Old 10-28-2019, 11:04 PM   #1
Mike1965
Mike1965's Avatar
1965 C20 LWB Flatbed Restoration
I've been meaning to post this build thread for a while now. I am now finally getting around to doing it. Here is my 1965 C20 Flatbed build. I picked this truck up last year in August.
My plan for this build is to restore it back to original with period correct mods done to it. I have already got a lot of work done to it so far.
Mike1965 is offline   Reply With Quote
Old 10-28-2019, 11:07 PM   #2
Mike1965
Mike1965's Avatar
Re: 1965 C20 LWB Flatbed Restoration
Here are some pictures of the brakes getting rebuilt. I picked up an original power brake booster for it also. I forgot to take pictures of the disassembly of the front sheet metal. But I'm sure all of you have seen that many times before, so you are not missing out on much.
Old 10-28-2019, 11:13 PM   #3
Mike1965
Mike1965's Avatar
Here are some pictures of the original 283 v8 getting rebuilt. The truck also came with the optional Powerglide transmission (I'm also getting that rebuilt).
Old 10-28-2019, 11:16 PM   #4
Mike1965
Mike1965's Avatar
Here is some pictures from when I tore down the cab and took it off the frame. The PO had welded a terrible bumper on the rear that had to be cut off. I am going to be reworking the flatbed when the time comes to do that. I am going to get the frame powder coated semi gloss black for that brand new look.
Old 10-28-2019, 11:20 PM   #5
Mike1965
Mike1965's Avatar
I got the rear shear type cab mounts rebuilt by Steele Rubber Products. Here is the link to the thread I made about these cab mounts. http://67-72chevytrucks.com/vboard/s...ght=shear+type
Old 10-28-2019, 11:28 PM   #6
Mike1965
Mike1965's Avatar
I got the original 17.5" x 5.25" steel wheels for this truck. I got them powder coated so they will hold up for a long time. Also I just had to try them on before I get the rubber for em.
Old 10-28-2019, 11:31 PM   #7
Mike1965
Mike1965's Avatar
I checked in on the cab today that is at the body shop right now getting all of the metal work done. They completely stripped the cab down to bare metal and powder primed it to seal it while they do the metal work. It looks amazing even though it is just in primer.
Old 10-28-2019, 11:56 PM   #8
Mike1965
Mike1965's Avatar
Here is the original red bench that it came optioned with.
Old 11-03-2019, 12:59 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Awesome build! Can't wait to see more.
Old 11-03-2019, 03:39 PM   #10
Mike1965
Mike1965's Avatar
Thanks man! Glad you like it!
Old 11-10-2019, 11:26 PM   #11
Mike1965
Mike1965's Avatar
Here are some progress pictures of the frame tear down.
1965 C20 LWB Flatbed Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=795718
Old 11-21-2019, 04:15 AM   #12
Mike1965
Mike1965's Avatar
I got my engine and transmission back from the engine rebuilder. It looks amazing, it is like is just came off the assembly line. I can't wait to slap it into the frame.
Old 11-21-2019, 04:24 AM   #13
ElReeso
One good looking Project! Alot of Money and time invested!
ElReeso is offline   Reply With Quote
Old 11-21-2019, 05:35 PM   #14
Mike1965
Mike1965's Avatar
Thanks man! I'm trying to build this truck right and that does take a lot of time and money, especially patience too. Glad you like it.
Old 12-05-2019, 04:38 PM   #15
Mike1965
Mike1965's Avatar
Here is some more progress being done to the frame.
Old 06-03-2020, 12:49 AM   #16
Mike1965
Mike1965's Avatar
Here is a picture of the frame after powder coating. I'll have more pictures when I start reassembling it.
Old 06-03-2020, 01:01 AM   #17
Mike1965
Mike1965's Avatar
Sheet metal repair started on the cab.
Old 06-03-2020, 01:03 AM   #18
Mike1965
Mike1965's Avatar
Here are some pictures of the rocker replacement.
Old 06-03-2020, 01:05 AM   #19
Mike1965
Mike1965's Avatar
Here are some pictures of the roof replacement. The front corner on the passenger side had some rust holes in it. It was easier to replace the whole cap and sound proof it while it was off.
Old 06-03-2020, 01:09 AM   #20
Mike1965
Mike1965's Avatar
Here are the holes cut out for the factory AC. The radio is not being shaved, it was just filled in cause someone put an aftermarket radio in it. The factory radio is going back in.
Old 06-03-2020, 06:48 PM   #21
cwcarpenter98
cwcarpenter98's Avatar
Lookin' good!
Did you use panel bond to attach the new roof skin, or did you weld it back in? I'm going to be pulling the roof skin off my truck and I haven't decided on how I want to attach it back
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-03-2020, 06:58 PM   #22
Mike1965
Mike1965's Avatar
Originally Posted by cwcarpenter98 View Post
Lookin' good!
Thanks! Glad you like it. I'm having the sheet metal work done by M & J Performance out in Apache Junction, AZ. https://m.facebook.com/pg/MJPerforma...ernal&mt_nav=0 He "spot" welded the skin back on.
Old 06-03-2020, 07:10 PM   #23
cwcarpenter98
It looks like he is doing a very nice job. I just hope that my attempt at fixing the rust will look at least half as nice
Christian Carpenter
Old 06-14-2020, 04:49 PM   #24
Mike1965
Mike1965's Avatar
Here are some pictures of the start of the big back window conversion.
Old 06-14-2020, 04:51 PM   #25
Mike1965
Mike1965's Avatar
Here are some more pictures. These show the sound deadening being applied on both panels. The fit and finish of this brand new big back window panel is really nice.
