Old 05-07-2020, 06:10 PM   #1
MD2020
MD2020's Avatar
Trans cover??????
My cab has a high hump tran. cover.
will a low hump (the FLAT looking one) fit in there and bolt holes line up.??
There is plenty of room for my motor and Trans. to fit.
Is that high hump for a 4 wheel drive Trans.?????
My Cab is a 4B cab, I think that is a 1-1/2 ton cab?
MD2020 is offline   Reply With Quote
Old 05-07-2020, 06:15 PM   #2
MD2020
MD2020's Avatar
Re: Trans cover??????
It seems like most of the carpet kit's are for low hump??
Old 05-07-2020, 09:53 PM   #3
Black_Sheep
Black_Sheep's Avatar
In my 3100 the flat cover replaced the humped cover, no problem...
Black_Sheep is offline   Reply With Quote
Old 05-08-2020, 12:19 PM   #4
mr48chev
mr48chev's Avatar
High hump was to clear the 4 speed if it has the hole in it for the shifter.
I'm not understanding the 4 B thing, can you explain on that?
Chevy or GMC?
The flat trans cover should bolt right in though.
My ongoing truck projects:
Old 05-08-2020, 01:01 PM   #5
MD2020
MD2020's Avatar
I Can't find it right now but I ran accrose it before.
I THINK ?
On the vin. tag
2B is a 1/2 ton
3B is a 1 ton
4B is a 1-1/2 ton
I THINK all the cabs are the same but it was just the tag on the truck that was different?
Edit---- I found some info HERE
https://chevytrucks.org/1956-chevy-b...k-vin-decoder/
TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
Old 05-08-2020, 01:07 PM   #6
_Ogre
_Ogre's Avatar
as mr48 stated the high hump is for the 4 speed granny tranny
if you still have the motor in stock location a car 3 or 4 speed will fit with low cover
any modification will be hit or miss, truk has 700r4, i had to slightly modify the low cover
shop air compressor timer
Old 05-08-2020, 03:15 PM   #7
MD2020
MD2020's Avatar
I have a custom frame and plenty of room under there.
I just wanted to know if it would bolt up to the original holes.
Thanks for the info, and I ordered the low hump (flat one).
Old 05-10-2020, 01:18 PM   #8
mikebte
Yes, the flat will bolt up to the same holes. I removed mine with the hump and installed the flat. The new flat was fiberglass and not steel. Not sure a steel is offered.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 05-10-2020, 01:22 PM   #9
MD2020
MD2020's Avatar
Thanks Mike
Old 05-10-2020, 03:24 PM   #10
Black_Sheep
I found both when looking for a replacement and opted for steel...
Old 05-12-2020, 02:06 AM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
My truck HAD the flat cover. I have a 4l85e behind my LQ4 and it wouldn't fit unless I put the humped trans cover on it.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
