Old 02-02-2020, 09:51 AM   #1
Zippi
Zippi's Avatar
*Rear Splash Apron*
Anybody install one of these? I'd like to see pics and I assume it is held on by the rear bumper. Not sure what the holes and notches are far though.
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 02-02-2020, 11:33 AM   #2
joedoh
joedoh's Avatar
Re: *Rear Splash Apron*
that is a GMC front splash apron, the notches are for the grille surround and the holes are for the grille mounting on a 1947/early 1948 grille which was different.
this is a rear apron.
https://www.chevsofthe40s.com/detail..._Suburban.html
Old 02-02-2020, 04:50 PM   #3
Jemezcrusher
Yep. The rear does not have holes or notches and is after market and not an original item. Fits 47-53 only. Would require modification to fit 54-55 be cause of the license plate recessed lip on those bumpers
Jemezcrusher is offline   Reply With Quote
Old 02-02-2020, 07:09 PM   #4
Zippi
Zippi's Avatar
Haha....you guys are right. I posted the wrong pic. Now it should be the correct one.
1949 5 Window 3100
Old 02-02-2020, 10:44 PM   #5
Jemezcrusher
I have the same thing. Mine will require some trimming on the forward edge as it does not follow the same line as the fender.
Does a nice job of filling the big gap between the bumper and the bed
Old 02-03-2020, 02:37 AM   #6
mr48chev
mr48chev's Avatar
Looks like my photobook page is back up so I'll try this and if it doesn't work I'll go the other way.
My ongoing truck projects:
Old 02-03-2020, 02:39 AM   #7
mr48chev
mr48chev's Avatar
That was on this cutie hiding out in the cheap seats at the East West Flathead reliability run a few years ago.
Old 02-03-2020, 07:53 AM   #8
Zippi
Zippi's Avatar
Nice. How does it fastened on?
1949 5 Window 3100
Old 02-03-2020, 01:59 PM   #9
jweb
jweb's Avatar
The rear splash apron uses the bumper bolts to attach but it's unlikely it will fit as well as the one in mr48's photo. I had to add 1/2" to mine to make it come close to the fenders.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 02-03-2020, 04:21 PM   #10
mr48chev
mr48chev's Avatar
That photo was the result of a second take oh wow moment when I did see how well that one fit. I was planning one similar until I found my 49 Plymouth surburban wagon rear bumper to go with the ribbed 49 Plymouth front bumper. .
Old 02-04-2020, 08:11 AM   #11
jackson
I used the front bumper and apron on the rear tucked it in closer to bed and made some small bed extentions behind rear fender to hide bumper brackets
jackson is offline   Reply With Quote
Old 02-04-2020, 01:28 PM   #12
Jemezcrusher
It may depend on where you get them. I actually have to trim the forward edge when it meets the fender as mine is too long. Got mine from Brothers for 139 I think as LMC or o there’s were 159 or 179. Can’t remember
Old 02-04-2020, 01:42 PM   #13
Zippi
Zippi's Avatar
Thanks for the info guys.
1949 5 Window 3100
Old 11-14-2020, 09:30 AM   #14
Zippi
Zippi's Avatar
Ok guys, it's been a while and I'm back on the idea of wanting to put a rear splash apron on my 49. I'm looking at the one from Brothers as mentioned. I'm just wondering if I bought this apron, would I be able to prime it, then get a rattle can made up at my local automotive color & supply store with my paint code and paint it to make it look presentable? Also, I think my rear bumper is a 54 so not sure if it would work anyway. Anyone used a rear splash apron on their truck with a 54 bumper?
1949 5 Window 3100
Old 11-17-2020, 02:02 PM   #15
jweb
jweb's Avatar
The 47-53 splash apron won't work with the 54 bumper unless you flip the bumper over.
You may have to move your license plate also.
If you don't want to flip the bumper, you might consider just pulling the bumper in closer and adding a roll pan to clean up the look. I know I have seen it done and it looks good. Hopefully someone can add a photo that shows a roll pan/ bumper combo.
Old 11-20-2020, 03:43 PM   #16
MiraclePieCo
MiraclePieCo's Avatar
Turn bumper over and tuck it for a cleaner look:
https://www.youtube.com/watch?v=XxHbuD9XLDo
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-21-2020, 08:12 AM   #17
Zippi
Zippi's Avatar
Nice info guys. A new bumper is $170 at Classic Parts so for me this is still doable just not right now. I guess I could sell my 54 bumper and re-coop some of the money. This will be going on the back burner for a while.
1949 5 Window 3100
Old 11-21-2020, 10:52 PM   #18
MiraclePieCo
Panel trucks and Suburbans came with a factory filler panel on the rear bumper. Anyone try to adapt one to a pickup?
Old 11-22-2020, 09:26 PM   #19
mr48chev
mr48chev's Avatar
The shape is all wrong for a pickup as the panels and burb use pickup front bumpers on the rear.
I wouldn't turn the bumper over although I have seen a couple of guys do it and then run the exhaust pipes out close to center.
I'd go along with looking at tucking the bumper in and maybe up though. That may take nothing more than marking and drilling new holes for the bumper bolts
I don't know if it is camera angle but this bumper in a Jim Carter tutorial appears to have the bumper a lot closer to the bed but maybe not higher .
The article is here http://www.oldchevytrucks.com/Articl...ear-Bumper.php
Old 11-22-2020, 09:31 PM   #20
mr48chev
mr48chev's Avatar
Comparing the two I wonder if maybe you can't just slide your bumper brackets forward on the frame a bit and get the bumper closer to the plate and bed like the one Jim Carter shows is. Maybe by moving the back bolts to the hole further forward on the frame.
Old 11-22-2020, 09:44 PM   #21
mr48chev
mr48chev's Avatar
A couple of more shots that make it look like 54 bumpers are for some reason closer to the bed
Old 11-23-2020, 05:00 AM   #22
MiraclePieCo
My '50 PU with a trimmed, flattened, and tucked FRONT bumper on the rear. The center bolt is the giveaway.
Old 11-23-2020, 09:01 AM   #23
Zippi
Zippi's Avatar
Thanks for the tips guys. I may take a look at what it would take to move the bumper closer to the bed.
1949 5 Window 3100
Old 11-23-2020, 11:49 AM   #24
Tempest67
Tempest67's Avatar
Miracle Pie - where did you put the tag ?
Tempest67 is offline   Reply With Quote
Old 11-23-2020, 03:09 PM   #25
MiraclePieCo
It's right in the center below the bumper. It's just edited out in that pic (note the blurring).
