![]() Join Date: Oct 2019
62 engine angle issue
Hey all, I need some help! I'm mocking up a V8 for my 62 C10 and the engine angle seems way too steep. I measured it at 12 degrees. I'm using the 67-72 engine perches with a 1/4 inch spacer on top of the frame. Transmission is attached and in place. Maybe I need to try a different mount? Feeling kinda confused.
Todd |
![]() Join Date: Dec 2009
Re: 62 engine angle issue
I think you need different mounts.
Maybe the 60/66 Guru's can help with the correct mount. Here is the flip for ya/ on the pictures. .
I think so.
How do I flip the pictures? Can't figure it out and everyone keeps doing it for me! |
#4 | |
Always edit your picture with a small(crop ). Then click the (preview post) button before you submit post. Hope this helps. .
To me the perches look good. I'm wondering about the tranny mount....what do you have for that?
What is the pinion angle? If it's close to 12° pointing up (maybe a degree less?), you're probably good. The angle of the engine/trans and the angle of the pinion need to work together.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
![]() ![]() Join Date: May 2015
12deg is wayyyyyyy to much...needs to be around 3 deg down...and diff needs to be matching angle, but up...
I'm not familiar with your yr models and what it takes to install a v8..is using the 70s mounts a common thing to do?.. They look awfully high to me..
I did find this old thread on it, so I guess the 70s mounts do work..
http://67-72chevytrucks.com/vboard/s...d.php?t=497634 According to Mark's post you may need a diff trans crossmember http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-30-2020 at 11:12 AM. |
The engine in my '77 C10 is 5° down, which at a lowered ride height, it actually too much for the u-joint operating angles to work with the pinion angle.
I have a transmission crossmember from Capt. Fab
I'm wondering if the trans mount is too thick? I did see a lower profile one. Last edited by Todd46; 11-30-2020 at 08:33 PM. |
60-66 Nut
The rear of the trans needs to go up, or the engine needs to go down. If that trans crossmember isn't going to work, let me know and I will send you one that does.
60-66 Nut
Are those engine mount brackets for a '67-'72 with a small block?
Yes they are. I will see what adjustment I can make with the transmission.
#15 |
I had the same issue when I mocked up the engine in my 62. I used 67-72 mounts and it made fit much better. The motor sits at 3degrees. Hope this helps.
