Old 02-28-2020, 10:12 PM   #151
7D2N
7D2N's Avatar
Re: My winter project
I needed to free up some space before I start working on the doors. The motor is in and FYI install power steering bracket and trans line clip before you find out as I did and pull motor again.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 03-17-2020, 10:30 PM   #152
7D2N
7D2N's Avatar
Things are going back together. AC box cleaned and the case sealed.
Old 04-18-2020, 08:16 PM   #153
7D2N
7D2N's Avatar
Working on AC and heating ducting under the dash, there is a lot going on under there.
Old 08-03-2020, 05:12 PM   #154
caseyfromMO
We need an update man!
caseyfromMO is offline   Reply With Quote
Old 08-10-2020, 07:40 PM   #155
7D2N
7D2N's Avatar
Casey, your right needed to download phone pictures hope they work. Here is a small update. I completed the engine bay AC stuff and still working on under dash things. I repaired the cut radio hole, I got an aftermarket speaker because that will need to go in first or never get it in, dash pad, middle AC vent and ducting work my way down and out. I had a paint shop mix GM 521 to factory spec. and put in spray can application I'll post when I get the dash painted.
7D2N
sorry for sideways pics can some one helpme turn them.
Old 08-11-2020, 11:01 PM   #156
1rippen6
Here you go
1rippen6 is offline   Reply With Quote
Old 08-13-2020, 08:27 AM   #157
7D2N
7D2N's Avatar
Thank You
Old 09-15-2020, 09:50 PM   #158
7D2N
7D2N's Avatar
Small update: I rattle can sprayed my dash with the 521 GM paint I had the shop mix and I think it worked out fine.
7D2N
Old 09-15-2020, 09:59 PM   #159
7D2N
7D2N's Avatar
Dash cluster work.
Old 09-18-2020, 01:36 AM   #160
72blue
72blue's Avatar
I just read this whole thing and couldn’t stop until I read it all. Nice work.
James
72blue is offline   Reply With Quote
Old 09-18-2020, 06:57 AM   #161
jaros44sr
jaros44sr's Avatar
Nice work....how hard is it too pull off the needles for the gauges
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-18-2020, 04:07 PM   #162
7D2N
7D2N's Avatar
Thanks guys, I couldn't have done half of this without the information on the board.
I didnt remove the needles, if you noticed the aluminum foil in the photo I cut small slots and slid it under the needles and pressed in place and used a brush on reflective needle paint.
Old 09-19-2020, 08:44 AM   #163
jaros44sr
jaros44sr's Avatar
Great idea, thanks for sharing I've been wanting to do that for a while and didn't want to break it
Is the paint available online, looks like a good match
SAFETY FIRST
AS usual, off topic
Jim
Old 09-30-2020, 08:41 PM   #164
7D2N
7D2N's Avatar
Yes, the paint is available online and worked great. The bottle I have has plenty more if you need it.
7D2N
Old 09-30-2020, 09:06 PM   #165
7D2N
7D2N's Avatar
I completed a few things on and under the dash, kick panels vents rebuilt, all ductwork replaced and GM radio installed.
Old 09-30-2020, 09:27 PM   #166
7D2N
7D2N's Avatar
I'm really close for the gauge cluster going in.
Old 10-07-2020, 03:51 PM   #167
BLT-NT-BOT
Craig,
Good to see that you are making great progress. Looks great!
Jothan
BLT-NT-BOT is offline   Reply With Quote
Old 10-07-2020, 07:55 PM   #168
7D2N
7D2N's Avatar
Originally Posted by BLT-NT-BOT View Post
Craig,
Jothan
Thanks Jothan, Thanks again with the parts you helped me out with. I did finish up the dash area so I'll start on the doors.
Old 10-09-2020, 01:57 AM   #169
72blue
72blue's Avatar
That looks so nice. I want a blazer now.
James
Old 10-13-2020, 09:47 PM   #170
7D2N
7D2N's Avatar
Thanks,
Old 10-13-2020, 10:15 PM   #171
7D2N
7D2N's Avatar
Moving to the doors and I have some things to fix.
Old 11-02-2020, 08:49 PM   #172
7D2N
7D2N's Avatar
I had some sandblasting done on my doors and fenders, does anyone know how should I prep the surfaces until I can repair?
Thanks.
7D2N
Old 12-13-2020, 09:38 PM   #173
7D2N
7D2N's Avatar
Started working on the doors and they need some patches. Any tips or advice on welding this together, butt weld, lap weld?
Thanks 7D2N
Old 12-14-2020, 09:41 AM   #174
raggedjim
raggedjim's Avatar
I'd butt weld it. Nice work so far.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 12-19-2020, 09:52 PM   #175
7D2N
7D2N's Avatar
I'm fitting the patch panels on the doors, checking the fit and alinement before I cut for welding.
