Old 09-12-2020, 01:35 PM   #1
bigmoe
bigmoe's Avatar
Bigmoe's 65 GMC10 project.
I've been posting occasion pics of my project related to what ever I was needing advice on at the time, etc., but now that it's finally done I thought I'd post some pics of the entire project. It was 2 1/2 years in the making but over a year of that was at the body shop. I bought the truck as a basket case, a 65 GMC. The frame had been cleaned and painted and the cab had been at a reputable body shop to be prepped for paint. It came with two boxes and I also bought a parts truck. The 5.3LS motor I got from a written off 2008 Chev Tahoe that had only 69000km (43000 miles). My apologies for the ones that are upside down. I finally figured out which way to hold my iphone.
bigmoe is offline   Reply With Quote
Old 09-12-2020, 01:38 PM   #2
bigmoe
bigmoe's Avatar
Re: Bigmoe's 65 GMC10 project.
I acquired a square body front crossmember. 2 1/2" drop spindles.
Old 09-12-2020, 01:39 PM   #3
bigmoe
bigmoe's Avatar
Exhaust holes through the crossmember and modified trans crossmember for exhaust.
Old 09-12-2020, 01:41 PM   #4
bigmoe
bigmoe's Avatar
Engine plates. Ended up using 3rd hole set forward to clear the firewall.
Old 09-12-2020, 01:45 PM   #5
bigmoe
bigmoe's Avatar
Picked up some 2008 Odyssey second row seats. I ended up recessing the mounts to gain more headroom. (I'm 6'3) They can be popped out of the truck by just pulling a release handle.I removed the handles on the back of the seats so they would go back further and removed the inner arm rests. Console is from a newer Silverado.
Old 09-12-2020, 01:46 PM   #6
bigmoe
bigmoe's Avatar
Aftermarket mirrors from Ebay
Old 09-12-2020, 01:47 PM   #7
bigmoe
bigmoe's Avatar
Progress in paint booth
Old 09-12-2020, 01:51 PM   #8
bigmoe
bigmoe's Avatar
RnD rad. Spal fan.
Old 09-12-2020, 01:55 PM   #9
bigmoe
bigmoe's Avatar
Finished the back wall with a piece I got from an ?04 F150 std cab and some Kydex plastic I formed for the corners.
Old 09-12-2020, 01:56 PM   #10
bigmoe
bigmoe's Avatar
motor goes in
Old 09-12-2020, 01:59 PM   #11
bigmoe
bigmoe's Avatar
I used an in cab recirculating heater because I didn't like the Deluxe heater in the engine bay. I had to modify the glove box because it was hitting the heater assembly.
Old 09-12-2020, 02:06 PM   #12
bigmoe
bigmoe's Avatar
Made some licence plate brackets to center the plate.
Old 09-12-2020, 02:08 PM   #13
bigmoe
bigmoe's Avatar
I applied vinyl stripe. The truck had no trim holes so we didn't know where to paint the stripe.
Old 09-12-2020, 02:10 PM   #14
bigmoe
bigmoe's Avatar
I used an Art Carr/Winters shifter. Cable actuated made it easier to position. It also has neutral safety and reverse switches.
Old 09-12-2020, 02:11 PM   #15
bigmoe
bigmoe's Avatar
Trim applied with 3M tape
Old 09-12-2020, 02:19 PM   #16
bigmoe
bigmoe's Avatar
All done!
The wheels are 17 x 8 with 4 1/2" backspace. I have a square body rear end that is 3/4" wider per side. 235-60-17 and 255-60-17
2 1/2" drop spindles and stock springs in front and Jeep 97-06 rear coils (ACDelco 45H2104)
Old 09-12-2020, 02:19 PM   #17
bigmoe
bigmoe's Avatar
72 bumper
Old 09-12-2020, 03:31 PM   #18
raylube
raylube's Avatar
Wow looks good, is that a homemade fan shroud?
raylube is offline   Reply With Quote
Old 09-12-2020, 04:07 PM   #19
bigmoe
bigmoe's Avatar
Ya square tubing from Home Depot and a piece of aluminum.
Old 09-12-2020, 04:15 PM   #20
bigmoe
bigmoe's Avatar
Went with a Dakota Digital universal dash with BIM module. Just plugs into the OBD II port.
Old 09-12-2020, 04:23 PM   #21
bigmoe
bigmoe's Avatar
Engine bay
Old 09-12-2020, 04:33 PM   #22
bigmoe
bigmoe's Avatar
Tanks Inc USPT-GH 15 gallon gas tank. I was going to fill up the middle thruogh the wood but ended up using the fill neck on the side, through the frame, to the corner of the box.
Old 09-15-2020, 02:34 PM   #23
aggie91
I'm just glad to be here!
aggie91's Avatar
Truck looks great!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-28-2020, 03:57 PM   #24
bigmoe
bigmoe's Avatar
Filler in the corner of the box. Filling it is slowed, probably because of the 45 degree elbow, but it's not too bad.
Old 12-28-2020, 04:48 PM   #25
The Rocknrod
Moderator
The Rocknrod's Avatar
Man that's looking sweet!
Love those license plate mounts. I'm going to make a pair for mine.
