09-30-2020, 09:40 PM | #51 | |
Re: #corona10truck - 77 C-10, pancaked crossmember - z'd frame etc etc etc
10-05-2020, 06:37 PM | #52 |
Plan is to raise the entire bed floor, or possibly convert it to a wood floor & sell the short fleet floor that I have since it's probably worth as much as I paid for the entire box. Once I'm done on the cab repairs I'll probably work on the box before I get to driveline stuff etc.
@badgaragebc |
10-05-2020, 06:51 PM | #53 | |
A clean wood floor would look nice!
10-20-2020, 06:11 PM | #54 |
So now with most of the suspension stuff back together - on to the less fun stuff..... rust repair
The cab has the typical rust for my area (Northwest) - front cab mounts were non-existent, floor was rotten & rockers (inner & outer) are garbage after ripping off some of the rubber insulation from the floor..... I wanted to get the cab mount in & secured before cutting out the rockers -
@badgaragebc |
10-20-2020, 06:15 PM | #55 |
then on to the real cutting -
Floor & rockers tacked in place I got my son to help me test fit the door, needed to make a bit of an adjustment on the outer rocker, but not much. Fit isn't perfect - but part of that is due to the aftermarket door I think as it wasn't great before either. I may end up adding a bit to the bottom edge of the door to improve the gaps, but I'll wait until I do the final sheetmetal fit up to decide if that is necessary or not
@badgaragebc |
10-20-2020, 06:17 PM | #56 |
and this happened to follow me home last night....... so we'll see what ends up happening with it soon (it's a runner and with a little work a driver, but it needs this same rust repair on the cab - the parts needed came with it (mostly))
@badgaragebc |
10-21-2020, 03:24 PM | #57 |
Thanks for posting the rocker and floor pictures. Never tackled that myself before and plan on doing it over this winter. Helpful to see it all cut out. Great project this year!
10-21-2020, 03:30 PM | #58 |
Yes, I always like seeing somebody's approach to rust repair sequencing.
Evan B. |
10-22-2020, 03:50 PM | #59 |
Thanks for the repair pics- hoping to do the same on Christmas break.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-22-2020, 07:08 PM | #60 | |
10-23-2020, 12:18 PM | #61 |
definitely not original paint on the white one - it was a previous owners faux patina job. I kinda like the look, I'll probably leave it
@badgaragebc |
11-13-2020, 06:12 PM | #62 |
Back to finishing off the other side -
Floor is a bit uglier than the drivers side....Not by much though rough cut out of floor Replaced a section of the floor brace & added the new cab mount & floor support piece Floor tacked in (outer rocker is cut out at this point & the new inner rocker is also tacked in) Finished welding, primer, a bit of filler on the new rockers at the seams, seam sealer on all the floor welds & a bit of spray paint and it's done, floors, cab mounts, inner & outer rockers replaced on both sides of the truck
@badgaragebc |
11-13-2020, 06:15 PM | #63 |
And now the little blue S-10 gets to go on the single bay side of the garage for some upgrades before drag racing starts up again next year (my 14 year old son's truck)
My stuff will sorta sit until we get the new rear end & rear suspension in his S10 along with some wiring and other details we need to do. Then I'll probably get to the white step side for a bit and get it road ready for spring. Might start another thread for that one
@badgaragebc |
