Old 11-10-2020, 05:40 PM   #76
WilliamFd55
Re: His name is "George" 84' C10
Point of no return.......
Productive weekend. Motor is out and will start cleaning up the frame and wires. Aired out, the truck was so low that I couldn't get under it on common ramps. Built my own, to get where we need to be. Plan to mock up the motor this weekend to see how low the OEM pan hangs, then go from there.
WilliamFd55 is offline   Reply With Quote
Old 11-10-2020, 05:48 PM   #77
SCOTI
SCOTI's Avatar
Good luck!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-30-2020, 12:50 PM   #78
WilliamFd55
Happy Turkey day all! Spent this time off cleaning up the frame/ firewall and got them painted. Decided to get a new oil pan that its shallower and is set up for the turbo drain already. While waiting for that to come in, painted the alt bracket and mocked it up. Once the pan comes in, I can start getting this thing back together.
Old 11-30-2020, 12:59 PM   #79
SCOTI
SCOTI's Avatar
Nice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2020, 09:53 AM   #80
WilliamFd55
Another productive weekend! Was able to swap the oil pan, get the flywheel/ clutch/ trans together and got her installed. Used TSP Low clearance pan for the swap. This is very similar to Holley's pan, but around $100 cheaper and has provisions for a turbo drain. The pickup tube did have some burs left from cutting at the factory that I had to push in through the screen to get it out. Also the Windage tray had to be modified for the tube to fit and the pan to sit flush. Cut it back to the first bump down in the tray. Did find a note form the previous owner when i opened the pan up
Old 12-14-2020, 09:56 AM   #81
WilliamFd55
Some more pics showing how much of the tray was removed.
Old 12-14-2020, 10:00 AM   #82
WilliamFd55
Here are some pics of her in place. Used ARP for pretty much everything. I know I use the word "Budget" a lot, but then find myself spending hundreds of dollars on bolts .
Old 12-14-2020, 12:03 PM   #83
daddyjeep
daddyjeep's Avatar
Sometimes you have to spend some dollars. Spend them in the right places.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-14-2020, 12:53 PM   #84
SCOTI
SCOTI's Avatar
x2. Quality fasteners are definitely a worthy investment for certain areas.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2020, 01:57 PM   #85
tinydb84
tinydb84's Avatar
Hahaha I love the note!
David
Instagram: myfabguy
Old 12-16-2020, 10:24 AM   #86
WilliamFd55
Agreed. Started this project very budget minded, but just makes sense.
Old 12-16-2020, 10:32 AM   #87
WilliamFd55
Decided to get some sensors changed out while I still have access to them. Also modified the Plenum back to its original position with my custom jigs I think this thing is going to fit under the hood! Did find some space issues with the valve covers I want to run. Very close to brake master booster, so will have to modify.
Old 12-18-2020, 04:23 PM   #88
tinydb84
tinydb84's Avatar
I made the mistake of not replacing my sensors when the engine was out. Lot less fun to do once everything is connected and in the truck. Did you get the crank sensor while you where there?
David
Instagram: myfabguy
Old 12-21-2020, 12:10 PM   #89
WilliamFd55
Shoot, I did not. It looks to be in good condition, but probably a good idea to change anyway. Thanks
Old 12-21-2020, 12:14 PM   #90
WilliamFd55
More plenum work. Pulled out the Dremel and did some more carving. Plan is to paint the same battleship gray at the block with black stars and stripes. Maybe center stripe red?
Old 12-21-2020, 03:35 PM   #91
daddyjeep
daddyjeep's Avatar
Nice
04 1500 crew cab
Old 12-25-2020, 09:40 AM   #92
moregrip
moregrip's Avatar
Very cool! One of a kind now!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 12-28-2020, 01:52 PM   #93
WilliamFd55
Thanks guys, here is the finished product. Overall happy with how it turned out. Went with a distressed look and now has an X Wing fighter from Star Wars vibe.
Old 01-04-2021, 11:49 AM   #94
WilliamFd55
Happy NEW Year! Started my new year off by re-engineering Edelbrock's SBC valve cover adaptor. With their set up, the coils are bunched together and the plug wires are bent really tight. Also there is nowhere for an oil fill. Started by cutting off the OEM fill and laying out how I wanted everything positioned. I originally tried to weld the ring on, but I ended up warping it with the heat ( Still learning TIG! ). Ended up using a high heat style of JB weld. Made a plate to mount the coils, which will allow me to use Edelbrock's mounting positions and add space to tuck the wiring harness in. Aluminum was from an old sign, so it looked like "Forged in Fire" when I melted the reflective coating off. With everything mocked up, the valve covers still fit!
Old 01-04-2021, 11:55 AM   #95
WilliamFd55
Some more pics...... Drilled/ Tapped both covers to allow 10an to 3/8 NPT fittings, to eventually run to a catch can. Also made up some baffles and opened up the wire ports. Found these were also very tight during mockup.
Old 01-11-2021, 09:55 AM   #96
WilliamFd55
Slow going.......Getting back into the hour here, hour there routine. Was able to get the covers/ coils set up installed. SBC cover is snug in there, but it fits! Mocked one of the headers and it looks like I will have to install some heat shield on the cover.
Old 01-13-2021, 10:32 AM   #97
daddyjeep
daddyjeep's Avatar
How did you even get that valve cover on there? Did you cut the back out of it by the firewall? That is a tight fit.
04 1500 crew cab
Old 01-13-2021, 11:23 AM   #98
WilliamFd55
I did. By cutting the back out, I'm able to slide it back and drop it into place. Still working on modifying them, will upload some pics.
Old 01-18-2021, 09:47 AM   #99
WilliamFd55
And we're plumbing..... Some pics of the catch can installed and heater core lines. This side of the engine bay is going to be tight. Wanted to dictate where the lines are run and not have them flopping around in there. Made up some brackets to keep everything in place.
Old 01-19-2021, 11:04 AM   #100
WilliamFd55
Throttle cable time! Cable is not long enough and didn't what it laying across the plenum. No matter how I set it up I knew it would have to be custom. Decided to flip the throttle body upside down to keep everything on the drivers side. After fabbing the bracket up, the cable just had enough room between the alternator. I figured that the cable had to be lever, but that was not the case. After testing the peddle I was not able to get to full throttle. Will have to modify to raise the bracket up on an angle and see where we are at. Here is the first failed attempt.
