Old 10-19-2020, 03:33 PM   #176
Tempest67
Tempest67's Avatar
Re: 51 Chev on a S10 frame, named Dale
Hey Guys,
I am not happy with my clutch master cylinder, so why I am waiting for some parts, I decided to make some hood prop rods. (idea from Orange Peel, thanks)
I used 2 holes that were already in the front hood brace.
Each rod is about 24 inches long, just long enough to fit under the hood.
Tempest67 is offline   Reply With Quote
Old 10-20-2020, 03:23 AM   #177
MiraclePieCo
MiraclePieCo's Avatar
Your truck is looking SOOOO good! I'm a big fan of the moons and trim rings.
Nice job on the hood props too, but won't you miss the metallic screeching of the stock springs resonating through the whole hood and the adrenaline rush of knowing that it could fall on your head at any moment?
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-20-2020, 08:16 AM   #178
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Prop rods look good.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-20-2020, 08:51 AM   #179
8man
I like the prop rods. Do you have the before and after picture of the hood?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 10-20-2020, 09:02 AM   #180
gigamanx
Originally Posted by Tempest67 View Post
took it out for a run yesterday and took some pics.
Looking good!! I really thought that bed was stock until I saw the wood widths being all mixed up. Nice truck
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 10-20-2020, 09:32 AM   #181
Tempest67
Tempest67's Avatar
Thanks Guys, I am having a lot of fun with this truck. Still need to finish off the rear end with a bumper or a roll pan or both, maybe some reverse lights, tag holder with a light...???... but that will be a winter project.
MPC - my wife insisted on the Moons with the red 'Chevrolet' letters....... I am a fan of a 5 spoke wheel, but these are growing on me...... maybe change the wheel color from black ????? and yes, that sound of the hood springs is a "special" one. ha ha
Ol Blue - Thanks
8man - not sure what you mean by 'before' pic, but the back of the hood sat up about 1/2 - 3/4 inch off the cowl, with no springs it sits tight on the new seal.
Gigamanx - the planks were rough cut at 11.5 inches, it would have been easier to just place 4 of them in the bed and be done with it, but I wanted the variation of the widths. I did put the full width (11.5 in) over the gas tank in case I need to get at it.
Old 10-27-2020, 09:58 AM   #182
Jason 56
Looking good. Love the stance. Congrats on getting her back on the road... I’m jealous
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 11-12-2020, 11:15 AM   #183
Tempest67
Tempest67's Avatar
I was never happy with my clutch master being located under the dash, so I decided to mount the clutch master on the firewall, where it belongs.
Well, that started a chain reaction of expenses. First, I needed to buy a small, 7 inch, brake booster to create space on the firewall (the S10 booster is almost 12 inch diameter)
Then , I purchased the American Power Train adapter plate to allow the push rod to go 'directly' into the master.
Then, thinking I could reuse the S10 Brake master, but No, the flange on the S10 master would not fit inside the hole of the new 7 inch booster, so I had to buy a new Brake Master.
Now, after logging several miles on the new set up, it is great. Clutch pressure is OK, wife thinks it is a little stiff, but it does not keep her from driving it, and the feel of the brakes is good too.
Also found some rear view mirrors at Speedway. I think they look good, but the passenger side does not adjust to be functional. I guess this where form trumps function..... and there is great visibility in a 5 window anyways.
The neighbours love the truck and want to decorate it for Christmas..... not sure exactly what that means ???
Still lots to do, but enjoying the process.
Old 11-23-2020, 12:41 PM   #184
Tempest67
Tempest67's Avatar
Ok, time to work on the rear bumper. I plan to make a roll pan, but thought I would start with a bumper. I had a front bumper with the chrome peeling, but it is too curved for the rear, so I decided to be creative. (some would say cheap)
First I straightened it by lowering a loaded snowmobile trailer onto it.
then I cut the ends off and reshaped the ends
then I used some 1.5 inch flat rod and made some bumper brackets
then I used the old pieces of frame that I cut off the rear to make some brackets to attach to the frame
and gave them a quick coat of paint
Old 11-23-2020, 12:43 PM   #185
Tempest67
Tempest67's Avatar
and I had to cut out a notch for the tag.
I still plan to add a roll pan, but here it is for now.
Old 11-23-2020, 12:56 PM   #186
Brads49
That turned out great! Looks good
Brads49 is offline   Reply With Quote
Old 11-23-2020, 01:01 PM   #187
Tempest67
Tempest67's Avatar
Thanks Brad.
the roll pan will hide the brackets and make things look better, I hope.
It is a Patina truck, so it looks fine for what I need.
Old 11-23-2020, 01:51 PM   #188
8man
Nice work, looks good.
8man-aka Robert
Old 11-23-2020, 05:47 PM   #189
olcarguy
Lookks good Sir....nice work...
olcarguy is offline   Reply With Quote
Old 11-23-2020, 10:16 PM   #190
Ol Blue K20
In my humble opinion, I'm not sure you need a roll pan. That bumper looks great and fits the bill.
Dale
Old 11-30-2020, 06:57 PM   #191
Tempest67
Tempest67's Avatar
Thanks Guys,
Ol Blue, I think it looks OK without a roll pan too, but after seeing all the great metal fab work from all the people on this website, it has inspired me to give it a try, afterall, winter is coming.
Here is another pic of it, and it looks like the rear bumper sticks out too far, I am hoping the roll pan will change that
Old 11-30-2020, 10:32 PM   #192
Black93GT
Black93GT's Avatar
Man that thing really freed up space! I struggled to get around the S10 booster as well.
'49 3600 build
SBC 350, a T-5 and some patina
Black93GT is offline   Reply With Quote
Old 11-30-2020, 10:35 PM   #193
Ol Blue K20
Thanks Guys,
Well, since winter is here. I say go for it!! I'm here to watch.
Dale
Old 11-30-2020, 10:41 PM   #194
Tempest67
Tempest67's Avatar
I was trying to be 'thrifty' and use as much from the S10 as possible, but I learned that the 7 inch booster with matching master is well worth the money. (if you are going with a manual trans)
Old 11-30-2020, 10:48 PM   #195
Tempest67
Tempest67's Avatar
I will keep you posted, but please be kind as I am nowhere near the talent you see here.
Here's another pic I just took
Old 12-01-2020, 10:16 AM   #196
Ol Blue K20
Ya never know until you try. You may surprise yourself....
Dale
Old 12-03-2020, 10:22 AM   #197
joedoh
joedoh's Avatar
outstanding!
Old 12-24-2020, 03:01 PM   #198
Tempest67
Tempest67's Avatar
Merry Christmas Everyone, and I wish you all a Happy 2021
Santa is almost ready to go...........
Old 12-25-2020, 01:00 AM   #199
28TudorAZ
28TudorAZ's Avatar
I think the rear bumper looks good. I wouldnt do a roll pan. If you are worried about it pull it in another inch or so before the tailgate. Here is a picture of mine. Also love the Christmas theme.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 12-25-2020, 04:42 PM   #200
Tempest67
Tempest67's Avatar
Thanks, your truck looks great.
We got a White Christmas this morning
