Old 07-01-2020, 08:50 PM   #351
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Originally Posted by TA_C10 View Post
Hey that looks good!
Thanks man. Your getting close on your build. It looks good.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 07-05-2020, 11:16 PM   #352
Kronald_70GMC
Originally Posted by Scurry67 View Post
nice work man! looks super clean.
Hey thanks for the compliment. Finally feeling like I'm getting somewhere
Kyle
IG: kyle_ronald
Old 07-13-2020, 08:03 PM   #353
Kronald_70GMC
And so the rust repair continues. This morning I cut out the rot at the lower corner of my passenger fender. After that, I found that the inner structure had taken a fair amount of rust as well so I went ahead and cut that out as well. I made a new piece for the inner structure and got it welded in.
Between welding on that while waiting for it to cool, I also started working on the patch panel for my passenger B pillar. The thing, like all my other pieces, was not going to just drop right in and fit. So I went ahead and chopped it into three pieces so that I could get it right. Now I just have to weld it all back together and it can be installed.
Kyle
IG: kyle_ronald
Old 07-14-2020, 12:14 AM   #354
Kronald_70GMC
Wheew that was alot of welding to fill in that gap, but its done now. Done mind the ugly welding, I was fighting it all the way. I also managed to get my fender patch ground down tonight as well. Hopefully tomorrow I can find some time to grind down the b pillar patch and maybe even get it welded in.
Kyle
IG: kyle_ronald
Old 07-17-2020, 12:10 AM   #355
Kronald_70GMC
I got my B pillar patch finished up. Then I proceeded to test fit it with the rocker panel. It fit quite well. My door gap was also nice. It can still be fine tuned a little bit when I install the cab corner. Not sure if I want to do the cab corner or rocker panel next? Is there a benefit to doing one before the other?
Kyle
IG: kyle_ronald
Old 07-17-2020, 01:12 PM   #356
SCHRUMGMC
SCHRUMGMC's Avatar
Great work
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 07-17-2020, 01:20 PM   #357
Kronald_70GMC
Originally Posted by SCHRUMGMC View Post
Great work
Thanks man. I appreciate the complement.
Kyle
IG: kyle_ronald
Old 07-17-2020, 09:10 PM   #358
cornerstone
cornerstone's Avatar
Lookin' great as usual Kyle.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 07-18-2020, 12:42 AM   #359
Kronald_70GMC
Hey man, Thanks. Good to hear from you again.
Kyle
IG: kyle_ronald
Old 07-19-2020, 01:02 AM   #360
Kronald_70GMC
Wow you would think that I would just realize by now that every piece I have for rust repair is terrible. I had a few minutes tonight to get an idea of how my cab corner is going to fit. It just looks terrible. I'm going to have to section it at least twice to get the fit right. Looks like I got my work cut out for me. These pictures are after I put the thing in a choke hold and folded it in quite a bit. Which created quite the kink on the lower edge of the corner.
Kyle
IG: kyle_ronald
Old 07-19-2020, 07:43 PM   #361
TA_C10
TA_C10's Avatar
Yeah man, I had to slice n dice mine too. The replacements aren't perfect but they are close enough. Be glad your not rebuilding them from scratch!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-19-2020, 07:48 PM   #362
Kronald_70GMC
That is very true!
Kyle
IG: kyle_ronald
Old 07-23-2020, 10:57 PM   #363
Kronald_70GMC
Well thats a relief. I have managed to get my rocker fitting quite well without having to slice and dice it. Bottom door gap is nice and even now. The cab corner on the other hand, now that I had to slice and dice. Still alot of work to do on the cab corner but I'm feeling good about it now.
Kyle
IG: kyle_ronald
Old 07-23-2020, 11:53 PM   #364
TA_C10
TA_C10's Avatar
That looks nice and straight. Good work.
"It's only money".
Old 07-23-2020, 11:55 PM   #365
Kronald_70GMC
Well thank ya sir
Kyle
IG: kyle_ronald
Old 07-23-2020, 11:57 PM   #366
Scurry67
looks great. i would say the rockers/cab corners patches were the biggest pain for me. you seem to have it well under control
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is online now   Reply With Quote
Old 07-24-2020, 02:00 PM   #367
Kronald_70GMC
Thats good to hear that it looks under control. Im just kinda winging it and hoping for the best. Thanks for the compliments. Your feather fill is looking spot on.
Kyle
IG: kyle_ronald
Old 07-24-2020, 09:28 PM   #368
Kronald_70GMC
Hey guys. Im looking for a little bit of input on something here. Ive managed to get my cab corner mocked up to an extent but im not sure that it is correct in the curve if that makes any sense. I think that it may dive inward of the body lines to soon. What are your guys thoughts on this?
Kyle
IG: kyle_ronald
Old 07-25-2020, 12:10 AM   #369
chewychevy67
Why don't you go look at my cab and take a cardboard template of the curve. That would help you. A body moulding could help too.
chewychevy67 is online now   Reply With Quote
Old 07-25-2020, 12:24 AM   #370
Kronald_70GMC
I ended up making one from my old cab and I took off the piece of moulding. My suspicions were confirmed and I had to make some relief cuts to make the adjustment. I now have it all tacked back together and fitting pretty nice.
Kyle
IG: kyle_ronald
Old 07-25-2020, 09:18 AM   #371
CryingJoker
Man i hope to have the same patience with my rust repair on my 70 I'm currently starting as you seem to have. Good work keep it up.
03 s-10: daily driver
94 s-10: late model toy
70 c10: starting frame off resto
80 c10: for sale just collecting dust
94 c1500: hauler to and from
55 chevy: hot rod project jus reborn
CryingJoker is offline   Reply With Quote
Old 07-25-2020, 11:15 AM   #372
Kronald_70GMC
Thanks!
Kyle
IG: kyle_ronald
Old 07-25-2020, 11:54 AM   #373
May70
May70's Avatar
Can you post some pics of the rocker panel with the door open? You are exactly a few steps ahead of me and I am really wondering how the @$#@ this is gonna go together!
Also how does the outer rocker top edge compare to the inner rocker height wise? Ill PM you some pics as not to hi-jack your thread (hah). Thanks man you are doing awesome work.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 08-06-2020, 12:27 PM   #374
Kronald_70GMC
I have been working at getting the cab corner welded back together which is alot of fun. Every tack I make wants to shrink it back down so I need to put it farther out than where it should sit so that once it shrinks, it is in the correct spot. It is turning out quite nice but is very slow going. You can see just how far off it is towards the bottom of the cab corner. Good thing I noticed this or it would have been far too much filler to correct it in body work stages.
Kyle
IG: kyle_ronald
Old 08-07-2020, 12:21 AM   #375
Kronald_70GMC
I'd say the cab corner is about 90% to the correct shape now. With a little bit of luck, I might just be able to get it all finish fit and installed this weekend.
Kyle
IG: kyle_ronald
