11-09-2019, 12:38 PM | #11 |
Re: HP Tuners Tutorials - Part VIII - Turn Off Cat Correction & Over Temp Protection
Next go to Engine \ Spark \ Advance \ Catalyst Heating click on the Startup Correction button which will bring up the table and zero it all out, every cell should say "0".
You can do it manually jumpinng from cell to cell with values different from 0 and typing 0, or you can click in the upper left corner of the table to select the entire table (similar to Excel), then use the menu bar to type 0 and press the = sign to zero them all out at once, you decide, ha ha. the colors in the table will change to show you what's changes, but after you save it it should go back to being all one color Last edited by Gregski; 11-09-2019 at 12:47 PM. |
