Old 09-01-2019, 07:44 PM   #276
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Ol Blue K20 View Post
I'm getting a little excited to see it done. That burger looks great. I'm having a tri tip sammich on a ciabatta roll. Mmmmmm
MmmMmm...goood
fishnixon is offline   Reply With Quote
Old 09-02-2019, 11:26 AM   #277
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Dumptruck Dolly
Originally Posted by fishnixon View Post
I might be ready. You never know when it’ll come in this neck of the woods.
If you can, send me a picture of the tool you mentioned.
It hooks under the edge of the arm and then you just work the arm up and it pops off. Should be able to find one at napa or similar.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-02-2019, 02:19 PM   #278
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks Too Much Stuff...I’ll have to look into it.
Old 09-02-2019, 03:51 PM   #279
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I have to say that I’m impressed the original flooring has held so well in its previous farm life.
Old 09-02-2019, 04:02 PM   #280
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
In my previous post (find the double burger) I mentioned removing the roll pin on top for the 4 speed shifter...DON’T DO IT!!!...
Here’s the right way...
1. I had to use a little lubricant to get the top to depress down against spring pressure...you may not have to. Note the opening where shifter goes in, is positioned straight ahead.
2. Get over the top of the silver ring and press down hard!
3. When you get it pressed down, turn an 1/8th turn counter-clockwise. See red arrow. Again, normally the opening you see is positioned straight ahead.
4. Remove shifter
5. Plug up the hole on top the trans to keep debris from getting in.
Old 09-02-2019, 07:01 PM   #281
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Bottom half is ready, I think...speedo cable, u bolts, trans mount bolts, motor mount bolts. Hopefully, tomorrow afternoon allows me to yank it out.
Old 09-03-2019, 10:09 PM   #282
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
That was a workout...thanks to my son and my brother, I was able to get the 292 and the trans out as one unit. Doing this while keeping the riveted transmission crossmember in was accomplished by disconnecting the rag joint, unbolting the front cab mounts, and simultaneously jacking up the front of the cab just a few inches. (I had enough slack in the brake lines) After that, it was just a wrestling match the rest of the way. I’ll clean up the tools tomorrow...but for now, I’m calling it a night.
Old 09-03-2019, 10:42 PM   #283
Getter-Done
Getter-Done's Avatar
Re: Dumptruck Dolly
Wow.
Great progress.
I like your shop and your strategy of the project.
84 Chevy K-20
Old 09-04-2019, 12:09 AM   #284
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Getter-Done View Post
Wow.
Great progress.
Thanks regarding the shop. Living in Northern Minnesota (and I do not hunt) I have to have somewhere to go and work, especially in the winter.
...regarding the project, I’m trying take a little section at a time, and enjoy the success of the moment. Thanks 👍
Old 09-15-2019, 07:08 PM   #285
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I siphoned the brake reservoir in preparation to disconnect the brake lines. I didn’t want brake fluid all over the place.
Old 09-15-2019, 07:26 PM   #286
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I marked the engine mounts... I don’t want to guess what they are on the “next” project.
Old 09-15-2019, 07:40 PM   #287
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Another milestone...
Old 09-15-2019, 07:51 PM   #288
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Some scraping, some grinding, and liberally spraying brake cleaner to clean and dry the metal, I sprayed my favorite rubberized sealer on the frame...now I am pumped up...after the frame dries, I think I’ll clean up the firewall.
Old 09-15-2019, 08:08 PM   #289
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Dumptruck Dolly
Looks good, progress is always good....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 09-15-2019, 08:17 PM   #290
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks Ol Blue...👍
Old 09-15-2019, 09:41 PM   #291
rustytruck50
rustytruck50's Avatar
Re: Dumptruck Dolly
Thats one of the nicest dump trucks in this era that I've had the pleasure of seeing!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 09-15-2019, 09:55 PM   #292
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you!
I do have some ideas on where I want to take this truck regarding looks, etc...but I have to remind myself about the initial goal of “keeping it in a functional mode”, and not tear this down so far that it’s not useable for long periods of time... Stay tuned
Old 09-16-2019, 11:24 PM   #293
Average Joe
Average Joe's Avatar
Re: Dumptruck Dolly
Looking good!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 09-17-2019, 12:36 AM   #294
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Average Joe View Post
Looking good!
Thanks!
Old 09-20-2019, 09:17 PM   #295
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Maybe a minor detail, but I’m documenting the original scribed numbers from the assembly line.
Old 09-20-2019, 09:41 PM   #296
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Using aluminum foil again, I prepped the firewall for paint. Prior, I used a wire brush on a drill to scuff up the paint. I used rubberized sealer below the cab seam and used black hammered paint for the rest. I find that this hammered finish covers a multitude of blemishes and is a great finish when you’re going to change colors later on. I’ll use this on the inner fenders and fender wells.
Old 09-20-2019, 09:49 PM   #297
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
My son came into the garage last night and cleaned up the trans and transfer case. After masking today, he sprayed multiple thin coats of Chevy Orange. I like it!
Old 09-21-2019, 08:24 AM   #298
Getter-Done
Re: Dumptruck Dolly
I like the Hammer finish paint.
I have used it before but not on trucks and cars Looks great.
Your moving right along.
84 Chevy K-20
Old 09-23-2019, 12:22 AM   #299
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks...I am now starting to look at removing the E-brake stuff and the leaf shackle mount points.
Looking at your profile, I see you had a 1963 Impala in high school. I bought one as a sophomore and spent the next three summers working on it. My first day on the road with it was October 2, 1984...I was a freshman in college. Here’s a pic of my SS.
Old 09-23-2019, 07:24 AM   #300
Getter-Done
Re: Dumptruck Dolly
I still got it. Bought it when I was 15.
That will be my next (make over) project.
Mine is a 2 door hardtop Impala.
I also like the Orange on the trans and transfer.
What transfer case is that?
84 Chevy K-20
