Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-07-2020, 10:56 AM   #1026
57taskforce
All about them K’s
57taskforce's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
I just skimmed over this build, nice truck! It’s going to be an animal when you get it on the road!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 09-08-2020, 01:00 AM   #1027
First c10
First c10's Avatar
Originally Posted by Richard View Post
Thanks for the response. Never seen it before, but then again I have not really worked on a 67 or 68. Wonder if it could be fitted to the newer models with a little bit of fab?
That’s funny I assumed the other had one. I will have to look at my sons 70. I will see if it would it and let you know.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 09-08-2020, 01:03 AM   #1028
First c10
First c10's Avatar
Thank you. It is one of those trucks that has changed directions every time I work on it!
I can’t wait to get the bed floor and interior.
GO GO!!!
Old 09-21-2020, 10:34 AM   #1029
First c10
First c10's Avatar
Hey all I was able to spend some time on tuning the Torqstorm supercharger. Man it sounds cool.
Here is a video after I tuned the new MAF.
https://youtu.be/cWadcANsbMU
I also received my Smokey road rod shop bed kit. Here it is laid out on my bed rails. Now to drill all the holes and try and game plan how to get this bed assembled.
GO GO!!!
Old 09-22-2020, 09:18 PM   #1030
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Great choice on the bed kit. Right on.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-22-2020, 11:06 PM   #1031
TA_C10
TA_C10's Avatar
No special design on the wood? I'm thinking of using these guys for my bed as well and also thinking of having them burn something on the floor. Not sure yet.
The wood looks great. Ready to see this update.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 09-23-2020, 01:09 AM   #1032
Richard
Bed wood looks nice!
Richard
Old 09-23-2020, 10:43 AM   #1033
First c10
First c10's Avatar
I have been looking for a design but will have it placed on the box. if I can make up my mind. Its like a tattoo you need to make sure!!!!
GO GO!!!
Old 09-23-2020, 10:47 AM   #1034
First c10
First c10's Avatar
I was able to get my filler neck and vent tubing routed. I am going to place a vent up higher than the fill neck up under the bed side up above the marker light.
GO GO!!!
Old 09-23-2020, 11:31 PM   #1035
TA_C10
TA_C10's Avatar
I like how you pieced all this together man. What is going to go on the barb here?
"It's only money".
Old 09-24-2020, 02:00 AM   #1036
First c10
First c10's Avatar
Thank you! Well since I cannot get the 5/8” vent line up to the gas cap. I decided to add this vent line and run it above the fill cap. I called Tanks inc and discussed my situation. They said to vent the tank (the 3/8” line) and to add this tee to the filler neck vent. They also said to tee them together and run the one higher than the fill cap. I will try to connect them and run One 3/8” line up and if it doesn’t work I will separate them and run two 3/8” lines.
GO GO!!!
Old 09-24-2020, 02:02 AM   #1037
First c10
First c10's Avatar
Hey Dan. Thanks to you! Thank you!
I am working with Frank and Rhonda on the tool box cover. Trying to get something cool.
GO GO!!!
Old 10-07-2020, 05:39 PM   #1038
First c10
First c10's Avatar
Continue to work on the bed. I ordered a set of stainless/delrin tailgate trunions.
Figured I would hit them on the polisher before install. Time to get the tailgate installed so I can square up the box and get it tightened down for the last time.
GO GO!!!
Old 10-07-2020, 09:05 PM   #1039
DWilbur
They look great. I bought set while back but can’t find them.
DWilbur is offline   Reply With Quote
Old 10-07-2020, 10:52 PM   #1040
First c10
First c10's Avatar
Grabbed a quick picture after getting the gate on. Looks good. I do need to tighten up the slack in the handle. I don’t like it. But the gate is on and looks great.
DW. I say that everytime I need something lol.
GO GO!!!
Old 10-14-2020, 12:30 PM   #1041
First c10
First c10's Avatar
Little update on the bed. Tailgate and fender wells are in. I just need to get my toolbox doors installed and aligned so I can tighten all the 1000 bed bolts.
GO GO!!!
Old 10-14-2020, 12:36 PM   #1042
First c10
First c10's Avatar
I also finished up my Gas tank filler behind the driver taillight. I ran the wiring for the taillights. reverse lights, and side markers.
GO GO!!!
Old 10-14-2020, 02:34 PM   #1043
TA_C10
TA_C10's Avatar
Looking good! Curious. Where did you get the cork gasket for wheel wells? And any chance you have pics of your cross sill in place before the bed wood went on?
EDIT: Oh, and did you use the rubber pads under the cross-sills?
"It's only money".
Old 10-14-2020, 06:12 PM   #1044
First c10
First c10's Avatar
The bed floor is from Smokey Road Rod Shop in Georgia. They provided the gaskets and hardware.
The cross sills are stock but have been customized by me and have been powder coated. I will see if I have a picture. but post 1034 you can see the cross sills
GO GO!!!
Old 10-14-2020, 06:25 PM   #1045
TA_C10
TA_C10's Avatar
Thanks. I am looking to see your placement of the second to last cross sill on the frame, hoping to see what holes you used in your frame. And I am also wondering if you used those little square rubber pads under your cross-sills or if they are metal to metal. Can't see that in post #1034 unless I am blind lol.
"It's only money".
Old 10-15-2020, 12:02 AM   #1046
First c10
First c10's Avatar
Oh I got you. I measured my mounting holes in my bedsides so I cant remember where i placed that cross sill. I will have to look and get back to you. I raised my sills up 1” so I made my own pads with some real thin rubber. I can’t remember the thickness. But it’s pretty thin like 1/16” or so.
GO GO!!!
Old 10-21-2020, 11:20 AM   #1047
First c10
First c10's Avatar
Small update...
Received my bucket seats from the upholster. The photo is them just setting in place. I need to melt holes in the floor to keep the carpet from unraveling.
after I set the seats in place my upholstery guy and I set the center counsel/seat in and now have a game plan on how it will be upholstered. The plan is to have the design flow from the center counsel to the speaker box. We will see how that goes.
GO GO!!!
Old 10-21-2020, 11:26 AM   #1048
First c10
First c10's Avatar
My time lately has been used up by work and a new toy.
I decided to order a Snap-on welders work station to consolidate my MIG and TIG welders so not to have all these carts.
On another note I cant wait to remove the truck and clean out all the dust and debris from all the work on this truck.....bodywork, dust, ash from the forest fires, etc.
GO GO!!!
Old 10-21-2020, 03:14 PM   #1049
TA_C10
TA_C10's Avatar
Those seats are just plush looking
I like the new welding station too. So you got ash from forest fires eh? Hopefully you and your family didn't have any loss due to all those fires....
"It's only money".
Old 10-22-2020, 01:15 AM   #1050
First c10
First c10's Avatar
Our whole state was or is on fire so the smoke and ash was around in,y area for a few weeks. They are contained or close to being contained now. I have a few friendS that lost their cabins but no one was hurt thankfully.
I can’t wait to get the center section.
I am heading to Montana for 2 weeks so maybe it will be finished by the time I get back!
GO GO!!!
