Old 08-07-2020, 12:25 AM   #376
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Has anyone else noticed that the view counter appears to have stopped quite some time ago or is it just something on my end?
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 08-07-2020, 08:28 PM   #377
chewychevy67
Nope it don't work. Been a few months now.
chewychevy67 is online now   Reply With Quote
Old 08-07-2020, 09:11 PM   #378
mr48chev
mr48chev's Avatar
Wow, I don't think I would have ever taken one on in that shape. I've primarily got to weld up the 50 something holes that my uncle drilled in the 71 I have that he had for years. I think my dad gave him that electric drill for his Birthday one year too. You sure are doing a nice job on it though.
My ongoing truck projects:
Old 08-07-2020, 11:58 PM   #379
Kronald_70GMC
Thanks for the compliments. I just keep telling myself that all this work will pay off in the end.
Kyle
IG: kyle_ronald
Old 08-09-2020, 02:17 AM   #380
Kronald_70GMC
Cab corner has nearly been finish welded. I had to cut it back off in order it weld all the bottom stuff. For some reason my welder is trash at welding from underneath. Its all good though as I had to remove it for weld through primer and to finish cutting the back to fit. It turned out to be alot easier than expected to remove the lip around the bottom of the cab corner. Im hoping to possibly get it tacked into position tomorrow. We'll see if I have enough time.
Kyle
IG: kyle_ronald
Old 08-09-2020, 06:50 PM   #381
Kronald_70GMC
All welded up. Just need to check for pinholes in the welds, clean up the back side, shoot with weld through and it will be ready for the final install!
Kyle
IG: kyle_ronald
Old 08-09-2020, 11:25 PM   #382
Kronald_70GMC
I'm hoping that someone who has installed vintage air might be able to chime in on this. Im still trying to figure out how I can mount the unit as clean as possible but I can't afford the unit as of yet. I would like to have the fasteners hidden from the engine bay to stick with my clean firewall theme. So my question is, if I were to weld in two vertical channels on the inner firewall that were just wider that the overall unit, would I then be able to build a mounting plate that I could bolt to the unit, and then to the channels? Im fairly sure that it would work, my only concern is that I would be then mounting the unit, Im guessing around 3/4" further into the cab. Does anyone know if this would work? Thanks in advance for any help on this.
Kyle
IG: kyle_ronald
Old 08-10-2020, 01:03 AM   #383
cornerstone
cornerstone's Avatar
I can't give a direct answer, but I'll be glad to try to help you figure it out. I want the same look, I mean we went through the work of getting the wall clean and it just feels wrong to have to have the head of a bolt mess it up. Currently I have the VA unit hanging on the the inside firewall. It's not bolted in yet, but held in place by the aluminum lines that attach to the unit. My thought was to get the evaporator in it's proper place, and make marks on the firewall where threaded mounting studs could be welded. It is a very tight fit just to get it up there, and will be even harder to get enough clearance to fit the unit on the studs, but where there is a will there is a way. I'll try to get some decent pics up so we can solve the problem.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-10-2020, 08:55 AM   #384
Kronald_70GMC
Thank you sir!
Kyle
IG: kyle_ronald
Old 08-10-2020, 03:59 PM   #385
curtisb
beautiful work, thanks for the pictures. this will help me when i start my restoration
curtisb is offline   Reply With Quote
Old 08-10-2020, 05:02 PM   #386
Kronald_70GMC
Right on. Glad I can help out in any way. Lots of what I've done was found on this forum.
Kyle
IG: kyle_ronald
Old 08-14-2020, 01:20 AM   #387
Kronald_70GMC
Nothing ever seems to work out in what I think i can get done in an evening. There is always something unforseen that slows me down. Tonight It was my rear floor patch. It looked like it was pretty close from the bottom which is where I've been viewing it from. I should have looked from inside the cab as well but of course, I didn't. Oh well its all fixed up now. I had to slice it along the top edge and twist the top out towards the back of the cab to get it to where it needed to be to work with cab corner. After all that fun, I even managed to get it tacked into position.
Kyle
IG: kyle_ronald
Old 08-17-2020, 01:52 PM   #388
TA_C10
TA_C10's Avatar
very nice work sir.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 08-18-2020, 02:15 PM   #389
gmc684x4
Very nice looking truck
What are you using for a mig ?
I had a mig pak 10 from Ct i hated it and sold it even a welder i know had a hard time with it
gmc684x4 is offline   Reply With Quote
Old 08-18-2020, 04:16 PM   #390
Kronald_70GMC
Originally Posted by TA_C10 View Post
very nice work sir.
Thank you sir.
Thanks for the positive input! Always a huge help for getting my motivation up.
My mig is an old Hobart Handler probably from the 80's. My dad has a hobart Handler 140 and it is a great machine. Thats what I started welding with back when I lived at home.
Kyle
IG: kyle_ronald
Old 08-21-2020, 09:25 PM   #391
Kronald_70GMC
Well I did manage to get on the truck for about 30 minutes today. I have been sidetracked on a different project for my quad. It turned out so much better than I expected so I just have to share it here. I did managed to correct the rear door gap. It was quite tight near the body line and for anyone who has the same issue, it seems that correcting it with the cab corner tacked on seems to be the best way. I had tried to correct it several times pre cab corner and it always went back. I guess it just needed something to hold it in place.
Kyle
IG: kyle_ronald
Old 08-21-2020, 11:06 PM   #392
TA_C10
TA_C10's Avatar
Great idea axe holder on the quad ��
And doing a great job on the cab corner.
"It's only money".
Old 08-22-2020, 10:03 AM   #393
Kronald_70GMC
Thanks man! I'm hoping to get out there later today to make some more progress.
Kyle
IG: kyle_ronald
Old 08-22-2020, 10:08 PM   #394
Kronald_70GMC
Wooo weee is that alot of welding. I got 2 hours in tonight and have the rest of the plug welds done and I also finished up the butt weld on the outboard side. It is all ground down and cleaned up. So shiny
Kyle
IG: kyle_ronald
Old 08-27-2020, 08:19 PM   #395
Kronald_70GMC
Cab corner is in! It fought me pretty good on the back so it will definitely need some decent filler but im pretty happy all things considered.
Kyle
IG: kyle_ronald
Old 08-28-2020, 12:32 AM   #396
cornerstone
You're a true craftsman Kyle! It may take long time to do it right, but you'll know exactly what you're driving and have pride in it at the same time.
Brian
Old 08-28-2020, 12:02 PM   #397
Kronald_70GMC
You sure know how to make a guy feel good about his work. Thanks! It's comments like this that keep me motivated.
Kyle
IG: kyle_ronald
Old 08-28-2020, 12:05 PM   #398
TA_C10
TA_C10's Avatar
Agreed. Such great work here. That corner looks really nice.
"It's only money".
Old 08-28-2020, 06:10 PM   #399
Kronald_70GMC
Thanks man! I appreciate the kind words
Kyle
IG: kyle_ronald
Old 08-29-2020, 02:37 AM   #400
gmc684x4
Nice work
I have seen cardboard as backer for bondo on rusty trucks seen a bronco where the fellow rivited the patch panels over the rust spots
My aim will be after i get a mig to make my work look close to yours
Practice will help
I seen a trick one fellow showed me make the patch and the panel trimmed close to same size tack the two together use zip disk cut at a 45 degree angle back tack the fresh cut flush make the next cut and continue until you have the patch completely flush fit finish welding and watch how much heat you drive into the panel
