Old 04-30-2019, 01:53 AM   #176
68Timber
I know the pieces fit
68Timber's Avatar
Re: Naught's 82 2wd K5 Blazer
Removing the B pillar seam between the cab and bed rails looks really good.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-30-2019, 11:14 AM   #177
82Diesel
Holy crap man! I'd love to do a full restoration like that on my 1982 K10... but I don't have a shop and they are crazy expensive near me to rent.
Maybe someday.
1979 Pontiac LeMans 231/Th350
1982 Chevrolet Silverado K10 6.2 Diesel/700r4
1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare)
1991 Chevrolet Silverado K2500 5.7/700r4
1999 Chevrolet Base LS K2500 6.5TD/4L80e
82Diesel is offline   Reply With Quote
Old 05-02-2019, 11:15 AM   #178
Dads79GMC
Dads79GMC's Avatar
Loving the color.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 07-19-2019, 04:23 PM   #179
Naught
Naught's Avatar
Added some shine to it!!
Naught is offline   Reply With Quote
Old 07-19-2019, 06:55 PM   #180
SCOTI
SCOTI's Avatar
PoP!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-20-2019, 07:46 AM   #181
Hammered 77
Hammered 77's Avatar
Just read your build thread again, awesome work!
Rick
Hammered 77 is offline   Reply With Quote
Old 09-30-2019, 09:33 AM   #182
Naught
Naught's Avatar
Thanks!
Old 11-26-2019, 04:53 PM   #183
Naught
Naught's Avatar
Body is back on frame!!
Old 11-26-2019, 05:03 PM   #184
Naught
Naught's Avatar
Trying to figure out wheel offset.
Old 11-26-2019, 06:37 PM   #185
SCOTI
SCOTI's Avatar
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-03-2020, 04:14 PM   #186
Naught
Naught's Avatar
Trying to get interior and wiring together.
Old 01-03-2020, 04:18 PM   #187
Naught
Naught's Avatar
Also have received my rear wheels!
Old 01-03-2020, 05:26 PM   #188
tinydb84
tinydb84's Avatar
Man that looks good!
David
Instagram: myfabguy
Old 01-03-2020, 05:53 PM   #189
SCOTI
SCOTI's Avatar
x2!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-03-2020, 06:43 PM   #190
lolife99
67-72 parts collector,…
lolife99's Avatar
Wheels look good,... but look really close to rubbing.
Did they arrive with the backspace that you ordered?
Keith
Convert to disc brakes.
Old 01-04-2020, 11:06 AM   #191
Naught
Naught's Avatar
Thanks! Yes they are close but are exactly what i ordered. We have around 5/8 clearance.
Old 01-04-2020, 11:07 AM   #192
Naught
Naught's Avatar
Thanks!
Old 01-04-2020, 11:07 AM   #193
Naught
Naught's Avatar
Originally Posted by SCOTI View Post
x2!
Thanks!
Old 01-08-2020, 10:57 AM   #194
rodstored-72
chevy truck fan
rodstored-72's Avatar
Naught,
terrific build! I like the detail. I am in the process of building up a Daily driving 1986 swb. I have a few questions for you if you don't mind. I was wondering if you would share (remember) what brake prop valve you are using?was it a "direct replacement"? also I would like to know what radiator you decided on? Finally I am wondering if you had to modify the frame any for your exhaust? I am using the DD mounts on my build. thanks for any input you might provide. I like the color choice too!!!
thanks!!
Rodstored-72
rodstored-72 is offline   Reply With Quote
Old 01-08-2020, 03:20 PM   #195
Naught
Naught's Avatar
Originally Posted by rodstored-72 View Post
Naught,
thanks!!
Rodstored-72
Hope this helps.
I ordered the complete front & rear brake kit from CPP and it came with the proportioning valve with it. It is a OEM style proportioning valve but it is for disc brakes on front and back (disc/disc).
Griffin Radiator Combo Kit
(Radiator & Fans)
Yes we did. Look on pages 2 & 3 on this build for pics. I couldn’t get the exhaust out the back with the trailing arm coilover suspension plus the fuel tank so we boxed in the frame and went threw it to get on the outside to go out the back.
I also used DD motor mounts
Old 01-09-2020, 10:32 AM   #196
rodstored-72
chevy truck fan
Naught,
thank you for the replies, and it does help. I mainly wanted to verify that I was not the only one that had to modify the frame for this type of install. I believe "glock" had to as well back when he did his, he used custom mounts-reason for verification. I ordered a "std" brake prop valve (disk/drum) and wanted to see if it was similar to yours. I am still not sure what to do about radiator.... here in the desert the heat is a huge concern. I believe these new motors require more cooling than a regular SBC. I am looking at a few from Summit that are "designed" for LS conversions, so again just wanted to check with a few knowledgable members here.
thanks again & best of luck with the build finish!!
Old 01-09-2020, 02:59 PM   #197
Naught
Naught's Avatar
Naught,
NP..... Yes the radiator I have is for a LS conversion, both hoses are on the same side so the water passes thru the radiator twice and has the steam port on it.
Old 01-16-2020, 11:24 AM   #198
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Wow! Those wheels look great under there! Amazing body and paint work as well!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-25-2020, 11:03 AM   #199
lukeembry
Looks great
lukeembry is offline   Reply With Quote
Old 02-03-2020, 10:53 AM   #200
Naught
Naught's Avatar
Thanks!
