1995 GMC Crew Cab Topkick Conversion
Greetings All,
In the past I built an 1981 Chevrolet C50 Pick Up. Over the past years I have been doing a newer version to haul my our family from Kart Track to Kart Track. Thought I would share the build. The truck started as a mid 90's GM Medium Duty Truck. It is powered by a 3116 CAT into a Eaton Six Speed and then to a Spicer Two Speed Rear. Truck is fun but still work to be done....
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
Re: 1995 GMC Crew Cab Topkick Conversion
Some more photos of along the way....
Pictures of stuff hacked off and mock up....
Love these ol' straight rail trucks.
Shackles cut it was time to move things forward....
As I get older this is not easier... ha.
More of the shorten...
More prep to the rear....
Raybestos Brakes at all four corners... Hard Lines/Flex Lines/New not Reman Calipers/Friction and Rotors. Big Brakes on this truck.
More Mock Up and frame clean up....
Front end work... I am not sure my wife appreciated this truck centered in our driveway....
Front brake work...
Splitting all this is a young mans game... ha.
Some more front end. My shortened driveshaft and the beginning of a lot of sanding...
#15 |
Sanding and arrival of six new tires...
#16 |
Our Driver with a tire, some more sanding and along the way I decided to have all holes filled in the rear of the frame.
BTW I use Rustoleum on the metal.
#17 |
Some more paint to the chassis as well as the subframe for the box...
#18 |
More random shots...
#19 |
I found a better box along the way...
#20 |
I had to put the outer wheel on for motivation...
#21 |
And still more sanding...
#22 |
Box is in Rustoleum Primer...
#23 |
Some undercoat and top coat under side of the box...
#24 |
A little color under the hood...
#25 |
Under hood shots... Was not a fan of the idea of red under there...
