07-31-2020, 11:07 AM | #26 | |
All about them K’s
Re: suspension
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-01-2020, 06:37 AM | #27 | |
Re: suspension
08-07-2020, 06:34 AM | #28 |
Re: suspension
About the steering again , could it be that someone ahead of me has the amount of turns on the steering wheel each way wrong , if you know what I mean .
08-07-2020, 03:45 PM | #29 |
Re: suspension
adjuster on drag link / pitman to axle arm is for centering the steering wheel only .
the problem with lifted stock push/pull steering is the limit one direction gets less and less the taller you go . and to magnify the problem start flexing the suspension and it gets even worse to the point of maxed out steering and no way to make it turn . this is why crossover conversion is the best if taller than 5-6" range and any real off road use .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-07-2020, 07:56 PM | #30 | |
Re: suspension
08-07-2020, 08:21 PM | #31 |
Re: suspension
no problem . been playing with lifted squares since 2001 ish
and i read a lot and ask a lot and remember a bit here and there and try and pass it along .
08-08-2020, 02:55 AM | #32 |
Re: suspension
Try this- turn steering lock to lock counting the turns. May be easier putting front axle on stands. Depending on the box installed should be around 3.5-4.5 turns. Position steering travel in the middle, ignore steering wheel position at this time. Adjust draglink until wheels are pointed straight. You should be able to pull the wheel from the column and re-position to make it straight. With the short draglink angled down bump steer will be more pronounced and you will loose additional steering one way at full droop or full compression. Most likely fine for highway driving.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-08-2020, 10:29 AM | #33 | |
Re: suspension
its just the nature of modifications one thing leads to another .
08-08-2020, 07:28 PM | #34 |
All about them K’s
Re: suspension
The thing I ran into in the past with reindexing the steering wheel is i happened to have too close to tripping the canceling cam for the signal switch when pointed straight. It’s really irritating when you set the signal lever going straight and move the wheel only a few degrees in one direction and have it cancel the signal lights. I fixed that real quick I can assure you.
08-09-2020, 07:10 AM | #35 |
Re: suspension
I have never had the steering wheel off , but that doesn't mean someone before me hasn't , when I got the truck the horn didn't work so I went at that and got it working but the left turn signal won't cancel out .
When the steering wheel is turned to the right it will squeal out on the pump way sooner than the other way and if not careful on the way I go about it I will end up doing a 2 point turn. |
