06-19-2020, 06:19 PM | #26 |
BlahBlahBlah
Re: 1971 Cheyenne Super C30 Ex Motorhome
Went to the DOL today after work to get my plates, tabs, and registration. She asked if it was still a motor home? ... Nope ... Do you have a bed on it? ... Nope ... OK, what you have to do is get your flat bed on there and then we can get you all road legal. Its going to have to be weighed too.
Guess I better get my butt in gear and figure out the final idea for the flatbed.
06-19-2020, 06:35 PM | #27 |
Oh no. It took me seven (yes seven) trips to DMV and CHP to finally get my papers sorted out. And even then I had something not right that I had to sign an affidavit for. Good luck!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
06-19-2020, 07:13 PM | #28 |
BlahBlahBlah
The truck is titled as a cab and chassis. And the title is already in my name, so I was really surprised she said I still needed to jump through a couple of hoops. Hopefully it wont be seven trips lol!
06-19-2020, 07:17 PM | #29 |
Proprietor of Dale's Corner
Best of luck to ya! The rules suck.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-19-2020, 11:29 PM | #30 | |
Hopefully it is easier in WA than CA As 68bowtie said They have plenty of hoops to make you jump through. Good luck Also, I think the chrome simulators you got will add a nice touch ‘Break up the white‘ ? Is your flatbed going to be white or black ? I’ve always thought a white cab with aluminum flatbed and chrome wheels Would look killer Problem is the bed costs twice as much as the truck is worth Last edited by Chevyland; 06-19-2020 at 11:35 PM. |
06-20-2020, 10:07 AM | #31 | |
BlahBlahBlah
06-26-2020, 07:09 PM | #32 |
BlahBlahBlah
So far Ive gotten my wheel simulators, the entire grill assembly I purchased from a board member, and four of the seven tires I ordered. I'm on hold right now trying to find out what happened to the rest of my tire order.
The parts I ordered from Rock Auto still haven't arrived. I have my inner fenders and core support ready to go. Not sure what else Ill need until I remove the nose and do a little detail work. Edit: Even though I got one tracking number the rest of my tires are coming in two more separate shipments via two different carriers ... UPS and FedEx, so odd. Supposed to be here Monday and Tuesday.
... Last edited by CG; 06-27-2020 at 09:45 AM. |
07-24-2020, 11:49 AM | #33 |
BlahBlahBlah
Update: I’ve been working on my panel and a couple home projects so this is sitting. I still need to get valve stems, which I’m totally unsure how to figure that out. I have to get a full set of lugnuts and rings because I can’t find the lugnuts I want to use that make it so I don’t have to use a rings I have a line on a couple of different flatbeds, one with a lift function. That’s it for now
07-24-2020, 12:06 PM | #34 |
What are you trying to figure out on the valve stems?
07-24-2020, 01:59 PM | #35 |
BlahBlahBlah
Never having owned a dually before dont they need to be curved or something vs plain ol straight ones? I suppose Im probably over thinking.
07-24-2020, 02:25 PM | #36 |
On my dually, I ran straight and metal stems. No matter what the duals are difficult to check the tire pressure. At one point I ran the flexible hose to the inside duals that made it easier.
07-24-2020, 06:07 PM | #37 |
All dual one ton stems I've seen all had short straight valve stems. Having a gauge with one of those dual heads, is about the only way to check the air in them...
07-24-2020, 07:31 PM | #38 |
If you go to a regular truck tire shop they have brass bendable stems about 4" long that they bend and route out so they are accessible just like the outer dual.
07-25-2020, 12:42 PM | #39 |
BlahBlahBlah
More very helpful info ... Thanks guys, much appreciated.
I went with metal med length valve stems. Thanks to a couple board members I found the lug nuts I wanted so I don't have to run the rings. Soon as that stuff comes in Ill run them over to my tire guy and get everything mounted up. I put the truck in my little shop and have started taking out the interior. I think Ill just treat the little bit of rust with some Rust Mort for now. I dont want to get into any metal replacement till I decide if Im really going to like this thing. Being a Super it has the nicer interior, but I really love the rubber mats vs the carpets. So I think Id rather spend my money on one of those instead of new carpets. Looks like we are finally having a run of nice weather so I might go ahead and put the new Super seat cover on the bench. Lets see, what else? Im not sure what the stock mirrors are called, camper mirrors? They pivot in close or you can pivot them out for better rear vision. Anyway I bought a set of those large size rectangular mirrors to try instead. Board member davepl has them on his blue GMC, he had his chromed though. Too much dough for me =)
... Last edited by CG; 07-27-2020 at 07:54 PM. |
08-01-2020, 10:27 AM | #40 |
Sounds like a great plan!!!
If you ever decided to sell it, it would sell, very easily, being a 71 (disc brakes!!!, auto trans, big block, and now modern wheels/tires. |
08-01-2020, 01:11 PM | #41 |
I think you'll love it...
08-02-2020, 11:35 AM | #42 |
BlahBlahBlah
Mounting the wheels and tires got put off till tomorrow. Got my mirrors last week. Shippers did a job on the box and even though the mirror heads we packed really well one got shattered. I’ll take the other mirror out so it can be used as a pattern and run it down to the glass shop and have two brand new mirrors made. Ive had it done before and they turned out great.
Here is a pic of what style I bought and pics of the other style I could use. I have one set with the white metal and two sets of the stainless. But I think I’m going to love the SR’s.
08-02-2020, 01:00 PM | #43 |
Looks like you have good options (maybe too many ). What is SR?
08-02-2020, 01:32 PM | #44 |
BlahBlahBlah
Ive seen the new white mirrors I got referred to as West Coast Seniors.
08-03-2020, 04:03 PM | #45 |
BlahBlahBlah
New tires and wheels buttoned up today. I like em!
08-03-2020, 04:23 PM | #46 |
What a difference. I think you need some shiny mirrors to match now.
08-03-2020, 04:50 PM | #47 |
X2, it looks a little naked without mirrors. LOL
08-03-2020, 05:27 PM | #48 |
BlahBlahBlah
Mirrors will probably be one of the last things I put on because of the narrowness of my shop I know Ill be bonking in to them all of the time.
Next up is to remove the front sheet metal so I can replace the rusted inner stuff and detail the rest. Im in no hurry though, Im kind of enjoying the process. I do wish I would have got the tires and wheels on sooner ... It would have been good motivation.
08-03-2020, 08:57 PM | #49 |
67-72 parts collector,
I’d love to have that cab and front clip.
That thing is clean! (Actually the whole truck)
08-03-2020, 10:08 PM | #50 |
I have (missed) (over looked) this Thread.
Now I am in. .
