Old 02-09-2020, 02:28 PM   #26
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Will 15" x 10" wide rim with 4" backspace fit with stock rear?
Originally Posted by goatless View Post
Here's mine with 15x10, 325 50 15 Nitto drag tires. BS is 6.5". Wheels from Wheels Vintique. Probably could have done just 6" BS, or an even wider wheel.
Man! I've always liked the look of the fleetside without a tailgate or bumper.
Nice shot. Good rake.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-10-2020, 07:27 PM   #27
goatless
goatless's Avatar
LOL, thanks! No front bumper, either.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 02-10-2020, 07:32 PM   #28
88Stanger
88Stanger's Avatar
goatless
That is a nice ride with a good amount of rake. I am happy to hear this about the rims, that is almost exactly what i want. Thanks!!!
88Stanger is offline   Reply With Quote
Old 02-10-2020, 08:23 PM   #29
SCOTI
SCOTI's Avatar
Originally Posted by 88Stanger View Post
goatless
But..... How much drop are you intending to have since your plan is to 'bag' the truck?
If you drive it low (more than a typical static coil w/block drop) & need the wheel opening lip trimmed to ensure clearance, the seam between the upper/lower bed half is @ the same dimension. You can't just roll it for clearance so it becomes more work required.
Like I stated about earlier responses, what might work for one truck might not for another based on what parts are used & how low/what the owner considers low. Based on the trucks I've done, this truck has a very mild drop & not what I would consider a 'bagged' ride.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-10-2020, 08:25 PM   #30
SCOTI
SCOTI's Avatar
These are what I consider 'bagged' ride heights.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-10-2020, 09:34 PM   #31
goatless
goatless's Avatar
I went and installed long-tube headers recently, so it's not going to get any lower for now.
MECHANIC: "ME"
Old 02-10-2020, 11:35 PM   #32
LostMy65
LostMy65's Avatar
You're as low as I'd want to go.
Old 02-11-2020, 10:47 AM   #33
88Stanger
88Stanger's Avatar
Scoti
I think i may be close to those heights, maybe not that low because (I could be wrong) i think to get that low you really must do some drastic changes on the from cross member. I am leaving the front cross member as is but installing tubular upper and lower a-arms cupped for bags and the rear i am c-notching it, but not to an extreme.
Old 02-11-2020, 12:50 PM   #34
SCOTI
SCOTI's Avatar
Scoti
Blue truck has a OE front x-member from what I remember. It was possibly pancaked but it was not an aftermarket unit.
The math can be done to get a better 'guess' of possible interference.... How tall of a rear tire is in the plan?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2020, 01:15 PM   #35
SCOTI
SCOTI's Avatar
Originally Posted by Captainfab View Post
The stepsides have less room for tire and wheel than a fleetside. You will not be able to use a off the shelf 10" wide wheel on a stepside with a stock width differential, if it is lowered.
Originally Posted by Todd46
Thanks for asking the question. I'm looking at the same size rims on a 62 step side.
Thanks Captain! I appreciate all the information you share
Todd46, you could do an easy(ish) mini-tub & fit 10's but would still want 6"bs so things clear. I've sold multiple sets of fleetside wheel tubs to step-side guys. Center & set them in place against the bedside wall & floor to mark the area the wood floor needs to be trimmed back. trim the floor. Mark & drill some holes. Some cutting & drilling & bolt the tubs in. You do lose bed space so 4x8 sheets of plywood would have to ride on top of the tubs but your truck can still do truck stuff.
Wheel Vintiques does custom back space set-ups for $25/wheel on top of their regular price (they did this for me in 2018).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-12-2020, 10:17 AM   #36
88Stanger
88Stanger's Avatar
Scoti
Honestly, i am not sure yet. I am not set on any size really, not to tall, yet not to little. I know that is could be a wide number, but i am also looking at maybe running 18", 19" or 20" even, but the part i really am sure about is the 10" width.
By the way, thanks for your time here.
Old 02-12-2020, 01:17 PM   #37
LostMy65
LostMy65's Avatar
This thread can be helpful for deciding on size:
http://67-72chevytrucks.com/vboard/s...d.php?t=379110
Old 03-02-2020, 10:54 AM   #38
88Stanger
88Stanger's Avatar
So here is the Rims i am looking at.
Ridler 695 Series Matte Black with Machined Lip Wheels 695-8973MB - Summit
They are 18" Rims and 9.5" Wide with 5.5" Back spacing. After all that i have read here and the research i can do, i still am nervous if these will fit. I think they will, just not sure how close to the outer fender i will be. Modifying the inside fender and bed are not a concern, just if it will hit the outer fender.
