02-28-2020, 10:12 PM | #151 |
Re: My winter project
I needed to free up some space before I start working on the doors. The motor is in and FYI install power steering bracket and trans line clip before you find out as I did and pull motor again.
Just for the fun of it |
03-17-2020, 10:30 PM | #152 |
Things are going back together. AC box cleaned and the case sealed.
04-18-2020, 08:16 PM | #153 |
Working on AC and heating ducting under the dash, there is a lot going on under there.
08-03-2020, 05:12 PM | #154 |
We need an update man!
08-10-2020, 07:40 PM | #155 |
Casey, your right needed to download phone pictures hope they work. Here is a small update. I completed the engine bay AC stuff and still working on under dash things. I repaired the cut radio hole, I got an aftermarket speaker because that will need to go in first or never get it in, dash pad, middle AC vent and ducting work my way down and out. I had a paint shop mix GM 521 to factory spec. and put in spray can application I'll post when I get the dash painted.
7D2N sorry for sideways pics can some one helpme turn them.
08-11-2020, 11:01 PM | #156 |
Here you go
08-13-2020, 08:27 AM | #157 |
Thank You
09-15-2020, 09:50 PM | #158 |
Small update: I rattle can sprayed my dash with the 521 GM paint I had the shop mix and I think it worked out fine.
7D2N
09-15-2020, 09:59 PM | #159 |
Dash cluster work.
09-18-2020, 01:36 AM | #160 |
I just read this whole thing and couldn’t stop until I read it all. Nice work.
James |
09-18-2020, 06:57 AM | #161 |
Nice work....how hard is it too pull off the needles for the gauges
09-18-2020, 04:07 PM | #162 | ||
I didnt remove the needles, if you noticed the aluminum foil in the photo I cut small slots and slid it under the needles and pressed in place and used a brush on reflective needle paint.
09-19-2020, 08:44 AM | #163 | |
Is the paint available online, looks like a good match
09-30-2020, 08:41 PM | #164 | |
7D2N
09-30-2020, 09:06 PM | #165 |
I completed a few things on and under the dash, kick panels vents rebuilt, all ductwork replaced and GM radio installed.
09-30-2020, 09:27 PM | #166 |
I'm really close for the gauge cluster going in.
10-07-2020, 03:51 PM | #167 |
Craig,
Good to see that you are making great progress. Looks great! Jothan |
10-07-2020, 07:55 PM | #168 |
Thanks Jothan, Thanks again with the parts you helped me out with. I did finish up the dash area so I'll start on the doors.
10-09-2020, 01:57 AM | #169 |
That looks so nice. I want a blazer now.
James |
10-13-2020, 09:47 PM | #170 |
10-13-2020, 10:15 PM | #171 |
Moving to the doors and I have some things to fix.
11-02-2020, 08:49 PM | #172 |
I had some sandblasting done on my doors and fenders, does anyone know how should I prep the surfaces until I can repair?
Thanks. 7D2N
12-13-2020, 09:38 PM | #173 |
Started working on the doors and they need some patches. Any tips or advice on welding this together, butt weld, lap weld?
Thanks 7D2N
12-14-2020, 09:41 AM | #174 |
I'd butt weld it. Nice work so far.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-19-2020, 09:52 PM | #175 |
I'm fitting the patch panels on the doors, checking the fit and alinement before I cut for welding.
