Old 08-04-2020, 06:00 PM   #151
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
The replacement 3/4 carriage bolts finally came in! It’s been more than a few years since these were produced, several of the bracket lengths were off and need to be corrected.
skymangs is offline   Reply With Quote
Old 08-04-2020, 06:04 PM   #152
skymangs
skymangs's Avatar
Michael mocking the board up.
Old 08-04-2020, 10:26 PM   #153
joedoh
joedoh's Avatar
great progress chris!
Old 08-05-2020, 08:50 AM   #154
skymangs
skymangs's Avatar
Thanks joedoh, a little slower than I’m used to, but it’s coming.
Old 08-05-2020, 06:38 PM   #155
skymangs
skymangs's Avatar
The first picture is that new running board bracket design with the proper measurements. The second is shortening the center bracket. These seem less time consuming to build, they will be my new standard.
Old 08-21-2020, 09:40 AM   #156
skymangs
skymangs's Avatar
We wound up having to replace the rear mounts with this. I designed the mounts for a 118”, not a 123” wb!
Old 08-21-2020, 09:44 AM   #157
skymangs
skymangs's Avatar
Boards getting mocked up
Old 08-25-2020, 10:04 AM   #158
skymangs
skymangs's Avatar
Now that the brackets are finished it’s time to shorten those splashguards to tuck the bed against the cab and center those rear wheels! They started by marking the 1.25” to be removed.
Old 08-25-2020, 10:22 AM   #159
skymangs
skymangs's Avatar
Here they’ve removed the metal
Old 08-25-2020, 10:27 AM   #160
skymangs
skymangs's Avatar
Here they have tacked it together and mocked up the boards.
Old 08-25-2020, 07:59 PM   #161
joedoh
joedoh's Avatar
tell em I said nice freakin work! a real chip off the ol sarge!
Old 08-26-2020, 08:34 AM   #162
skymangs
skymangs's Avatar
Thanks dude
Old 08-26-2020, 11:33 PM   #163
oldman3
oldman3's Avatar
Yes nice job...Jim
oldman3 is offline   Reply With Quote
Old 08-27-2020, 09:36 AM   #164
skymangs
skymangs's Avatar
Thanks Jim!
Old 01-01-2021, 12:09 AM   #165
skymangs
skymangs's Avatar
after 8.5 months of prison, I finally got fed up and left! I now live in an apartment in town . I'm at the shop weekday's from noon-5. we get so much more done when I'm there! here is the finished stance. he didn't want it too low.
Old 01-01-2021, 12:16 AM   #166
skymangs
skymangs's Avatar
we put the steering column in
Old 01-01-2021, 12:57 AM   #167
28TudorAZ
28TudorAZ's Avatar
Is this the wife? If so I completely understand.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 01-01-2021, 10:07 AM   #168
skymangs
skymangs's Avatar
the VA home held me prisoner for 8.5 months. couldn't Leave, no visitors, not even delivery's! they called it quarantine, I called it unconstitutional! I fought for 4 months to leave, they even tried to have me declared incompetent IOT keep me! I won of course! total tyranny!
Old 01-01-2021, 10:18 AM   #169
skymangs
skymangs's Avatar
next we built a new cab dolly. (wife sold mine after the fire, didn't think I'd ever recover enough to need it I guess) that's OK, this one's better built!
Old 01-01-2021, 10:27 AM   #170
skymangs
skymangs's Avatar
oh, I almost forgot! before the cab came off, we did steering geometry! we used a piece of DD shaft and a 3/4 hiem to capture the lower joint. to keep it from wobbling.
Old 01-01-2021, 10:37 AM   #171
skymangs
skymangs's Avatar
then we tried to split the cast 4L60, to put in the torque converter and flywheel, but we couldn't get it to work even with the adapter!
Old 01-01-2021, 10:46 AM   #172
skymangs
skymangs's Avatar
so finally out of frustration, we pullud one of our expensive 4L65E's off the shelf and put it in. this required completely rebuilding the crossmember as it needed to move farther back .
Old 01-01-2021, 10:55 AM   #173
skymangs
skymangs's Avatar
I'll leave you with a bit on the gas tank. before he quit, Alex managed to misplace the gas tank straps! so we had to scavenge some from our personal junkyard! needless to say it was a fight!
Old 01-01-2021, 12:14 PM   #174
Rickysnickers
Hope you don't mind, I just straightened your photos. Nice work!!
Old 01-01-2021, 12:22 PM   #175
skymangs
skymangs's Avatar
not at all!
