Old 01-12-2020, 06:42 PM   #451
UK62LW
UK62LW's Avatar
Re: faux-tina paint jobs
Originally Posted by kensblue64 View Post
The piece in the pics is a glove box, from a 48 Ford truck.
It took about 2 minutes to do, and cost about 25 cents to faux patina.
Wow, nice job! Please share your technique..!?
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
1987 Peugeot 205 GTi
1991 Peugeot 205 GTi
UK62LW is offline   Reply With Quote
Old 01-12-2020, 09:02 PM   #452
kensblue64
BEWARE !! BEFORE anyone tries this technique, you are one your own !!!! This has worked well for me, but your results may not turn out to your liking !!!
I will not assume any liability for your results.
ONLY use this process if you present paint work is not satisfactory to you, as there is no going back.
Lightly scuff up the panel with 600 grit sandpaper, dry sand the entire panel (no water) with heavier pressure on areas that would normally rust first, do not wipe down, only gently blow off the excess with an air gun from about 4 feet away, this will clean off most of the dust, leaving some dust to get integrated into the upcoming paint to give somewhat of a texture like a light rust.
Then lightly mist the entire panel with lacquer thinner from a spray bottle, let it dry on the panel
Time spent so far on a complete bedside will 15 minutes tops !
Next stand about 2 1/2 to 3 feet away, and lightly mist on a very , very faint coat, like a guide coat, of flat black paint, remember only a very light coat, so it will dry almost on contact.
This should only take 3 minutes or less.
Now you are almost done with the panel and you have less 20 minutes and than 75 cents invested.
Now the MAGIC
Rustolium spray paint (Aged Metallic rust) in a spray can # 285072.
They make a few similar shades, but the Metallic Rust color looks best.
Before you spray the rustolium, do not shake the can, turn upside down, and press the button about 10 tp 15 seconds, to release some of the propellent, and thinner from the can.
I know what you are thinking, "won't that make the paint partially clog up the nozzle" well you would be right, but that is exactly what you want, to simulate natural rust. Also the spray nozzle on this Metallic Rust can, is not like the standard nozzle, it is really bad. you can never get a nice splatter free uneven coat if you try.
Actually the more it splatters from the can, the worse it gets, what is exactly what you want, so simulate a natural rust.
DO NOT SHAKE THE CAN at any time, spray the liquid rust onto the panel at various distances, to produce heavier coats on areas that would naturally rust the heaviest.
Go light at first, as you can go over an area again to apply more paint.
When the sputtering is worst, that is perfect to apply the paint.
This stage should cover the entire bedside in only 5 minutes, and use 1/4 to 1/2 of the can.
Let the panel dry, and the next day scuff lightly with a 3m pad, to flatten off some of the sheen.
MIST VERY LIGHTLY WITH LACQUER THINNER, let dry, and you are done.
Total time 25 minutes, with the total cost about $3.00 for half a can of paint.
Most of the sheen will flatten out in a few weeks in the sun.
You can do your entire truck for less than $50.
My liking is to spray the entire panel with a medium coat of rust paint, from about 2 feet away, so that most of the original color still shows underneath.
Next I go in closer about 1 foot away, to re-spray areas where natural rust would be heaviest.
Good luck
When I do my blue truck, I'll post a video.
kensblue64 is offline   Reply With Quote
Old 01-13-2020, 12:18 PM   #453
forestb
forestb's Avatar
do you have a photo of your friends ford?
forestb is offline   Reply With Quote
Old 01-14-2020, 10:36 AM   #454
sstock
sstock's Avatar
I plan to patina my entire truck for $50.00 to $75.00.
I will be able to complete the entire job in about 8-10 hours, outside, on a nice sunny day.
My friend & I completed a patina job on his 48 Ford truck, and it is simple, and looks authentic.
My truck looks nice about 15 feet away, but most of the panels, fenders, box, and tailgate are have a lot of bondo, from previous owner. They look presentable, but require a lot of work, before spending any money on proper paint.
I plan to drive the truck this coming season ( I live in the Northeast PA)
so the season runs from mid April thru mid October.
Then I will order new boxsides, front bed panel, wheel housings, and tailgate.
If I have any money left, I'll order a new hood, and new fenders, as well.
I don't weld or do body work, so I figure that with the high price of labor, it will be cheaper to order rust-free repro panels, than have them done in a body shop.
My friends truck looks Old School patina, and he has no plans to change it, it really looks good.
The last pic is how my truck looks right now.
Very interesting Ken, please keep us up to date when you do this.
Subscribing.
Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 01-19-2020, 11:43 PM   #455
60chevyjim
60chevyjim's Avatar
the glove box looks great , I tried to find this color local , but I ended up getting it on ebay. I plan on using it on my 65 c10 rat ,and my chopped top 50 f car
the 65 is spray canned satin green with zero prep . it was black with horrible paint and bodywork when I got it. i put the rusty hood on it.
