01-24-2020, 07:34 AM | #26 |
01-24-2020, 07:38 AM | #27 |
Got the cab back tacked on in a few spots.. don’t quite know if it’s exactly where it should be so leaving it tacked until further progress is made.. re hung the pass side rear door checking gaps... got the rounded piece in the door as well. Got glass window run channel installed and threw the window in to make sure it still works properly..
Posted via Mobile Device |
01-24-2020, 07:42 AM | #28 |
Kinda at a standstill with the passenger side so onto the real work.. drivers side. Got to working on the B pillar. Man I didn’t realize all the work that would go into this. I don’t think I’m a 1/4 way done yet but satisfied with the work so far.. getting itchy to start the 4th door but patients is key... sorry if the pics are sideways
02-03-2020, 12:14 PM | #29 |
Finished up the drivers side B pillar. A ton of work involved in this and many hours but pleased with the outcome.. got it all ground and sanded down. Still have some cleaning up to do but it’s tome to start on a door...
02-03-2020, 12:16 PM | #30 |
Starting on the fourth door.... not much progress. Just working on getting the inner door section and hinge area figured out. Figured I’ll reskin the door once completed
02-11-2020, 03:27 PM | #31 |
More door progress pics..
02-11-2020, 07:27 PM | #32 |
Re: 1972 Chevy Crew Cab “Denali”
Nice work on all of it .
Good clean lines Especially that 4th door. I like your path with the 4th door. .
02-11-2020, 07:33 PM | #33 | |
02-20-2020, 05:12 PM | #34 |
Been pecking away at the door... got everything working correctly internally. Modified both window channels and got all lock linkage figured out. All the pieces for that came from a third door as well. Door hinge reinforcement is done... took everything back apart and finished all welding on the door inner. Got a new door bottom in as well.. laid down some rust inhibitor on the inside of the door.. need to get some primer and seam sealer on the inner and it’s time for new outer skin and about to close up the door for good! Finally
02-20-2020, 05:14 PM | #35 |
Took a break from the door as I’m tired of seeing doors and door pieces.. PO cut out the dash for an aftermarket head unit and that can’t stay in there. Plan on running a factory AM/FM so I cut up a diner dash panel and welded that in. This also gave me my center AC hole. Just need to cut outer holes for vent balls...
03-30-2020, 12:46 PM | #36 |
Finished up the new reskin on the fourth door and it came out better than I expected... been working on the floor lately in hopes of mounting to the chassis to complete rockers and cab corners and supports...
03-30-2020, 12:47 PM | #37 |
Starting to work on the rear floor as well. Hand to get another doner cab to get front bench seat mounts.. I had the pieces but wasn’t thinking and scrapped them.. oh well 40$ cab is shot but it came in handy
03-30-2020, 12:50 PM | #38 |
03-30-2020, 12:54 PM | #39 |
Starting to get chassis ready for new cab. All new lift springs and shackles. Went with a 4” lift. Also completed a shortbed conversion on a longbed. Bed was a little rough but using it for mock up right now at this point I plan on building a new bed with aftermarket parts down the road when paint is near.. for now this will do the trick and I enjoyed doing it. Not welded solid only tacked ever 1/4” or so
03-30-2020, 03:00 PM | #40 |
Almost Satisfied
This is very cool to watch....I wouldn't or couldn't do it, but fun to watch...keep posting progress. I love it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
03-30-2020, 03:07 PM | #41 | |
03-30-2020, 09:45 PM | #42 |
Great pictures and documentation of your build
Nice work. .
03-31-2020, 07:34 AM | #43 |
03-31-2020, 07:44 AM | #44 |
Figured since the cab is stout enough to lift again I can start preparing to mount on chassis. Now that I have a shortbed that will help me figure where and how much to add. First I removed the front most bed mount. Then I measured my shortbed k10 frame from center of front bed mount to center of cab mount. I ground rivers off of the rear cab mounts and moved them back according to my k10 measurements... Next would be to measure center to center on cab mounts on crew cab and compare on frame to see how much I need to add. Came out to be 20 3/4” I needed to add. I got doner frame rails from a 1967 c20.. did some cross measuring on frame and a lot of bracing before cutting. Did a simple 6” stair step notch with reinforcement plates on back side. Welded them solid with two plug welds per plate. I also used run off tabs at each flange so I was getting full penn welds by the time I got to frame rail..
03-31-2020, 07:48 AM | #45 |
With this corona virus going around most the places around here are feeling the effect but my company is still working 10 hours a day. Well spent 10 hours on Monday second guessing my frame lengthing.. So I was on a mission to set the cab on it’s new home. I set the front of cab down first and got both mount bolts in place. Rolled to the back and the rear mount bolts threaded right in barely any effort so my frame modifications were spot on.. Couldn’t be more pleased now it’s starting to look like something. This is where I’m at currently...
03-31-2020, 11:24 AM | #46 | |
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-31-2020, 11:30 AM | #47 |
04-01-2020, 08:15 AM | #48 |
Threw a front clip and hood on I had laying around and pushed it outside to stand back and look. WOW looking like a truck now.. of course I had to throw some hooks and k20 hub caps on it for a quick picture...
04-01-2020, 12:25 PM | #49 |
It's going to be awesome.
04-01-2020, 04:59 PM | #50 |
Almost Satisfied
Hard to take back apart once they look like a truck, but it is very motivating. Looks great. I want one!! Are you going to try to keep the truck roof profile or the burb?
