Old 11-05-2020, 02:49 PM   #1
Asshat
Asshat's Avatar
Clutch linkage for the 4-speed trans
Anyone running the standard linkage? I have a 63 C20, 292, 4-speed. The clutch fork has two positions for the rod coming from the pedal, and it looks like it could fall out of place.
I was thinking of using some safety wire to make sure I don't lose any parts. Anyone else done this?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-05-2020, 03:37 PM   #2
61K10
61K10's Avatar
Re: Clutch linkage for the 4-speed trans
you need a clutch fork return spring that goes from the tip to the frame.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-05-2020, 03:42 PM   #3
Asshat
Asshat's Avatar
Pics?
292, 4-speed
Old 11-05-2020, 03:57 PM   #4
MusicMan70
MusicMan70's Avatar
Here's a partial pic...
and post#3
http://www.67-72chevytrucks.com/vboa...+return+spring
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-05-2020, 04:32 PM   #5
geezer#99
geezer#99's Avatar
Check this.
Better pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=300537
Old 11-05-2020, 04:54 PM   #6
Asshat
Asshat's Avatar
I’m wondering how long that return spring is.
292, 4-speed
Old 11-05-2020, 05:14 PM   #7
geezer#99
geezer#99's Avatar
Likely about a foot long.
Old 11-05-2020, 05:31 PM   #8
Asshat
Asshat's Avatar
🤔 Really, a foot long? That’s a long spring.
292, 4-speed
Old 11-05-2020, 05:38 PM   #9
geezer#99
geezer#99's Avatar
Look in post #4 in that link.
It’s not all coils.
Old 11-05-2020, 06:28 PM   #10
Asshat
Asshat's Avatar
It’s not all coils.
Yeah, see what you mean.
292, 4-speed
Old 11-13-2021, 09:01 AM   #11
rgtrough
rgtrough's Avatar
Hey guys, I’m going through the “where in the hell does the clutch return spring go” also. I don’t think Bubba had mine hooked up correctly. I have a larger diameter shorter in length spring and no other spring. When I purchased a new clutch return spring for a 1966 c10 I only saw the larger diameter shorter length spring. I guess I will install the spring that I bought between the clutch fork arm and the linkage plate that holds the other end of the clutch adjustment rod.
peace Bud
1966 C10 4X4
1962 Impala Sport Coupe
1974 Corvette Coupe
1987 Suburban
rgtrough is offline   Reply With Quote
Old 11-13-2021, 12:09 PM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
The clutch fork return spring - https://www.americanclassic.com/1963...ctinfo/90-791/
Old 11-14-2021, 12:57 AM   #13
AcampoDave
AcampoDave's Avatar
My clutch is set up with the push rod on the outboard hole. I figured it would give me more leverage that way for my leg. Did 6 cylinders use the inboard hole and wouldn't that decrease leverage at the pedal?
AcampoDave is offline   Reply With Quote
Old 11-14-2021, 08:47 AM   #14
rgtrough
rgtrough's Avatar
Thanks. Ordered one. Is the one of which I’m referring to for the clutch pedal itself?
peace Bud
1966 C10 4X4
1974 Corvette Coupe
1987 Suburban
Old 11-15-2021, 10:13 AM   #15
Rubbertiredtramp
An interesting topic. I Can see by the picture where it hooks to the fork, but what about the other end. I made an attachment point on the frame for mine, but would like to see where the factory hooked it.
Rubbertiredtramp is offline   Reply With Quote
Old 11-15-2021, 04:09 PM   #16
61K10
61K10's Avatar
there is a notch or hole forward on the frame where the spring hooks into.
anybody know why there is two notches on the throw-out bearing fork?
1961 chevy K10
Old 11-15-2021, 11:20 PM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by The Rocknrod View Post
That's what mine on my 65 looked like.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-15-2021, 11:53 PM   #18
cwcarpenter98
cwcarpenter98's Avatar
I had half of that same spring above left hanging on the frame of my 63 when I got it. Of course, I took it off 6 years ago and don't remember where it was hooked into
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
