Old 08-16-2020, 02:15 PM   #1
clay68c10
clay68c10's Avatar
Motorhome Tilt Column, bolt in ready
$250 local, $300 shipped
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a motorhome tilt column. From a mid 80s GM chassis
I moved the NSS down so it's a bolt-in for your 67-72;
I used my multi-meter to adjust it, you may need to fine tune it after install.
Turn signal has no lever, your original will fit
Turn signal switch is tight and cancels as it should. Includes the pigtail with the flat wire end so you can modify your harness for the newer style switches.
Includes the cancel cam
The gray illumination wire is fairly long
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings were cleaned and greased
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is average
Shift arm and adjuster lever have decent chrome, they shine up well.
The finish on it is OK, great for a driver. Some scratches and wear as pictured.
I will include a new GMC Paul's gear indicator.
You will need to add your dash and firewall gaskets, as well as the firewall plate.
The new gaskets will stretch over the shift arm. Old ones may split.
**I will ship it with the levers and indicator housing removed to avoid shipping damage**
There is a trick to getting the indicator housing and pointer on, I can go over it with you if needed.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-16-2020, 02:20 PM   #2
clay68c10
clay68c10's Avatar
Re: Motorhome Tilt Column, bolt in ready
More pics
13 Tahoe LTZ
Old 08-16-2020, 08:55 PM   #3
zach_carver
zach_carver's Avatar
How will this work in a 1965 c10? Or should I look for something different.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 08-16-2020, 10:30 PM   #4
clay68c10
clay68c10's Avatar
I honestly don’t know.
You might post up on the 60-66 area and see if anyone has an answer.
13 Tahoe LTZ
Old 08-17-2020, 10:08 AM   #5
1968C30
1968C30's Avatar
I have this column installed in my 64 c10. I have a new wiring harness installed and used a Lokar shifter cable. Here are some pictures
https://paypal.me/DMorris6870
1968C30 is offline   Reply With Quote
Old 08-17-2020, 07:33 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
Clay if it will go right in a 72 and work.......
PM me
Thanxs
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-17-2020, 07:49 PM   #7
clay68c10
clay68c10's Avatar
Yes it will, you just need to connect the wiring.
Sold to Big Orange
PM sent
13 Tahoe LTZ
Old 08-18-2020, 02:12 PM   #8
BIG ORANGE
BIG ORANGE's Avatar
Thanks for understanding,,,
Old 08-18-2020, 04:00 PM   #9
clay68c10
clay68c10's Avatar
Big Orange has bowed out, best of luck to him and his.
Back up for sale
13 Tahoe LTZ
Old 08-20-2020, 01:54 PM   #10
Leroy-B1
Im interested in this...can you pm me about the wiring details?
Leroy-B1 is offline   Reply With Quote
Old 08-20-2020, 02:57 PM   #11
clay68c10
clay68c10's Avatar
Sure
The wiring colors and pin positions are the same for early and later turn signal switches. The old style has a half-round connector and the new style is flat. New replacement switches come with the flat to half-round adapter.
You can also splice in the pigtail end that I'm including. That updates your truck harness to the flat style connector.
I think you can buy the flat to round adapter separately.
The neutral/reverse switch wiring is similar. Splice it in as necessary. If you have an auto column already you can just swap the connector since it is slightly different. If it's a manual then you can use the pigtail to wire them in.
13 Tahoe LTZ
Old 08-21-2020, 09:30 PM   #12
Leroy-B1
I'll take it
Old 08-22-2020, 08:59 AM   #13
clay68c10
clay68c10's Avatar
Sold to Leroy-B1
13 Tahoe LTZ
Old 09-30-2020, 07:39 PM   #14
clay68c10
clay68c10's Avatar
Back to the top, the deal fell thru.
13 Tahoe LTZ
Old 10-01-2020, 10:44 PM   #15
396ci
396ci's Avatar
if you can do $275 shipped to zip 95356 i will take it. thanks for the consideration.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 10-02-2020, 03:55 PM   #16
clay68c10
clay68c10's Avatar
Sure, I can do that
PM sent
13 Tahoe LTZ
Old 10-02-2020, 08:34 PM   #17
396ci
396ci's Avatar
Sure, I can do that
PM sent
payment sent. thanks
Brian
XNGH ECV Chapter 58
Old 10-03-2020, 03:47 PM   #18
clay68c10
clay68c10's Avatar
Shipping it out today
Thanks again
13 Tahoe LTZ
column, comfort tilt, motor home, tilt
