOL...
