![]() Join Date: Aug 2014
Does the driver door swing open more than the passenger by design?
On my '54 I noticed the driver side door appears to swing open further than the one on the passenger side. On the driver side it opens to be perpendicular to the car so ie 90° whilst on the passenger side it only swings open about 60°
![]() ![]() Join Date: May 2015
Re: Does the driver door swing open more than the passenger by design?
Mine are the same...could your hinge be bent?...or maybe the stop bent?
#3 | |
anywho armed with this new information went and snapped a few pics, here's what's interesting assuming this round ring is the stopper, it is loose like a goose on the driver side, the side that swings way more open (so that would make sense if the stopper is broken) however on the passenger side it is completely missing, I know so cause i found it in the bottom of the front of the cab when I was welding in a rust patch, I had no idea what it was so I think I tossed it, but needless to say it was snapped / broken what has me perplexed is, if the stopper be missing from the passenger side, what's stopping that door from swinging as far open as the one on the driver side scratching my head on this one |
![]() Join Date: May 2007
my drivers door opened that far and did a great job of smashing the cowl with the door edge.
#5 | |
It swings open further because part of the hinge body that bolts to the truck has been beat out from years of the door being pushed too far when people got in and out. That is real common though and one reason besides backing into something with the door open that so many AD trucks have the dent in the side of the cowl where the door hit it.
let me rephrase:
I have no idea how your door opens 90 degrees, my door was windblown and hit the door edge on the cowl at a little more than 45 degrees. in fact the "stop" gets the door edge really close to the cowl. so its gotta be a case of the hinge wallered out enough to give that much swing? I have no idea, but I have 4 cabs that have the "door opened too far" crease on the cowl
![]() Join Date: Jul 2015
My '63 C20 does the same thing.
#9 | |
I'm going to say that one issue with these trucks an trucks in general is that a lot of drivers push the door all the way open and then use it to help get in the truck pushing on the door against the jamb. That and wind blowing them open and backing up into things with the door open.
The round ring is the spring that holds your door in the open position. The top hinge on both doors each have 2 of these springs. They are often broken or missing. Most restoration parts stores sell them, they are easy to replace once you have taken your hinge out. I just replaced my hinge springs
My build- 51 Chevrolet |
