![]() Join Date: Oct 2009
centering brake pedal
I almost never do a tech thing and perhaps someone has already done this. But, a small thing that has always bothered me is that the auto and manual trans both use the same pedal hanger. When you change a manual to an auto and remove the clutch pedal (just like the factory did) then the brake pedal seems to be very close to the gas pedal. So, to fix this. I removed the clutch arm and cut the pedal off. Then cut the pedal off of the brake arm. Then the two pedals were sectioned and welded to the width of an early Impala power brake pad. The clutch and brake arms share a common hole which when bolted together to align them, I cut them off. The reason is to replace the brake arm with the clutch arm because the clutch arm kicks off to the left, therefore moving the pedal to the left.
If you want to move the brake pedal to the left and have a wider power brake pad, this is one way to do it. I hope some of this makes sense, if not perhaps the pics will. |
Re: centering brake pedal
Nice, I like that a lot. Too bad my welding skills could prove that mod to be lethal.
Nice work. Can you show us a photo of the setup in the truck and how it looks next to the gas pedal?
Moderator
![]() ![]() Join Date: Aug 2011
Oh man, that' looks great clemdaddy.
Nice work Pop's.
Now I know where I got my mad welding skills. |
![]() Join Date: Feb 2011
Great Job!!
MusicMan70 1961 GMC Suburban |
64-66 CHEVY JUNKIE
Very Nice.. what Year Impala Brake Pedal is that?? 60's ?? Thanks
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
![]() Join Date: Mar 2011
That's a great idea. A little too late for me but I would have stolen it at the time.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
Good Job! I feel the same way you do and moved my brake pedal over when I converted my 64 drums to a 73 Disc brake setup. Since I went to Discs I used a 73 pedal though.
Actually started modifying mine today and didnt think about using the clutch pedal to offset it a little to the left like it needs to be.
Now know what I will be doing tomorrow .
1964 C10 Resto-mod 5.3L - L59 |