Old 03-02-2020, 03:02 PM   #39
SCOTI
SCOTI's Avatar
With those numbers, hitting/rubbing on the outer edge of the body shouldn't be an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-02-2020, 04:31 PM   #40
88Stanger
88Stanger's Avatar
Thank you Sir, that is what i think also, but i just wanted another opinion.
Old 03-02-2020, 04:34 PM   #41
88Stanger
88Stanger's Avatar
For the Fronts now. Would the same 20"x 9" Rims with 5.5" backspace work?
Old 03-02-2020, 06:20 PM   #42
SCOTI
SCOTI's Avatar
Fronts get harder to assess. A 9" wheel w/that much back-spacing/offset is going to crowd things on the a-arm side of business. Disc brake spindles widen the track width. CPP's 'Modular' spindles are supposed to maintain drum brake hub track widths. Point being, the spindle used can change the dimensions so everything needs to be known for calculating & considerations.
What spindles?
What a-arms will be used? Are they narrowed vs. stock?
What tire size?
5.50"bs is aggressive up front. Watch-outs would be possible/probable a-arm, sway-bar, & possibly the frame or shock interference.
Beyond that, the visual aspect needs consideration. The track width is impacted by wheel width & back-spacing. You'll want to know where you are for one end to "match" the opposite end appropriately. 'Too narrow' of a front track width w/a rear track width that is as wide as allowable (because of sheet metal) may not 'look' right (or good). The opposite is true as well.... a narrower rear foot print vs. the front looks awkward & not well planned.
Bottom line, more info needs crunching before saying yes/no to your proposed combo working.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2020, 10:29 AM   #43
88Stanger
88Stanger's Avatar
What spindles?
What tire size?
Thank you sir for your time on this, i really appreciate it. I am not taking a closer look at what i will use. After reading this, i think it is better that i go with 8" rims up front, but i will need to look at what is offered. In the next week or so i will be ordering a set, when i get a good idea what i would like for sure, i will throw it on here and see what you think.
Again, thanks.
Old 03-18-2020, 08:28 AM   #44
88Stanger
88Stanger's Avatar
Ok, i am ready to buy rims and after much consideration, i think im going with a set of "20 x 9" and 4.75" backspace for the rears and then for the fronts 20"x 8.5 and 3.75" backspace with low profile tires. These are transit style rims offered by summit. I want the raw ones then i will powder coat them black with the edge coated white.
Thoughts?
Old 03-18-2020, 10:22 AM   #45
SCOTI
SCOTI's Avatar
Thoughts?
Unfamiliar w/the wheel choice.
Personally not liking the BS listed on the front option but it would likely work/function.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-19-2020, 12:45 AM   #46
88Stanger
88Stanger's Avatar
Thank you for the feedback. My issue is they offer the 20" in those sizes.
My spindles are 2.5" cop, I'm running tubular upper and lower control arms for bags, stock size but upgraded 1972 front disc conversion.
Old 03-19-2020, 09:46 AM   #47
SCOTI
SCOTI's Avatar
This is why I stick to steelies & 15" tires. Most mass produced wheels that are affordable have very generic sizing. They work on vehicles that are close to stock height but not so much on anything beyond.
My estimate is you're front wheels will be similarly placed as the ones in the pic from Post #18-19...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-22-2021, 05:13 PM   #48
joesscamaro
I have a question related to the original post and didn’t want to create a new thread. I figured it could help being here. I’m trying to buy wheels for my ‘65 and need to take the proper measurements first. Problem is, I don’t have brakes yet due to the fact that I don’t know if I can fit the wheels I want on my stock width 12 bolt. If I can, I’ll buy disc brakes for the 12 bolt and take my measurements. If not, I plan to buy a narrowed 9” and buy brakes to fit. I’m new to this, so how do I figure this out?
joesscamaro is offline   Reply With Quote
Old 07-22-2021, 09:58 PM   #49
SCOTI
SCOTI's Avatar
Ok.... Lots of unknowns.
Let's start w/what you want (what you're wanting to accomplish)? Is there a certain look you want? Certain diameter?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-23-2021, 06:38 AM   #50
joesscamaro
For the rear I'm wanting to go with the Raceline Classico in a 20x14 with the MT Sportsman SR 29x15 tire. I have disc brakes on the front already and can get the measurements I need...so I'm not too concerned about that. Mainly talking about the rear.
