Old 07-26-2020, 09:13 AM   #1
SoCoC10
SoCoC10's Avatar
Converting High back bucket seats to low back
Has anyone converted High back bucket seats to low back? Here’s a picture of what I have.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 07-26-2020, 10:41 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Converting High back bucket seats to low back
Maybe?
Old 07-26-2020, 02:54 PM   #3
mrtoni
There is a guy who bought a few highbacks from me. He cuts the top off and recovers in 70-72 covers and asks $1200 I could use some plaid material if you discard
mrtoni is offline   Reply With Quote
Old 07-26-2020, 05:14 PM   #4
weq92f
weq92f's Avatar
I took some seats to an upholstery shop asking about the same thing...to cut the back of them down to my glass height, shape the top and make them look right.
The shop didn't want to touch it. Guy explained in detail about how cutting the seats down wasn't as straightforward as I thought it would be...that he would have to build new structure into it once existing structure was cut away...
It worked...I chose not to pursue cutting the seats!
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-26-2020, 06:57 PM   #5
chev-obsession
chev-obsession's Avatar
I have also been thinking about the same thing... cutting a high back down since they seem to easy to locate or even try looking for a 73-77 blazer/truck seats. curious if its been done and if it is worth it.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 07-26-2020, 10:04 PM   #6
davischevy
davischevy's Avatar
I've never cut any, but this prompted me to think a little. I have a set of 69/72 seats I let sit in a cab for years and the weather was not kind to the lower frames.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 07-27-2020, 12:55 AM   #7
Miller's Metal
Miller's Metal's Avatar
Foams fit good, skirts are different.
Miller's Metal is offline   Reply With Quote
Old 07-27-2020, 12:40 PM   #8
davischevy
davischevy's Avatar
So is that hoop at the top the only difference in the back?
other Larry
Old 07-27-2020, 01:01 PM   #9
SCOTI
SCOTI's Avatar
x2?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-27-2020, 01:05 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
so is that hoop at the top the only difference in the back?
x3
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-27-2020, 04:24 PM   #11
Miller's Metal
Pretty much the same. The high backs don't have the round bar tacked in the back or the slotted holes around inside perimeter of the back. easy fix.
I'm going to try to recover both low and high/converted to low. I will post up the difference.
Old 07-27-2020, 04:44 PM   #12
SCOTI
SCOTI's Avatar
Thanks & please do post info as you move forward. Curious to see what differences there were on the GM products.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-27-2020, 04:48 PM   #13
chev-obsession
The buckets in the first post are from a blazer correct? Not a van?
1965 c/10 swb
1969 c/10 lwb
Old 07-28-2020, 09:58 AM   #14
SoCoC10
SoCoC10's Avatar
Driver’s seat has tracks allowing front to rear adjustment while passenger side flips forward so I’m thinking Blazer.
Old 07-08-2021, 09:51 PM   #15
dagnabbitt
dagnabbitt's Avatar
Checking to see if OP or anyone else has done a successful conversion from hi back to low. I have a set of hi backs that I can't give away, I am willing to cut them down if there is any chance that it will be successful, but I want to do my due diligence.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-08-2021, 11:01 PM   #16
Jim Boy
Smile Re: Converting High back bucket seats to low back
Just a note folks! Hope that you don't get smacked in the rear after you cut the seats down. I got nailed good and after I woke up with damaged neck and shoulder muscles to this day 16 years later, I swore that with technology today that if I ever did anything with the seats it would have to include restraint protection. High seats or headrests are a must. My two cents worth as it is all I got left cause I own a truck. Have a good one eh.
Jim Boy is offline   Reply With Quote
Old 01-23-2023, 09:45 PM   #17
mehoff400
Any update on converting high back to low back?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 01-23-2023, 10:50 PM   #18
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I am in the middle of doing this myself. I forgot to take pics of the test fitting the foam, but the 71/72 style foam fits perfectly. I still need to drill the holes for the hog rings on the back side. I am currently making adaptor risers for the tracks as I want the seats a little lower than stock mounts. I am also too cheap to buy factory bucket seat tracks and my truck is a 68. I got a set of tracks for a 66-67 Chevelle buckets for cheap and I am making those work in my cab to save my bench seat mounts and limit how many new holes I need to drill through the floor.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 01-27-2023, 01:47 PM   #19
mehoff400
Thought your truck looked familiar. seen you around the PNW at a few truck shows with Northwest C10's and such.
My truck
Old 01-27-2023, 03:25 PM   #20
CAMAROBOY68SS
yep I have been running around the PNW since I got the truck done, gonna do it again this summer as well once I get these bucket seats into the truck.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
