08-07-2020, 03:23 PM | #1 |
steering gear help
Hello all,
Will the steering gear from an 87 r10 bolt up to and work on a 74 K20 frame? Thanks, Chip |
08-07-2020, 06:49 PM | #2 |
All about them K’s
Re: steering gear help
It should, the main differences will be that the later unit will likely be a quick ratio box(not a bad thing) and also the later box will have metric power steering hose fittings, that’s easy to overcome though.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-07-2020, 11:50 PM | #3 |
Thanks for the help!
08-08-2020, 01:34 AM | #4 |
All about them K’s
I had a major brain fart on this one, It just hit me that the R is the 2wd and V is 4x4 if I’m not mistaken. If you’ve got a 2wd box it will not work with a K series truck because the pitman arm moves side to side as opposed to forward and back. I apologize for missing the boat on this one.
08-08-2020, 02:29 AM | #5 |
Something new learned. 87 R10 2wd, last year of the square body's. You could use it with a crossover steering conversion.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-08-2020, 08:44 AM | #6 |
Well r or v it is a 87 1/2 ton 4wd box going on a 74 3/4 4wd frame if that helps. i have thought r was 4wd huh i learned something today as well.
08-08-2020, 09:18 AM | #7 |
All about them K’s
Ok then if it’s from a 4x4 truck my original post stands!
08-08-2020, 09:28 AM | #8 |
thanks again! I've been searching part numbers and have come to the conclusion that it will fit and the number differences probably have to do with the metric connections. I am swapping the eng/trans/ tc, fuel tanks and associated stuff as much as I can from the 87 into the 74 k20. keeping it a 3/4 ton. its a long story that I'll so a build thread someday to explain it all
08-08-2020, 10:12 AM | #9 |
All about them K’s
Sounds good I look forward to seeing progress.
