#126 |
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Thank you, sometimes I miss the big things because I am looking for the fine print!!
#127 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Curious as to what would the other 2 digits denote if there was a 14 digit serial number on a 1967 GMC?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#128 | |
Its not that simple, In a nutshell the big differences are an added GVW range as a suffix, two digit wheelbase, two digit model and a four digit serial. To see the differences clearly just go to the begining of this thread and compare the 67 GMC to the 12 digit 67-71 Chevrolets. In 72 Chevrolets used a 13 digit VIN with an added maunfacturer digit.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#129 |
Junior Member
![]() Join Date: Dec 2017
Can anybody help me to decode this vin?
1C154L113981 its on a 60 Apache, here in Germany. What I found: 1 = 1961 C = 2WD 15 = 1/2 ton 4 = Pickup L = (found Los Angeles but not for this year)# 113981 = ser. number 3981, but that be? Could this be real? thank you for your help. Joerg. |
#130 | |
CHEVY/GMC VIN DECODERS |
#131 |
Junior Member
Thank you for the information.
I have a title which shows built in 1960 but the vin says 1961. Can you explain how this works? https://photos.app.goo.gl/RN7dwK3aTkBuMW2K2 regards Joerg. |
#132 |
Jogre, that's pretty common. 1961s were built from August 1960 to July 1961. So a early 61 build is often titled as a 1960. Or if a late build sat on the lot till 1962, and then sold it could get titled as a 1962.
#133 |
Junior Member
Thank you for this information.
Joerg |
#134 |
Junior Member
Another question. How can I identify the colour, engine and tranny of this old one?
#135 |
Joerg, Start a thread in the 60-66 section. Here's a link.
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=6 The guys in that section can answer your questions better than me. Also ask them about your L= Los Angeles assembly plant code. And don't forget to include a pic of your truck. They love pics.
#136 |
Junior Member
Thank you, I'll do after it arrived this weekend...
#137 |
Can anybody help me to decode this vin? PB1001NC2 For a GMC Value Van 1965 I think
#138 |
Hello All
I have a 1972 GMC 5500 grain truck and want to know if its a 3 ton or a 5ton The vin is TCE53WV508362It is a Canadian truck with a GVW of 20000-24000 lbs |
#139 |
I made the discovery today that my '72 burb has two different VINs. One on the glove box, one on the door jamb. I imagine this happens from time to time as these old vehicles use parts from donors to be restored?
I guess my question is which is more accurate? Any opinions? VIN = glovebox: CKE162F145864 door: CKE262F143439 C = Chevy K = 4WD E = V-8 1 = 1/2 ton | 2 = 3/4 ton 6 = Suburban 2 = 1972 F = Built in Flint Michigan 145864 | 143439 serial number |
#140 | |
![]() Join Date: Oct 2015
6 LUG OR 8 LUG? Door jamb is probably correct Have you verified the rear axle has a locker in it? or front? I really want to believe that the person typing up the VIN on the SPID was just extremely hungover and screwed up, but there are too many numbers off. Shame really because that's a highly optioned truck. I hope its just a mistake. |
#141 |
6 lug. The front wheels have locking hubs. I guess I don't know how to tell if the rear differential is a locker.
#142 |
#143 |
not my pics, but photos of my vehicle posted by others (before my ownership in 2011) I have made some mods since purchase
https://www.youtube.com/watch?v=SZHcWFrI1AQ (private owner selling the old girl) and https://www.mecum.com/lots/SC0511-10...olet-suburban/ (Mecum listing that didn't apparently reach reserve.) Last edited by iriereggaeman; 02-22-2019 at 09:12 AM. |
#144 | |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#145 |
Still looking for one that includes the bigger trucks. EM 4640M C1303D Cowl and chassis like for a school bus (this is a linen truck)
#146 |
Getting ready to buy a 1972 GMC Sierra Grande, the vin is
CE234-S132178 Reading the decoders the 4 in CE234 should indicate Model year.....this is a 1972? |
#147 |
![]() Join Date: Oct 2009
#148 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Bruce this is a great resource I've relied upon many times. Thank you.
I'd like to add that Blazer VINs for the 1969 model year begin with "B". Here's a link to an example on the K5 SPID thread (where several others are documented): http://67-72chevytrucks.com/vboard/s...&postcount=370 EDIT: Is there a chance you know the assembly month for a 1971 model year Blazer assembled in Flint with a sequence number of 654572? Prior to 71 all K5's were assembled in St Louis and I'm curious in what month Flint began K5 assembly. As I don't see many 71 Flint K5s I suspect is was later in the model year.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-04-2019 at 12:05 PM. |
#149 |
Deadhead, thank you for the props. We're glad you are finding the decoders useful and very pleased at the number of people that have found the resource useful.
We knew about the Blazer VINs when we put the decoders together but left it off to save space. It was just the one year and only on Blazer models, so we figured not enough affected to include it. We kept to the essentials so that the characters and boxes could be as big and readable as possible. We also left out things like the starting sequence number of 800001 for the 1969 model year and 600001 for the 1971 model year. But your absolutely right, First year Blazers had a B for Blazer as the first Character of the VIN. As far as your 654572 Blazer build date. Lucky it's a 1971. I can only do this for 1971. Any other year and we would have to do it the hard way. Checking blue door stickers, Engine date codes etc. against the VIN number in a made/collected database. But for 1971 I have some documentation from GM that helps a lot. Your Flint Blazer 654572 was built on assembly line 2 on June 17th 1971 give or take a day or two. I estimated the date. All I really know is that the last light duty truck built in flint, line 2, in May 1971 was 649411. And the last LDT built in Flint line 2 in June 1971 was 658369. Hope that helps and thanks again for the props. Bruce
#150 |
Carpe manana
Amazing! Thank you sir! Confirms my suspicion. I'll keep an eye out for additional 71 Flint K5s but of those so far documented (total 4) all were assembled in June of 71. Perhaps a trial run ahead of the 72 MY when Flint figured prominently in K5 production.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
