Old 03-25-2020, 10:19 AM   #51
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 1972 Chevy K20 Extended Cab Cummins Build
Getting it figured out.... that's half the fun!
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-28-2020, 09:40 PM   #52
1972_K20
today we got the door latch pocket tack welded on in the correct position and the weather stripping lip from the rear of the passenger side cut and re shaped to fit the front of the drivers side.
1972_K20 is offline   Reply With Quote
Old 03-29-2020, 06:31 PM   #53
1972_K20
got the upper door jamb spot welded in and working on the lower pillar, almost done.
Old 03-30-2020, 10:32 PM   #54
1972_K20
today I worked on the various puzzle pieces that will be welded to the 4th door pillar to match the passenger side, I hope to be tacking them in tomorrow
Old 04-01-2020, 08:27 AM   #55
ShortbedClayton
Your making super fast progress on your post. Looking factory to me. I love seeing how different peoples approach to making this pillar are. Keep up the good work. Took me about two weeks to make my post... hours of welding ahead of ya..
ShortbedClayton is offline   Reply With Quote
Old 04-01-2020, 11:09 AM   #56
1972_K20
yeah its getting really close to being able to be welded, the latch mechanism will fit and work in the current state but to make it the same as the other side I need to sink the pocket into the post another 1/8th.
Old 04-02-2020, 10:33 PM   #57
1972_K20
Got the rear of the pillar tacked in place and the latch pocket moved back where it needs to be.
Old 04-03-2020, 09:50 PM   #58
1972_K20
Got the bump out on the pillar tacked on today, feels good when stuff fits like its supposed too.
Old 04-04-2020, 10:12 PM   #59
1972_K20
today we got the pillar welded in and the temporary latch for the drivers door made and installed so it all works, tomorrow the plan is to get the suburban cut off and the back of the truck cab put on
Old 04-06-2020, 10:52 PM   #60
1972_K20
Sunday we got the suburban back off and the truck back sat on, the nest step is to mount the rear to the cab
Old 04-07-2020, 09:39 PM   #61
1972_K20
got the cab sitting in a more correct position, had to cut out the window track as expected and lined the drip rails up with clamps
Old 04-09-2020, 04:10 PM   #62
locrwln
Amazing work.
Jack
locrwln is offline   Reply With Quote
Old 04-19-2020, 10:06 PM   #63
1972_K20
got the rear cab tacked to the suburban, we made an 8 inch long inner support manel to tie the two together and even with a few welds seems very strong, the mock window pillar is also welded in until we use a full other pillar to weld into the door like the original, the two line up real well. mucking up the cab corner to make sure everything fits an then lock down the drivers side so we can make that door. also I buffed out the original Ochre door that will contribute to the fourth door to look at it in person. I was set on blue but I have always liked the yellow and I think that is the direction I will go, with the white top and no trim.
Old 04-19-2020, 11:20 PM   #64
Getter-Done
Getter-Done's Avatar
Looking good.
Great progress.
I like that Ochre color also.
84 Chevy K-20
Old 04-20-2020, 06:52 AM   #65
72 tigger
72 tigger's Avatar
That color will look good. Nice progress! What’s the white stuff on the green grass?
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 04-20-2020, 06:16 PM   #66
1972_K20
Yeah it was 78 one day and snowing three inches the next, crazy weather
Old 04-21-2020, 10:49 AM   #67
71blksuper4x4
SWB 4x4 Collector
Looking good!
TREVOR
Old 04-21-2020, 11:02 PM   #68
1972_K20
got the drivers side cab corner on and looking good, the rocker is just screwed in place. the passengers side cab corner was welded on but the corner didn't fit right and tapered in on the bottom, after checking the contours of another cab we realized they both should be the same and the passenger side is not, most likely it was twisted while doing the drip rails. we just need to cut and form a bit until its close. also the drip rails line up perfectly on both sides.
Old 04-21-2020, 11:03 PM   #69
1972_K20
The contour as compared to the drivers "correct" side.
Old 10-13-2020, 12:24 PM   #70
1972_K20
work on the project is on hold right now as we bought a theft recovery 2019 Duramax and had to put it back together. I was looking through the "Trucks in the Wild" Thread and came across a picture of the White C20 I bought from 2018, sitting in the same exact spot as when I picked it up, thought it was interesting
Old 10-20-2021, 08:02 PM   #71
1972_K20
I am hoping to start back up on this build here soon, the plan has changed, I put the 12 valve 5 speed into a ext cab short bed dodge, I sold that truck and made some money, I have now switched to a duramax chassis for my swap. I got a donor truck a month back, 2005 lly crew cab long bed.
Old 10-26-2021, 12:39 AM   #72
Low Elco
Too bad you're in Indiana, I need that 06 HD hood! Great progress on the truck.
Low Elco is offline   Reply With Quote
1972, chevrolet, cummins, k20