60chevyjim is offline   Reply With Quote
Old 01-23-2020, 03:04 PM   #456
kensblue64
Now the MAGIC
Good luck
This just keeps getting better.
As I said in a previous post I Plan to faux patina my crappy paint job, until I can buy new sheet metal to properly have my truck painted in a year or two.
I plan to permanently change the color of my truck from the current blue to Rally Red.
Previously I played around with the blue color, so I decided to actually use the rally red color, and see how it turns out.
Wow I am happy.
First I had a bunch of joist hangers left over from a backyard shed I built last summer, so I thought I would use them for my latest experiment.
I sprayed two coats of the red, and let it dry for about 2 hours, and then sprayed the "rust in a can" over the red, and let it dry overnight.
The next day I sanded it lightly with 1000 wet dry, and this is how it came out.
The pics with 2 hangers, show the original shiny red paint on top, and the finished result underneath.
Any comments would be welcome.
Old 02-01-2020, 07:53 AM   #457
richards72chevy
richards72chevy's Avatar
richards72chevy is offline   Reply With Quote
Old 04-07-2020, 12:41 PM   #458
cgster
A lot of good faux-tina paint jobs on this thread. Are any of you applying any kind of clear coat afterwards?
cgster is offline   Reply With Quote
Old 04-08-2020, 08:26 AM   #459
spudder
Active Member
Here is one that a friend owns. He is doing a mild drop and several other mods this spring. Going to 5 X 4 3/4 bolt pattern so he can run any of many GM wheels. I think it is going to be a slick driver.
spudder is offline   Reply With Quote
Old 04-08-2020, 05:56 PM   #460
theastronaut
theastronaut's Avatar
I bought a '69 that had mostly original paint but needed a fender, hood, and cowl. The new fender already had black primer, and the hood was painted black first then green to match the original primer color. I soaked a rough terry cloth towel in lacquer thinner to rub the paint off the high spots before the paint set up all the way.
theastronaut is offline   Reply With Quote
Old 04-08-2020, 07:30 PM   #461
69Tom
69Tom's Avatar
Great looking truck. Which I could have kept mine in the as-is paint, but had too much damage to the metal and was a (old) re-spray anyhow.
69Tom is offline   Reply With Quote
Old 05-07-2020, 07:22 PM   #462
Asshat
Asshat's Avatar
Lots of good info in here. Mine has a pretty good start, I think, just need to figure out a way to "touch-up" ther areas that need attention.
Wondering if a fresh coat on the just the grill would enhance the look.
Asshat is offline   Reply With Quote
Old 05-08-2020, 12:21 PM   #463
youngrodder
youngrodder's Avatar
Wow I am happy.
Thanks for your write up. I plan to do this to my Suburban. This is rusted primer. I would like to add some color then enhance the rust to smooth it out. I will probably add some air brush work to also enhance the effect. Looking forward to your video..
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-03-2020, 01:24 PM   #464
youngrodder
Here's a few afters of my Suburban using the prescribed technique
Marc
Old 06-03-2020, 01:28 PM   #465
youngrodder
More pics
Old 01-12-2021, 09:43 PM   #466
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-04-2021, 12:04 PM   #467
LostMy65
LostMy65's Avatar
I went and picked up some diesel to get some burn piles going. An older guy pulled in with a shiny older jeep. He said if I gave my truck a nice paint job, it would be a really sweet ride. I said, but then I'd have to worry about it. He smiled and said good point.
Old 05-16-2021, 12:32 AM   #468
LostMy65
LostMy65's Avatar
Found this in another thread.
I like both with and without clear.
Old 05-20-2021, 10:35 AM   #469
tazattitude
tazattitude's Avatar
I just finished this one a few weeks ago.
Stripped, bodyworked, 2K primed and patina'd it
basecoat/clearcoat
More pics
https://www.attitudecustompainting.c...l_suburban_c10
video of the paint job process
https://youtu.be/RRo0P_K0jyM
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 05-20-2021, 11:41 AM   #470
SCOTI
SCOTI's Avatar
^^ Awesome! ^^
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2021, 07:38 PM   #471
AcampoDave
AcampoDave's Avatar
Wow, Taz...nice job. One of the most natural looking ones I've seen. I bet that took way more time that just doing a straight forward paintjob.
AcampoDave is offline   Reply With Quote
Old 05-22-2021, 09:13 PM   #472
Asshat
Asshat's Avatar
Should I just start sanding to get rid of the cracked look of the paint? That’s probably the quickest, right?
1963 C20, small window, long bed
292, 4-speed
Old 05-22-2021, 09:14 PM   #473
Asshat
Asshat's Avatar
basecoat/clearcoat
More pics
Yeah - that is pretty nice!!
292, 4-speed
Old 05-23-2021, 12:48 AM   #474
caseyjones
I wouldn't touch it. That looks cool.
caseyjones is offline   Reply With Quote
Old 05-23-2021, 01:45 AM   #475
LostMy65
LostMy65's Avatar
I agree, your truck is a natural:
