Old 06-20-2020, 01:57 AM   #76
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Came across this...
Originally Posted by 68Gold/white View Post
Don't let that emblem of the hunter, on the back of the camper, go with it, that looks cool!!!
A member on my Pontiac website, is an engineer. He's now retired. Told a story of how farmers used to drain the crankcases of their tractors in the winter. They' put the oil in large glass containers. The sediment would fall to the bottom. They'd siphon off the clear oil and put it back in the tractor, and top it off with new oil (yes, this was a LONG time ago!!!) BUT, I was wondering about the same situation with your 327 in this awesome pickup???
Carry on!!!
Thanks for sharing, can't wait for next installment!!!
I wish I could have saved the hunter decal off the back of the camper but I didn't want to cut a hole in it.
That very well could be about the oil, but I won't know until I drain it. I have some other unique stuff I'm going to post tomorrow that was very interesting.
I will keep you updated!
Originally Posted by Custom 68 View Post
Wow it is like opening a time capsule with all the stuff you are digging out.
It really is! I will have to share the other time capsules.. they are really cool as well
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 06-20-2020, 12:52 PM   #77
HO455
HO455's Avatar
Thanks for sharing all of this. I love these kinds of treasure hunts, however the old lady doesn't so I only get to do it vicariously. That service box certainly seem not to to be an off the shelf model. Maybe it was a lube and fuel truck with a set of tanks in the bed.
RIP Bob Parks.
Old 07-12-2020, 12:29 AM   #78
Classic v6 GMC's
Well I have been busy working away. First things first, I found some information on who owned the truck and what it was originally used for. Hiding above the visor was this registration holder and inside was one of the last registrations (1981), a few of the last gas receipts from shell stations and best of all at the very back was the "Application for Arizona Title and registration". It's dated 11/24/1969 and the truck was purchased from Cialoni Marine Service in Crystal Lake Illinois.
Not sure how the previous owner came across the truck all the way in Illinois but it lines up with him sending the truck to the Lombard coach company located in Illinois. He might have had the coach installed before the truck came to Arizona.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-12-2020, 07:55 AM   #79
KevinK7
KevinK7's Avatar
Very cool on the documents
Just really neat finding the history of these trucks for sure
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 07-12-2020, 08:55 AM   #80
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
That's some cool find/info.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-12-2020, 10:46 AM   #81
toolboxchev
Great Story and Great Find.
Keep up posted as to your plans and finds!
toolboxchev is offline   Reply With Quote
Old 07-12-2020, 12:21 PM   #82
54blackhornet
54blackhornet's Avatar
Man what a post ! Congratulations this is the most interesting vehicle I have seen in a long time....America ingenuity at it’s finest.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-12-2020, 07:44 PM   #83
Classic v6 GMC's
That's for sure!! Every truck has a story!
Thank you! I will keep the posts coming. It's a special truck
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-12-2020, 09:15 PM   #84
Classic v6 GMC's
So I purchased all the parts to give the truck oil change and tune up. After sitting for almost 40 years I figured it would need a new distributor cap, rotor, points, condenser, plug wires and spark plugs. Started by spraying down the engine with degreaser and rinsing it off. Looks better.
Next up I pulled the oil plug and out came what looks like brand new Lucas or a mix of it and STP. Wish I would have drained it into a cleaner pan so I could get a picture of just how clean it was. Very intrigued, I pulled the old rotten belden plug wires and the spark plugs. All the plugs are clean with good plug gaps but I went ahead and put in the set of new AC Delco plugs. Pulled the distributor cap and inside looked like brand new, the distributor cap is an original delco. Put the cap back on and installed the new plug wires. Installed a new oil filter and filled it up with new oil and a can of CD2 oil additive (more on oils/additives in a future post). Set a good battery in and hooked up the cables. I ran a fuel line from a gas can tothe fuel pump and time for the moment of truth.
Cranked the truck over a couple times and then poured a little gas down the carb and she fired up and ran for almost 10 seconds. Poured some more fuel in the carb and she ran for 10 more. And then the fuel pump started leaking so pulled the fuel line and hooked up my little electric fuel pump and turned it on. Poured some more gas down the carb and she fired right up and runs great! Let her run for close to 3 minutes and she idles perfect and is a smooth as any of the engines we have rebuilt. Honestly I never thought it would run that good!
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-12-2020, 09:22 PM   #85
68bowtie
68bowtie's Avatar
She’s alive!! That’s great news.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 07-12-2020, 09:30 PM   #86
Classic v6 GMC's
Next up will be replacing the fuel pump, the thermostat housing, all the hoses and probably the water pump. It needs the coolant passages and radiator flushed because they seem to have some garbage/corrosion build up in them.
It was 113 here today and could only spend about two hours outside. Hope it cools down before I can spend some more time on it
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-12-2020, 10:10 PM   #87
Ol Blue K20
I'm glad to hear that it's showing some life! AWESOME! KEEP TRYING!
Dale
Old 07-12-2020, 11:44 PM   #88
Classic v6 GMC's
Yes, it is!
Me too. You never know what to expect on classic vehicles and especially one that sat for many years.
Slowly going to get it back on the road!
Lots of parts coming
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-13-2020, 12:50 AM   #89
Classic v6 GMC's
So the family is continuing to clear out his house and all the vehicles and they asked if we wanted any oil and other automotive stuff in this large cabinet outside under the open carport and we opened it up and hauled 4 large tubs full of oils, oil additives, fuel additives and lots of others stuff home. They didn't even know where to "git rid of it".
How many remember "Slick 50", "CD2" or these others?
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-13-2020, 01:03 AM   #90
Classic v6 GMC's
More
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-13-2020, 01:06 AM   #91
Classic v6 GMC's
A few more, I'm going to be busy pouring these in everything
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-13-2020, 01:49 AM   #92
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wow What a Incredible Time Capsule
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 07-13-2020, 06:30 AM   #93
Happy_dan
Happy_dan's Avatar
Such a cool story and the hits just keep coming!
Happy_dan is offline   Reply With Quote
Old 07-13-2020, 08:41 AM   #94
Ol Blue K20
Some cool stuff....
Dale
Old 07-13-2020, 08:58 AM   #95
68Gold/white
I wouldn't put that Slick 50 oil treatment crap in ANYTHING!!! I've seen it make a bad running engine, worse off!!!
68Gold/white is offline   Reply With Quote
Old 07-13-2020, 10:56 AM   #96
SCHRUMGMC
SCHRUMGMC's Avatar
Time capsule indeed, very neat and cool
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 07-13-2020, 11:22 AM   #97
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I just went through this whole thread. This is just as cool as it gets. What a find and story.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-13-2020, 11:42 AM   #98
tristan
Please let me know if he has a highly optioned SWB K10 hibernating somewhere on his lot. :-)
tristan is offline   Reply With Quote
Old 07-13-2020, 11:48 PM   #99
Classic v6 GMC's
It really is! Not many left out there. These are my favorite finds.
So much history!
Some cool stuff....
I wish, I have walked the lot and unfortunately none of those lol
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 07-13-2020, 11:56 PM   #100
Classic v6 GMC's
So me and my dad went back a couple weeks ago so and ended buying these as well.... not 67-72 but all have history and all were taken care of as well
Start with the suburban that is exceptional inside and out
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
