09-14-2019, 02:24 PM | #1 |
Prothane T/A bushing install help
Seeking some advice from the ones who have used the Prothane trailing arm bushings. I have the one side fully seated but the piece that is added to the opposite side is to long. Hopefully the pictures explain better. What has everybody done to alleviate this issue?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 09-14-2019 at 03:30 PM. |
09-14-2019, 07:50 PM | #2 |
Re: Prothane T/A bushing install
Right or wrong, unsure at this point but the only logical solution was to reduce the height of the bushing. So that’s what I did.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
09-16-2019, 07:53 AM | #3 |
When I did mine I just beveled the inside of the bushing to clear the weld. They make them the correct length they just don't account for the weld.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-16-2019, 09:14 AM | #4 |
Thanks Jimmy. Too late for that now, but that is probably the better option. I couldn’t force the bushing over that lip, I tried. The bushings do not have much give to them.
09-16-2019, 09:37 AM | #5 |
Active Member
Is there a front and rear kit available or are you buying individual components for the components you're upgrading?
I'm already replacing shocks, springs, panhard bar, and upgrading/adding sway bars front and back, so it might be a good time to update all the bushings and stuff at once. |
09-16-2019, 10:19 AM | #6 | |
Prothane Bushings Brothers offers these like the originals. Rubber bushings
09-16-2019, 10:38 AM | #7 | |
Active Member
My trailing arm bushings are shot, so I have to assume it's all shot, front to back. (I'll try to snap some pics in a bit as I go through mine today.) I've used the poly bushings in the past (pretty much on everything) and realize they're more firm than oem, but I'm counting on the fact that my current setup is so bad that switching to fresh poly pieces will still be a much improved ride. Right now, these cut coils and blown original shocks are kidney breakers. |
09-16-2019, 11:14 AM | #8 | |
09-16-2019, 06:15 PM | #9 |
Delrin lined spherical bushings would be best.
The rubber on the original bushings is part of what allowed the OE truck arm arrangement to function within the binding limitations designed. When we start stiffening them up using boxed/tubular aftermarket structure & poly bushings, it makes things (binding) worse. If you want to 'tighten-up' the factory truck arm rear suspension & you're replacing the worn rubber/steel sleeve bushings, swap in a bushing that doesn't allow slop but also allows for articulation: https://www.hotchkis.net/product/196...rt-suspension/
09-16-2019, 06:42 PM | #10 | |
09-16-2019, 06:48 PM | #11 |
Active Member
Great find, man!
They're expensive, but I have a sneaking suspicion that they're totally worth it. |
