![]() Join Date: Sep 2017
Serpentine belt systems
I don't have a lot of room between the radiator and the crank in the 48 on the S10 frame, and I need some of that room for the electric fan.
There are a lot of serpentine belt systems out there, and I was looking at one when I saw it was 8" from the front of the pulleys to the tip of the crank! That won't work for my truck. So does anyone have a recommendation for what they used that took up minimal room, maybe 4"? If you have done this set up, how much room did you have between the back of the radiator and the end of the crank? Maybe I need to start over and move the motor back some.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
Re: Serpentine belt systems
I used a system off of a V6 1989-90 Firebird. My passenger side valve cover is 1 inch from the firewall. The electric fan motor just barely misses the fan pulley bolts, but it all works. Good luck.
A lot of guys like the setup off a 4.3 V6. Same front end of the engine as a small block that has all the bolt holes for brackets.
That is one thought though, as you have to make sure what ever you get you get a setup that is compatible with your engine. They "they are all the same" doesn't apply when trying to bolt pieces for a mid 80's 350 on a mid 60's 327.
Thanks Joe. I may have to scrap the 283 as I don't know the year. It looks in pretty good shape inside - I took it apart again, but not knowing the year makes getting anything to fit it problematic.
I don't have an S-10 frame, but used the brackets from the 88-92 Camaro/Firebird. Even with the stock frame it was a little tight. I had to cut off a couple of pieces the plastic guard to clear the fan pulley.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
Thanks.
Jan, I'll take "barely" it's "uh oh" that worries me. I was looking at a serpentine kit until I read it was 8" from the tip of the crank to the outside edge of the kit. I do not have that much room without the fan.
I have SBC 350 with serpentine set up from S10 4.3 V6. This is on an S10 chassis. Still in construction mode, but looks like it will all fit. Long water pump for SBC is about 7" out from the front of the engine block at the pulley end, so the pulleys on the serpentine system will be around 7 to 8.5" from the front of the block.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
I'm not a V8 guy but my crank was made for SBC damper. The spacers are in there for crank trigger. The outside of the pulley is about 2" from the crank snout. I'm having a SFI damper made with serpentine pulley on it. Then crank trigger 3/8", 3" blower pulley and dry sump oil pump pulley 1". It's still only about 5.5" in front of crank snout. I have electric P/S and A/C.
Mick53 I'm a little jealous of that engine.
8man do you have the accessory holes drilled in your heads?
1950 Build |
1950 Build |
And see post 12 I think on this one. I've had these saved. Keeping an eye out for one too.
http://67-72chevytrucks.com/vboard/s...d.php?t=233335
1950 Build |
Wait till you see my 12 port cross flow aluminum head. The one on there is a race head I had made before I knew I could get the other one. It's the first of it's kind from New Zealand. About 10 years in R&D. Thanks.
Thanks Matt. Yes the heads do have some holes, but one of the articles you sent me has a reference guide to determine year by hole pattern. I tried searching several different ways, and I didn't find either of those articles. My search function skills are worse than my welding!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 Last edited by 8man; 10-30-2019 at 09:12 AM. |
#15 |
![]() Join Date: Sep 2016
Check my build thread. I went through similar issues with finding a serpentine systems. I'm pretty sure I just went with a 1995ish and cobbled the parts from craigslist. Didn't end up being terribly expensive just make sure the pulley system is from the same vehicle. There are a few configurations. I probably have half an inch between the electric fan and the water pump pulley
An example... https://www.ebay.com/itm/SERPENTINE-...Condition=3000 Wasn't in my build thread ![]() Try this thread when I was pi$$ed off at my accessory drive... http://67-72chevytrucks.com/vboard/s...d.php?t=747312
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride Last edited by gigamanx; 11-07-2019 at 09:28 AM. |
#16 |
Thanks Gigamanx. That helps.
#17 |
8man, How did you solve your accessory drive system space issue? I'm at same point. I installed a GM performance system but it left me short of room for the fan and barely enough for the radiator.
#18 |
I went with the KWIK performance system. It uses the Sanden mini compressor and mounts very close to the crank. Just enough room after I had the inlet on the bottom of the radiator turned down on a 45.
#19 |
Thanks! Do you know the distance from block face? Can you send me a product link?
#20 |
is that a short reverse rotation water pump sytem?
#21 |
http://www.kwikperf.com/
Here is the link. Yes on the water pump. I'll have to go measure from the block to the radiator.
#22 |
If you unbolt the water pump, and measure from the face of the block where the bolt hole is to the radiator, it's 9.5".
Does that help?
#23 |
Yes. Thanks for your trouble and the info! How much clearance did you end up with in the end between you drive system and fan?
#24 |
1/2" or so, maybe a little more. I've held the fan up, but not mounted it yet and so I don't have a really accurate measurement, but it's enough to clear.
#25 |
Great! I was afraid I would have to go with a push fan. Thanks again for your help! The one upside to all that's going on is I have time to work on my truck. Stay safe!
